  • Replies 277
Posted Images
Will there be a collection at Crazy's for the southsiders? If you heed one I'll do it. Any suggestions for the best route to Aspley?
I was gonna lead the way, I've got it all worked out.
But it's not locked in, if Erin already has someone to do it?
Mud, it looks like I might be able to make it after all.
After a lot of sorting out on cars and who's going where, seems we are taking two cars just so we can work this all out. Expensive day! But damn i hope it's worth it.
So I should be able to lead the group from Southside, but Mud if you could be a back up incase things go pear shaped, that would be awesome.
