The airflow meter on my series 1 stagea just died just wondering  what fits,  will any r33 do or is there a specific type for stageas ?
AFM's don't die, are you sure?
Stagea AFM's are not unique, same as R33GTST.
:) cheers :P
https://www.sau.com.au/forums/topic/93693-afm-help/#findComment-1691917
Gave it the boot on about 80 it took off then just died when i pulled over it would idle for a few seconds and stall. This happend on my r31 when the afm died on it so i tried the old fix for that on the stag disconected the afm and it went into limp home
https://www.sau.com.au/forums/topic/93693-afm-help/#findComment-1692250
Limp home doesn't prove its the AFM. For example if the throttle position sensor dies and you unplug the AFM, it will go into limp home mode. Just make sure it is the AFM by checking the output voltage with a multimeter or a Consult. If it is the AFM, I would always try cleaning it (with spray on brake cleaner) before I chased a new one.
:( Cheers :P
https://www.sau.com.au/forums/topic/93693-afm-help/#findComment-1692642
