i know this has been discussed before, but my enginee is making a tapping noise from idle to 4krev its always there i am currently looking at getting a screwdriver and listening to the diffrent parts of the engine. its either injectors or tappets....
could cleaning the injecters fix the problem if it is injector related.....
i bought the car and it didn't make that much noise but now after the first oil change its always there and anoying... any ideas how to fix the problem
https://www.sau.com.au/forums/topic/93655-injectors-or-tappets-making-noise/
my rb25 developed this noise after about 80,000k's of use. i was told by several work shops that its fine. engine @ 130,000 and still going fine on same injectors. they used to be silent as then one day noticed they make tapping noise
I've got the same sound in my R32 RB26
So do you guys think that it's the tappets or the fuel injectors.
I tried listening with the stethoscope thingy and couldn't tell where it was coming from.
If it is the tappets and it doesn't get louder do you think that it'll be alright.
Is there any sure way to tell. I'm thinking about throwing in some thicker oil to see if it goes away, otherwise how would I tell which it is?
Edited by RB240Dav
Is it more of a ticking sound rather than a rattle?
I've noticed that my last 2 sets of single pintle 550 injectors were pretty noisey and that was a ticking/clicking sound.
The last set of buggered lifters i heard were more of a rattle that got significantly louder with revs. There's a big difference in the sound. What sort of car are we talking about here as an rb doesn't have tappets.
Right right, Lifters, I don't know what I was thinking.
Which reminds me, I have yet to put a load on the engine, so the lifters might not be tight yet. The motor probably sat for at least a year so I'll have to see what happens once I get it out on the road.
Yes, it's definately a ticking / tapping sound. The frequency increases with rpms, but doesn't get any louder. Do the stock injectors make some noise themselves, I mean 440 is a pretty good size injector.
  • 1 month later...
not sure mate my rb26 has 550cc injectors and it makes a similar noise to what u r discribing and fairly loud to, also a slight noise from the lifters in my car but can hardly hear it ova the injector noise
Edited by Turbz_13
    • It doesn't look like there's a lot of options out there these days, and what's out there is performance oriented aftermarket stuff (with the GTR markup) I wonder if there are other cars with similar springs, after all its just a matter of length, diameter and stiffness. Alternatively, I did see coil spacers. Probably not the best option, but could be serviceable too.
    • Final thought for now. Obviously the reason I was in there was to check everything is OK cooling wise, pull out the radiator to flush it etc, but I have to say the factory has done a hell of a lot of thinking about air management in a way they never did back in the R chassis days. The Redsport/400rs have (from engine forward) 2 large shrouded fans - radiator (incl AT cooler) - AC condenser - Intercooler Heat Exchanger and Oil cooler. There are shrouds and foam around everything to keep it pretty well sealed, which is good in that they have it sorted from factory, and bad in that I can't make any meaningful improvements there. The second red sport pump water pump is mounted in front of the rad in the airflow, so I will see if there is somewhere else I can stash that (unlikely, it is tight in there). The horns which are also in the rad airflow will be moved somewhere else, and hey who needs 2 when 1 would work For track days, I can also remove the lights which would block some airflow. Factory has already taken the smart option of ducting all air that went through the oil cooler down and out of the engine bay. This pic is taken from below looking up, so air comes through the cooler at the top of the pic then hits the shroud and is directed down and out of the engine bay through the engine bay lower cover Which of course is good for oil temps, but doesn't help the rad as it diverts 10-20% of airflow away So, no big improvements to be made here, I'll flush the rad out and put it all back together.....
    • It looks so incredibly busy in there! 😮
    • Next..... That escalated quicker than an Elon and Donald break up! I'll post up a specific DIY for radiator removal on these, but all I'm saying is that if you get a workshop to change your radiator for any reason and they give you a $1000 bill for it, go and hug them and thank them for not charging all the hours it took.....what a bastard of a job. I'll make some adjustments as I put it all back for faster access in the future, but it was a nightmare.
