You can either remove the indicator itself, it clicks into the headlight and has one scew to the rad support panel.....that way u can undo the plug and pull the bulb out with open space rather then full cramped room. Or you can try getting behind the light while still attatched to the rad support panel and struggle a little
cheers, done. take the single screw out then wack it out was the key
