hey, im doin an assignment for Physics and i have to find out the Ideal speaker layout of a car for maximum sound and quality n that. i was jst wondering wat do u guys think is the best layout...like in front doors, back doors, the bit above the back seat, boot, dash where eva u can put a speaker
Kind Regards,
Cootie
https://www.sau.com.au/forums/topic/93740-speaker-layout/
what sort of criteria defines the best layout in your assignment?
I would base the whole thing on the main set of speakers being built into the kick panels, which is the part in front of the door next to your feet on side of the car i.e. left of your feet if you are a passenger and right if you are on driver side.
The idea behind this is that it lessens the difference in distance between the listener and the two speakers either side of the listener.
The reason for this is to make it as close as possible to a situation where you are sitting directly in the centre of the two speakers like in a home HiFi environment.
Remember that high frequency sounds are the most directional so where you mount and direct your tweeters (assuming you are using component speakers) is the most important. You should point your tweeters so that the sound from both sides meets in between the two front seats or at the drivers head if you didn't have to worry about it sounding good to a passenger.
hope that helps
https://www.sau.com.au/forums/topic/93740-speaker-layout/#findComment-1693703
Yeh it does help thanks...the criteria is that is has to have good quality sound comming from it...no interference, loudness has to be good enough, not muffled by anything. and last i guess how easy it is 2 install the speaker and hide the wiring...hehe might not sound like a physics experiment but yeh i gotta make it sound like one.
https://www.sau.com.au/forums/topic/93740-speaker-layout/#findComment-1693833
do not run power cables with rca's or speaker cables, use oxgen free copper for all cables running to and from the amp, use all gold plated connetions all connetions to be solder as well. As for speaker lay out, subbs to be facing windows eg back window. splits to be facing the centre of the car say just above the centre console, if you have 6x9's dont run them of the amp they will conflict with the sub noise they are to be used as rear fill only.
Good luck thats about all i can give you.
oh amp cable should be 10g which is 10 gauge oxgen free power cables.
https://www.sau.com.au/forums/topic/93740-speaker-layout/#findComment-1694400
usually mounting two 6x9's in the rear parcel shelf is a good idea as the sound hits the back window and reflects back towards the front of the car
subs work on sub sonic sounds so the main aim is to get a decent amount of reveberation throughout the cabin - thus they are usuually mounted in the boot as it has heaps of unrestricted space fro reberveration
two subs mounted facing inwards just behind the rear wheel arch is a good idea - ie one on each side
or go custom boot mount and have them mounted in perspex in teh middle of the boot facing upwards and slightly backwards
https://www.sau.com.au/forums/topic/93740-speaker-layout/#findComment-1715227
dont place a speaker facing dirrectly at another speaker or a completly flat surface, otherwise it will suffer from sound cancelation
you should learn this from the idea of superposition and peaks and troughs of sound waves
https://www.sau.com.au/forums/topic/93740-speaker-layout/#findComment-1717152
If you wanna learn a bit about car audio, especially SQ - sound quality, go and do some searching on www.nzicemag.co.nz should help you out lots. Be warned though, search first, ask second:-)
There has been a bit of debate about SQ recently.
Ideally a car would run a 3-way front and sub. Thats Tweets, mids - say 4-5" speakers, mid woofer - 6.5-8" speaker. Then one or two subs, whatever takes your fancy. Your sub doesn't 'reverb' to get sound, it actually plays a portion of the sound spectrum, ie deep/low bass in music. Usually from 50-80hz and below.
Paramount in getting a really good sounding system is installation. I can make my average joe speakers outperfom some very expensive speakers because mine have been installed well, ie custom pods/baffles, fully sound deadened doors/panels, tested speaker placement, proper wiring, quality equipment. Custom sub enclosure to sub woofers recommended volume.
Seriously I could write a fair few pages on details of getting the most out of your system, but go have a look at above site.
https://www.sau.com.au/forums/topic/93740-speaker-layout/#findComment-1746590
My dad uses copper in our home hi-fi, just 2 speakers pre amp power amp and cd player. the speaker cable connectors are copper and the interconnects are silver. And this is a 30,000 dollar hi fi he's got.
https://www.sau.com.au/forums/topic/93740-speaker-layout/#findComment-1761638
"Conductivities vary for material being greatest for metallic solids, lower for nonmetallic solids, very low for liquids, and extremely low for gases. The best ordinary metallic conductors are (in decreasing order) silver, copper, gold, aluminum, beryllium, and tungsten."
http://hypertextbook.com/physics/thermal/conduction/
https://www.sau.com.au/forums/topic/93740-speaker-layout/#findComment-1762219
Put 5x7 two ways in the front doors and they sound good, had ripped out originals cos they were stuffed. Managed to pull out plastic speaker mount and cut it out a little to suit the 5x7s. reinstalled everything and it still retains the clean stock appearance. Put 6" 2 way kenwoods in the back. Just have to sort out what sub install I can fit in the boot without loosing to much room and gaining xtra weight.
https://www.sau.com.au/forums/topic/93740-speaker-layout/#findComment-1762227
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
