cruises in Melb.
Guest JapCrazyImports
The ones you are seeing at westall road arent an import or MCCR group. It sjust a bunch of hoons out for illegal drags. You're right but the cops have hit hard - best bet is to stay away. If you do go be careful unmarked cars travel in the pack as well as them sending coppers in their own hotted up cars. they take down number plates and then call you in for a full roady at a time of their choice ($1000 fine for failing to comply).
https://www.sau.com.au/forums/topic/9384-cruises-in-melb/#findComment-141746
half the MCCR ppl are hoons what are u talking about.
https://www.sau.com.au/forums/topic/9384-cruises-in-melb/#findComment-141760
not much to drag for u being in a calibra lol
altho thats probably why u hang out with the MCCR crew and all the Daihatsus, mirages with neons and old civic sedans with fugly decals on the paint
lmao j/k
https://www.sau.com.au/forums/topic/9384-cruises-in-melb/#findComment-141854
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
