ok peoples
I've always been curious as to this after reading peoples upgrades/mods etc etc
Lets say you have 2 turbo's. Ones a big one.. the others a small one...
Now lets say there both running 14psi or something..
If they both go into the exact same car how is it possible one turbo will make more power than the other if there both running the exact same boost level ???
I understand that the smaller one will make boost earlier.. and the larger one would hold the boost stronger.. i guess.. but I dont understand how 14psi from one turbo makes more power than 14psi from another turbo ???
14psi from 1 turbo would be the same volume of air as 14psi from a smaller turbo right???
hmmmmm
thanks :mellow:
https://www.sau.com.au/forums/topic/93825-turbos-output-power-hmmm/
pressure does not equal volume. 35psi in car tyre is not the same amount of air of a truck tyre at 35psi. the bigger turbo will make more power as its exhaust housing is bigger, thus it can flow more air making the engine more efficient at the same base manifold pressure (boost)
this is my impression im sure other will correct me if im wrong. a small turbo will hit boots at low rpm but the boost trails off and becomes lower at higher rpm. so at 2k you might be at 14 psi but at 6k it might have fallen to about 10ish. a larger turbo will hold the psi for much longer.
oooh ok i think i get it now thanks :mellow:
so like.. if you attached e.g a balloon to both turbo's there both filling it with 14psi, but the larger turbo would fill the balloon quicker ???
ok peoples
Lets say you have 2 turbo's ones a big one.. the others a small one...
The easiest answer is 'RPM'.
Power = Torque x RPM / (some factor > 1)
Assume that both turbos can make their boost target at some point in the engine's RPM range,
and that the smaller one cannot hold 14psi to redline.
Assume they both make the same torque for the same airflow - the one that can hold that
same airflow (torque) to a higher RPM will make more power according to the formula. So if
the smaller turbo can't hold it's 14psi as high in the rev range as the larger one, that's less power.
The next easiest answer is 'efficiency'.
Assume that the smaller turbo _can_ hold the 14psi to redline, but that it's well out of
its efficiency island. That is, that the air comes out of it much hotter than out of the large one.
All other things being equal, the hotter air has less oxygen to burn - meaning less torque
at the _same_ 14psi and the _same_ RPM. According to the formula, that's less power.
_edit_
As pointed out by PaulR33, the turbo itself is a restriction (like a muffler). A larger turbo
should offer a lower restriction at the same RPM, thus allowing more airflow for a given
input pressure. More airflow == more torque at the same RPM, so that's more power.
I'm sure that others can express this better than me or correct deficiencies :mellow:
Regards,
Saliya
Edited by saliya
psi means nothing. airflow makes power not psi
boost is a reistriction to air. decrease the restriction, ie bigger exhaust, bigger dump, bigger cat, bigger exhaust housing the lesser the resitriction, the more air, the power. at the same psi boost level. this is because there is less restriction
I think you mean 'boost is a measure of restriction' (the way I say it is 'boost is a function of
the engine's inability to deal with airflow). And I agree, it's airflow (not a given pressure) that
results in the ability to burn fuel and make torque.
But on the same motor, the restrictions should be the same (with the exception of the
turbo itself). He's not talking about changing other properties of the system to
permit more airflow at the same boost level...
Regards,
Saliya
an engine is just one big air pump... Bigger pipes... bigger pump (turbo) at the same pressure means more air is going to flow through it...
You can blow 14psi through a straw you know... Or you can blow 14psi through a 10 inch pipe.. Which one is going to let more air through?
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
