I think most of the importers use the same small/fall to bits side markers when complied!
Well thats what i had anyway.. I decided to go the good old typeII comodore VT side repeaters! For the simple fact they are clear and look ight!
They cost me NEW from holden city $45 for the pair.
Things you will need!
Power drill + a 1\8 SHARP drill bit!
Masking tape.
some paint.
texter.
printer paper.
soldering iron.+solder, electrical tape!
asortment of files.
First thing to do is remove the stock crap side markers, just a quick turn should do the trick! cut off the wires , and tie a bit of string around the wire. T save time later.
My dad had his VS ute at home so i took his repeater out to make a template of the hole in his body work.
To make a template i placed a bit of printer paper over the hole and used a blade to cut out the hole!
I added the front so it didnt go in wrong!
Place the paper over the existing hole in your guard, and line up with with a rule, or even your eye! (but use a rule)
Mark out the hole with a texter(i used blue lol) and then remove paper..
Have a good look at the texter and make sure its nice and plumb with the car! Cause once cut , no turning back!
To be safe and to see the shape of the hole i used some masking tape to go around the lines!
This is the FUN part. Grap ya powre drill and a new sharp 1\8 drill but.. I chose to drill out the hole than use a nibbler or other tools that can damage the sourounding paint work!
BE VERY CAREFULL when drilling, use some specks and other safe stuff so you dont get hurt, lol.
Now what ya wanna do is, place the drill bit onto the edge of the masking tape, About half a mm from the edge of the tape. DONT push too hard, you dont want the drill running off the hole mark onto ya paint...
start drilling the holes as close as you can to the one b4 , being sure not to push too hard, it take about 10 min a side.. so take your time..
20 small holes should do it... once the scrap part in the middle falls out from all the holes, get to work with ya flat file,(hand smooth) to file the hole till it is flat on the masking tape!
once all smooth place in ya repeater to be sure it will fit.. if goes in with out a hitch move on to next stage.. If not file more off till goes in.
Grab some paint and a small brush and apply a small run of paint on bare metal,(dont want it to rust) unlike origanal hole :D
take off masking tape. and use your soldering iron to solder the blinker wires to your new blinker!
Place new blinker in and test the light!
now do the same thing to other side!
end result, better looking blinkers! :(
https://www.sau.com.au/forums/topic/93785-sick-of-ya-cheap-side-blinkers/
  • 3 months later...
  • 7 months later...
hey, was this done on a 32 gtst?, .. kezza, is that black 32b in your sig the end result of your clear blinkers?. any one know if any one has but 32gtst blinkers or gtr r33 blikners on a r33 gtst, due to the different light, one sticks out and smaller and r33gtst is in the guard and longer and crapper looking
yeah mate. its my black one in my sig! im not sure about the R33 side markers, i would just get a nice set of clear or smoked nismo markers mate... look alot better than orange stocko ones!
while ya haveing a look check out my GB im doing, this is the last gb for me!
http://www.skylinesaustralia.com/forums/in...id=2663196&
thanx kezza.. yeah, ima get some clear nismo blinkers, but i just do not like the gtst side blinkers hey. gtr33/32 have those niced small poped out blinkers, ima see if this can be done on a gtst 33. ill let everyone know if it can be done :laugh:
yeah, they look cheap, funny that all nissans now have the gtr style side blinkers, damn it!. but not gtst, cheap bastards. hehe.. ill see what i can do, and post up how to do it, i cant live with these style blinkers much longer. :thumbsup:
yeah cause they are resesed into the front guard and shit . It would make it hard to out in aftermakit ones in!
even worse they are real LONNNGGGG blinkers!
You could go to the extreem and get a set of the new holden vent\blinkers, cause that template would be bigger than the stock one!
worth a think about!
kezza
Yeh the clear ones are really good.........until some jealous person who wants them and has no idea how to get em out, puts a screw driver in the front an snaps them an marks you car at same time :) do look the part but :)
damn bastards!!. i belive some one would do that 2 blinkers.. if i was rich i would put trackers on all the parts that are easy to steal, them suprise them at there house one day and ask for the part back..hehe, would be sooo funny...
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
