cruises in Melb.
Guest JapCrazyImports
u know what shits me..
wen u get poofs in xr6's doin that
and they just dont give up
they accelrate and stop again and again
so u say ok fair enough
teach time. u dump and u teach them a leason.. a pretty hard one as well
and when they catch up they wanna do it all again.,..
some people never learn..
im sure you'll eat those words when the new xr6t hooks up next to you :)
Originally posted by pushead
I want to rewire the brakelight to a switch so if you get ****heads tailgating you, flick it on, they will definitely brake hard!
hehehe my old daewoo had a rear fog light switch.... i used to love it when ppl tailgated me (not for dragging puposes lol) cause id hit it and u just watch them drop back as i keep doing the same speed hahaha
Meggala - you're not that old! well maybe compared to a lot of people on here i guess you're not young but :D
Then again jet33 i think was referring to those 50+ year olds that drive an XR6, HSV, or whatever else mainly just for the status symbol and never push it.
Wait for 5-10 years and every 20 year old will have one - then watch out :)
Talking about XR6's i had my first run with a new XR6 turbo last night down princess highway in Dande!
I pulled up at the lights behind him near dande and kept flashing him tellin him i wanted to race, lights went green we both went, i pulled up next to him and he gunned it i gunned it and i preety much pulled away quite easily about 3-4 cars to 160 click, then i slowed down till he came again and then he gunned it again and caught me in 3rd gear at 60 click, i went back to 2nd caught him and as i started to pull away he slowed down, we did this about 4 times and eveytime i started to pull away he slowed down, the pu*ssy!
Couldnt see who the driver was as he had dark tint.
Conclusion new XR6 turbo aint the best thing since sliced bread, as every1 has been bragging about!
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
