Hi All
Well, after spending the last 2 weeks trying to find tyres, and every time i find a tyre i like being told "there are none in Australia in your size" (205/55/16, to go on standard rims) (This has happened with both the Hankook K104's and Goodyear Eagle F1 GS-D3), i have been recommended the Goodyear Revspec RS-02 (The place that recommended them actually suggested i get the Eagle F1, but then found out that there were none in Aus)
I see these tyres recently places First overall in the Wheels (Or Motor?) Tyre test for 2005?
Does anyone have a copy of the article that i could see?
The shop has ordered me 4 of these in, and at around $230ish a tyre, i didn't think it was overly bad (though i would have preferred to pay the $190/tyre for the Eagle F1's)
Does anyone have any experience with these tyres?
https://www.sau.com.au/forums/topic/93651-goodyear-revspec-rs-02/
No, but had experience with Gy Eagle GSD 3 f1's, I had 205/55/16's on my R32 GTS 4. Some people raved about them - overseas, but I didn't think they were anything too special, good in wet but awd makes most tyres look good. Not great in 205 size for a 1450kg plus car, too soft and squirmy under really hard driving(trackwork) - prob a much better tyre in 225 or 235 size for a car weighing as much as a skyline does.
So just a review reinforcing your decision to buy another tyre..
    • Not sure why but RBF660/700 or Castrol SRF is listed as DOT4, not 5.1.
    • Interesting....can't say I've ever checked it, have always just changed it in the off season as practice
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
