i'm selling my gts-t
i wish i didn't have to, due to it being my pride and joy, though life can throw things in your travels,
it wasn't planned but yes the old feller works fine i have a baby on the way
must use funds from car to establish the new comer comfortably
anyway back to the car
175kw@rw
it's a 96 series 2 with 125,000 km's
with white 17" light weight racing rims
adjustable coil over suspension
it has three strut braces one in the bonnet one in the boot and one on the parcel tray
microtech lt8 computer which controls the car like a dream
it has a turbo smart type 3 blow off valve along with the standard one (to keep the cops at bay)
pod filter along with standard intake box and filter (same as above)
trust greddy front mount intercooler
brand new 3" inch exhaust (legal db)
apexi avcr boost controler
turbo timer
boost gauge
momo steering wheel
front spoiler on standard bar
cd player 12" sub and 1500 watts of amps
new battery with 3 years warranty
12 months rego
the turbo on the car is spot on,no leaks or noises i recently put a new exhaust on the car and checked for shaft play or rear fin damage, there were no signs at all
$19,000ono
Edited by masivr33
https://www.sau.com.au/forums/topic/93686-r33-series-ii/
  • 1 month later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
