Item Condition: all in reasonably good nick
Reason for Selling: need space and $$$
Price and Payment Conditions: pickup or i'll post if payment is made in advance
Contact Details: reply or PM here
Have the following parts:
R34 NA 5 speed manual gearbox $500
R33 GTS25t bits:
standard intercooler $50
black front guards $150 each
steering rack and crossmember $70
front radius rods with red nolathane bushes $40 pair
RS*R front springs and struts $120 pair
power steering pump $15
brake booster and master cylinder $60
Heater core $80
Air conditioner core $25
Blower motor $20
Instrument cluster with 64,000km $100
Dashboard garnish that goes around radio, HVAC, air vents, from centre all the way over to the drivers side $100
Most other plastics around the dashboard except the dash itself - make an offer
Dont have the radio bracket :D
I'm going to brisbane around 20th december so I'll be able to drive stuff up if needed.
Cheers
Edited by Bozz
https://www.sau.com.au/forums/topic/93770-r34-na-5spd-gearbox-r33-parts/
what sort of strength is in those n/a R34 boxes? presumably similar to the RB20DET box i would imagine?
p.s. any chance you're willing to do the wiring for an RB25/30 into VL while you're up in brisbane? was reading some of your posts on PF and saw you did this kind of stuff regularly that's all.
Yeah its similar outer dimensions to an rb20det box.
re the wiring, i can do it but will need to sort out dates accurately later in december.
re the instr cluster, i replied to the pm
cheers
hello there
I have a r33 series 2 GTS-T.
do you sell the
1. front lip
2. rear speaker bracket... have a look at the picture
3. the cover that covers up the battery compartment in the boot
please let me know. thanks
The drivers side 1/4 is perfect, the passenger side is missing the GT badge and not as good condition. I'll sell the passenger side panel for $100
Edited by Bozz
Hey mate, With the R34 gearbox will i need to change my tail shaft, i have a r33 skyline rb20e....
Dayne
Absolutely no idea :D
I'd imagine the answer is the same tailshaft will fit but I've never swapped a 31/32/33 gearbox for an R34 one.
The only different gearbox I know of is the GT-R, VL turbo commodore and R33 GTS25t gearbox that uses the huge tailshaft yoke
will the gearbox stright fit into an r32 gts or is there modifying involved also r u negotiable with price?
I suspect it will bolt straight in but you may need a new clutch slave cylinder. I could be wrong though.
Offer a price via PM and you may be lucky and get it.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
