Rb26 Turbo Upgrade, All Dyno Results
SLY33
R32 GT-R
R34 GT-R ball bearing turbos, 12psi boost
550cc injectors
Remapped stock computer
3.5' Exhhaust
HKS front pipes...with a little stupid cat
Stock dumps
Stock airbox
Stock inturnals
made 204.3 4wkw's...i will post up the dyno graph when i can get it scanned or a foto of it!
i will get another dyno after i have my engine rebuilt and throw the power fc on and bump up the boost to 14-15psi!! hoping to get 230 4wkw's, atleast!!
26/4/07
had the rebuild done. made 175rwkw's on 9psi. dunno where the power went. nore the boost
currently running 239.8rwkw's on 14psi. (about 321rwhp)
new mods:
Trust pods
Haltech e11v2
Cam Gears, still set at zero at the moment.
they believe i have steel wheel turbos on but not too keen to run too much boost until i am certain for my self that they are steel wheeled, then if they are im gonna throw it up to 18-19psi.
Edited by Turbz_13
R32 GT-R
Power FC
Nismo AFM's
13.5 PSI on bleed valve (since dyno has been replaced with Blitz DSBC Spec-r)
Big HKS FMIC
3" cat back
Punch through CAT
Stock everything else
226.6 rwkw
I've got some HKS GT2530 in the mail, and had HKS adj cam gears fitted today. Once the new huffers go on it'll be another trip to the dyno.
Guest Mashrock
32 Gtr
R34 N1 turbos .42 front (14411-AA403)
N1 Pistons ? or aftermarket
Tomei cams
Veilside exhaust
Standard dumps
Hks Fcon pro v
Greddy Profec a
1.4 bar
No meow
Arc cooler
Hks cooler pipes and cross pipe kit?
Not holding boost. drops to around 10 pound at around 5000.. too rich.. but this is just a base untill its holding boost and tuned.
Edited by Mashrock
89 gtr.
195000ks 315.6awkw
t04z on 1.2bar
autronic smc/cdi
engine is un-opened dead stock just the turbs bolted on.
044,bosch 363 injectors. 3 inch exaust, trust front mount yada yada...
left dyno sheet at work. will edit it in later :
90 R32 GT-R
138'000ks unopened
R34 N1's, PFC, Dual SBC, a/m exhuast & dumps, filters
401 rwhp @ 1.4bar on Top Racing dyno, backed out due to old engine
No idea where dyno sheet is - but N I B will vouch (as he tuned it)
Edited by gun-r32
Ok, my turn......
Built by Race Pace Motorsport:
Fully prepped block, crank & rods
Ported & polished head
88mm HKS Pistons
Tomei Cams 260 Duration 9.15mm Lift
STR Adj. Cam Gears
Z32 AFM x 2 w/Apexi Super Suction kit to suit
HKS 2530's
HKS Heavy Duty Actuators
Split Dump Pipes
3&1/2" exhaust
Hi flow catalytic converter
660cc Injectors
N1 Water & Oil Pumps
Apexi Power FC
Power is a fuel pump limited 343kw(460Hp)@rear wheels. I'm currently making a 2lt Surge Tank with Bosch 044 pump. With the fuel pump upgrade, I'm hoping for 375kw(500hp).
Edited by yug_r34
1994 R32GTR
stock internals
N1 turbo's
custom manifolds
HKS dump pipes
3 1/2 " exhaust
carbon cannon muffler
high flow intercooler 600x300x90 tilbrook special {american}
HKS pipes
apexi power fc
standard injectors
running 1.1bar boost
no detonation or leaning of injectors
car made 292rwkw's.
have heard with boost controller turbos can run 1.4 bar safely but might need to upgrade injectors and rail etc. :)
160,000k's orig
peter hall from willall racing will be able to verify dyno run.
Edited by savage GTR
1999 Autech 260RS
All usual strengthening mods. Noted ones for power:
Tomei 260 IN/EX 9.15 lift cams
HKS Extractor Manifold
APEX'i 92mm exhaust
Trust 600*300*125mm core FMIC
HKS T04z turbo
HKS slide cam pulleys
HKS F-CON V Pro
HKS Filter
390.7 kW @ 4 wheels (~=675HP @ flywheel)
  • 3 weeks later...
1992 R32 GTR
All work done by previous owner, i havent touched a thing.
2.7Litre JUN engine with 264 degree cams and cam gears
HKS 2540's
HKS exhaust system, including HKS split dump pipes
Sard 700cc?/720cc? Injecters and Bosch motorsport pump, Malpassi FPR
Apexi Drag IC
K&N PODS
APEXI PFC
300ZX AFMS
Made 357KW @ ALL4WHEELS ON CRD DYNO @ 18PSI
Edited by mazgtr
11 months later… finally got my R32 back from major works…
Engine built by AE Automotive
Tune by Ben @ Racepace
T78
Forged 87mm pistons
New rods, bolts, valve guides, bearings and so on (assortment of aftermarket and standard parts)
Apexi Power FC (Tuned by Ben @ Racepace)
4" Exhaust + dump pipe
Trust FMIC
HKS Oil Cooler
Standard CAM's
660cc injectors
New oil pump (standard Nissan)
Afms (Z32)
367.9kw (RW Only)
96 GTR V-spec
Power FC tuned by www.speedworks.com.au
JUN racing valve springs
JUN high lift camshafts In 256 / Ex 264
Sard 700cc injectors
044 fuel pump
K&N Air pods
2 x Z32 air flow meters
Garrett bolt on replacement turbos
Custom dumps / full 3 inch exhaust
Running on BP98 = 470hp@all 4, Running on VP109 = 520hp@all 4, always at 1 Bar
Everything else standard, un-opened motor
R32 GTR
Garret T04Z .70 front 1 rear peaked at 21 psi
engine 40 thou over size
JE pistons, stock rods and crank.
ACL metal headgasket, race bearings
ARP rod bolts, head stud kit
N1 oil and water pump
tomei poncams 260 9.15
stock cam gears and AFM's
800cc SARD injectors on stock rail
3.5inch exhaust with magic catalytic converter
044 pump with stock fuel pressure regulator
split fire coils
403 awkw 541 awhp
comes on hard at 4- 4500RPM but starts pulling about 3000RPM
(will add dyno sheet as soon as i fix my stupid scanner)
As per the graph, max power is 578 hp at the rear wheels. This is an improvement of 37 hp on the same dyno by fitting a 272IN cam (previous 264) and spending dyno time optimising cam timing.
Setup is:
N1 block
HKS 2.8L crank
Nismo bearings
Pauter rods
ATI crank damper
HKS nickel coated pistons
GT-RS low mounts at 25 psi
HKS bridged manifold
HKS hard piping induction kit
Apexi 136mm IC
Greddy plenum
HKS fuel rail (twin entry, single return)
HKS fuel regulator
HKS 680 injectors
Nismo intank fuel pump (direct power feed)
HKS step 2 cams (272IN, 272EX)
HKS guides, springs and retainers
HKS timing belt
HKS cam gears
HKS metal head gasket
Ported head
Trust oil pump
N1 water pump
HKS dumps, pipes and exhaust
PFC D-Jetro
Blitz dual solenoid BC
Splitfire coils
HKS Twin Power CDI
HKS twin plate clutch
GTS4 diff centres front and rear (shorter ratio than GT-R)
Edited by Gav
Rb26det in R32 GTS4 sedan
Precision turbo PT67gtq with .68 rear changin to .81 (non bally)
apexi d-jetro tuned by Ant @ x-speed
87mm venolias. changing to arias
tomei 270deg cams with 10.8 lift
tomei springs and retainers
head has been ported and hks guides
hks head gasket
N1 water pump
tomei cam gears
greddy 720 injs
hks fuel rail
sard fuel regulator
sard fuel cell with 2x sard pumps
rev rods soon to be eagles
greddy oil pump
tomei sump baffle kit and cam covers kit
572rwhp @ 22psi
ran 10.98 @ 130mph on 1/4 mile
engine is out for for for changes hopefully more hp to come
Edited by GOT BOOST
just picked up my new GTR
1992 GTR
1000cc injectors
3X bosch fuel pumps
Standard plenum
re-ground standard cams
ARP rods
unknown pistons
T51R SPL BB turbo
AP racing Triple place clutch
Autronic computer X2
re built standard gearbox
AFR btween 12 and 13
last dyno:
631.3 ft/lb torque
578 kw at all 4
775.2 hp at all 4
that was running 2bar
dyno sheets to follow when i get scanner working
R32 GTR rebuilt engine with all the usual support mods etc etc
Airflow improvements:
Tomei cams 260/260 9.2mm lift
HKS cam gears set at zero/zero at the moment...
HKS GT-SS turboes with HKS split dumps HKS Super Drager exhuast system with no cat
Greedy inlet piping kit
8.8:1 compression
0.5mm over forgies
PFC computor tuned with FC Datalogit by myself > awesome software a must have!
Boost running on the 12psi wastegates boost controller turned off
257rwkw on a dyno dynamics 2wd dyno on pump gas 95 octane at 12psi boost
Will post dyno graphs very soon
cheers,
Mike
UPDATE:
boost increased up to 18 psi and made 290rwkw. Boost dropping off though at 6000rpm onwards.
Made 324rwkw on av-gas in another car at 22psi. Pretty much at their max at this level.
Edited by The Alchemist
Hi people,
Just got my GTR
1990 R32 GTR
Mods Include
Engine/Performance
Trust T517Z x 2 with custom polished Greddy piping
Tomei 268 cams
Custom blue cam covers
Custom blue intake plenum
Custom blue cambelt cover
HKS cam gears
Trust belt
Trust oil cooler and relocation kit with braided lines
Trust drag intercooler
Z32 80mm AFM's
N1 water pump
N1 oil pump
Trust blow off valves
Trust radiator
HKS pod filters
Apexi Power FC
Blitz boost controller-SBC iD 111
Greddy turbo timer
Greddy Iridium plugs-cold #7
Split fire coil packs
HKS 600cc Injectors
Nismo fuel pump
Sard fuel pressure reg
CES race dump pipes
CES full 3.5 in open race exhaust
OS Giken triple plate clutch
OS Giken Cross Mission Gears
Nismo diffs 2 way
301kw@all wheels with 0.9bar
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
