Hi people,
Fairly new here but been reading alot of posts on here and I have to say, I've learnt a fair bit and picked up some good tips on what to do and what not to do.
I own an R33 GTS-T and decided to rebuild the motor. My cousin and I have been around cars for a while now and have rebuilt motors before but have never attempted one of these babies! Managed to resource some parts and contacts, etc but...
--Has anybody rebuilt an RB25DET motor before and if so, have they come across any issues or have any tips for me as we are about to start in 2 weeks.
--Also, has anybody managed to find some good parts (pistons, gasket kits, bearings, etc) and does anybody know of any good brands? I've found it particularly hard to find parts for this motor. It seems easier to find parts for the RB26 motor.
Can anybody help here??
Thanks
gasket kit, Nissan
bearings, ACL Race series, same as rb26
pistons, anything cheap and forged like Arias from Rockett Industries.
I would have said it was dead easy to do, but my rb26 spun a bearing again after only 2000klm...so I guess my advice now is get a good machine shop. I've never rebuilt any other engine to compare it to, but it wasn't a tricky thing to do.
Thanks mate,
Good to know, we will be taking extreme care and I will be getting the block bored out 20 thou for the new Aries Pistons I'm getting. I actually spoke to Rocket the other day and said I could get them for $1080... Sounds pretty good.
Someone said something about torque deck boring where they use a template where the head usually goes and they bolt it to the block while boring.. This stops any distortion problems that might occur if the block is bored without the tamplate head on there because I was told that if you don't do it this way, when the real head is bolted on, the alignments can distort slightly...
I've done a fair bit of homework so hopefully nothing bad happens when I turn the key for the first time!! Think I might have a couple of drinks before I turn the key... just to relax me!! lol..
So those gasket kits, etc are ok?
no idea about the machining I outsourced that. Also had the head recoed.
the gasket kit is a must there are a million gaskets involved and they should be fine everywhere. A lot of people go aftermarket metal head gasket to lower compression but that is a whole other can of worms. The standard gasket is fine at sensible boost levels. I went metal intake and exhaust gaskets but I reckon it is a waste of money.
Good luck.
I've done a few. There are a few extra things that can be done to improve the basic engine.
GTR rods are recommended. Get them sized (if necessary) and crack tested by the machine shop. Should be under $300 for a set.
Get the crank checked for straight by the shop, and get them to supply the bearings. Plastiguaging can be easily mucked up but they do it all the time.
If you intend running high rpm/power or at the track then get the front oil feed blocked to reduce oil to the head. Oil can build up in the head and assist with starving the pickup -> bearings can go. Also think about a sump baffle if you intend to track it as well.
O ring the block as well so the stock gasket can take a significant power increase. Works out less than metal head gaskets.
Get a full balance.
Good luck
Thanks for the info.. I'v e been speaking to a guy from a place called "Salibro or Salibo Engines". He has been extremely helpful and sound like he knows what he is doing.. I'm going to take the block to him and get him to do everything that needs to be done... ie... torque plate boring, honing, dynamic balancing, square decking and much more.. He mentioned something about him doing the bearings but he lost me there..! He was going to do something with them so that they would be 100% reliable when we put the engine back together...
Does anyone know how much the block will have to be bored for a 1st rebuild? I'm guesing that 20thou will be enough.. I can get a set or Aries pistons, rings, etc for $1080... but should I wait until the guy has checked out the block before I go buying the pistons just in case he needs to bore it out more then 20thou?
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
