Hey ppl
since I had my JAP made 3 1/4 inch exhast system put back on after driving around with a stocky system for 2 weeks, I notice now massive backfire on every gear change, every time. I put on a XForce mildsteel 3" Hi Flow cat converter onto my current system (the 3 1/4 one), could this be y the backfire is so more common now, due to a shit cat converter?
https://www.sau.com.au/forums/topic/93867-backfire/
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
    • Excellent...maybe even instead of RB rebuild start with 6L LS and add boost for good measure!
    • This sounds do-able except space is a little tight were it's currently sitting. How many metres you reckon it would need to go?
