After a year and a half of my power FC sititng around in my attic, i finally got soichi to install and tune it.
Specs.
R33 GTR
Mods :
Forged internals - unknown brand
HKS Split Dump Pipes
Trust Front Pipe
Custom bent 3" tripple muffler exhaust
Tomei Adjustable intake and exhaust cams
Blitz heat range 8 racing spark plug
Dual urathane Pod Filters
Trust 100mm thick intercooler
Trust 9 row oil cooler
Apexi Boost controller Kit
Apexi Power FC with Commander
Everything else is stock
Turbos, fuel pump, injectors etc..
Power went up from 183 awkw to 264awkw
Questions
my intake air temp is getting to 40c-45c degrees , is that normal.
other power fc users, what is your water and air temp reading?
1997 R33 GTR (Series 3):
Tuned by DYNO TUNZ (Browns Plains, Bris, QLD) for mid-range power.
Garrett 2 x 2860R-5(HKS 2530 Equivalents)
HKS Adjustable Actuators
Tomei Dumps Pipes
Stock Manifolds
HKS twin 2.5inch exhaust (twin 2.5s from dump back)
Tomei Poncams (260degree, 9.15 lift)
Top Secret Adjustable CamGears
SARD 650cc Injectors
SARD Fuel Pressure Regulator
NGK IRITOP7 Spark Plugs
Walbro 341 (255L/hr) fuel pump
Greddy/Trust Oil Cooler & Relocator
Apexi twin Pod filters (stock afm)
Power FC D-Jetro
HKS EVC (V5)
@ 4 Wheels
Low Boost: Max Power 261.4Kw @ 14.9PSI
High Boost: Max Power 292.1Kw @ 20PSI
R32 GTR
Standard internals
HKS GT-SS turbos
opened up exhaust manifolds
sard 700cc injectors flowed to 780cc
HKS hard piping kit
HKS inlet pod filters
Tomei Fuel pump
Nismo NE-1 exhaust with twin cats
Bigger cooler (not labelled, came with the car)
Power F-C tuned by unigroup
Greddy Profec b spec 2
all tuned to 16psi as air flow meters maxing out
287kW
Getting z32 afms next week and tuning to 20psi, aiming over 300kw
Will post both dynosheets after I get it back
  • 3 weeks later...
R34 GTR NUR 2002
Mileage:15,000kms
Mods:
Stock engine internals
Stock N1 turbos with HKS actuators
Apexi Power FC
Nismo Z Tune intercooler
Nismo air duct
Nismo hard piping kit
K&N High flow air filter in stock air box
Racepace custom front pipe and cat back exhaust
Tuning by the renowned Ben@Racepace
Output at the Rear Wheels: 334.9kW
An Update.
17 n a bit psi and a little bit more time on the dyno.
Cheers ANDY !!
RPM scale is prob 200-300 rpm out as limiter is 7800 not 8000 ish.
Still stock internal unknown km engine with stock cams n etc.
I love these motors :)
FAT GTR
2.6L
Eagle rods
CP pistons
262 Tomei cams
Fantasy manifold
Single Billet Z-P turbo
Custom Fantasy Intercooler
Apexi Power FC
505 awhp @ 23psi
http://www.youtube.com/watch?v=EtN6bFMPD60&NR=1
Dyno Graph for FAT GTR
Billet Z-P turbo with 1.06 A/R open exhaust housing.
stock nismo R1 (v-spec ii with R1 conversion), out of the box untuned.
It appears to be boosting late, and in a bit of a rush.. (1.1 bar).
so a nur engine with hard pipes, modified intake
box inc cold air intake, a slightly different cam, plus a weldina
exhaust and nismo ECU. (and various other bits largely unrelated
to performance).
just had all this stuff fitted, so a light tune, advised to drive for a a while then run it up again and crank up the boost etc.
1997 R33 GTR
standard bottom end GENUINE 58,250
Tomei pon cams type B 260,260,9.15, adjustable gears, cam cup stud kit.
HKS fuel pump (I did have adjustable HKS regulator but Xspeed changed it to a Nismo one??)
HKS racing chamber kit
Mines stainless pro front
decat
Kakimoto Mega 3.5 cat back
HKS extension kit.
HKS GTSS
Tomei manifolds
Sard 700's
evc 6 AT 17.1 psi
PFC djetro
splitfires
I think that is about it for relevant mods - 380 RWHP, ill post up graph asap.
I am hoping for this figure to increase when it goes back in!
Not Really a turbo upgrade cause it's how the car came. But is an upgrade over a standard 32 GTR
1992 R32 N1 GTR
M's Pods
Unknown Brand Front Mount cooler
Veilside Exhaust
Greddy Profec B II Boost Controller
Nistune ECU
16PSI - 276.5 rwkw.
Did it quite comfortably but the stock AFM's were maxing out. Very smooth power curve, peak power coming on at around 7000rpm.
No idea if the turbo's are N1's or whats inside the motor. Will try and post up the dyno graph tonight.
Cheers
Bobby
95' GTR V-SPEC
Apexi Power FC & Commander
3.5" Exhaust (straight through) front pipe etc.
Split Dump Pipes
Bosch 044 Fuel pump
Stainless exhaust manifolds
Pod filter
HSD HR Coilovers
Blitz 700cc Injectors
Head Gasket & Studs replaced
Greddy profec-b booost controller
Ogura Twin Plate clutch
Hicas lockout bar
Trust cam gears
Garret 2680-7 Turbos
320KW @ 20PSI
One of the oil returns from the turbo is rooted though so my fun is temporarily at an end :(. Next on the list is complete rebuild & stroke. Try push the -7's to their limits... Car was tuned for torque. If you're up it enough in 1/2 it starts to lose traction when boost comes on (well you feel it wobble around a bit). 265 tires too.
Til' next time!
Spec:
R34 GTR
Mods:
HKS 2530
Trust-Greddy SPEC-R HG Type 23 H302/L600/W115mm 3Layer
ATS Type S Twin Carbon Plate
PowerFC
Sard 800cc injectors
Sard Fuel Pressure Regulator
Apexi Suction Kit - Z32 80mm
HKS Actuators
Sard Fuel Rail
Trust Piping
HKS Cam Gears
HKS Timing Belt
Z32 AFM
Kakimoto Hyper Mega Full 2000 Premium (3.5" Front Pipe, 3.5" Catback)
HKS Dump Pipes
Xforce 3.5" Cat (Knocked Out)
Tomei PonCams TypeB 260in/260ex 9.15mm Lift
Sard Surge Tank
Bosch 023 Fuel Pump
350.2awkw @ 20psi, exhaust leak hence the shake at the top of the dyno. Will fix this weekend and retune next week.
Edited by destrukshn
ok iv had my R32 GTR for 3 weeks now and bought a E11 V2 haltech,front pipe for it.
the mods for the car stand at
haltech ecu
s/s front pipe,3" all the way with one big resonator and a jap spec muffler at the back9system is not perfect by any margine and still runs the compliance cat
apexi suction kit(still runs the air flow metres(disconected)
cooper plugs
exedy h/d clutch
profect b boost controler running 14psi
the car also runs 20"x10" wide which i was told isnt to power friendly.
this is about it,the car made 293.4 HP
the machanic who is justin at CTP qld said the motor probably isnt standand as they dont make that power.
i cant thank justin enough for the work he did and will be using him again....thanks mate
1994 R32 GTR VSpecII.
Stock engine
Stock Turbos
Full Kakimoto Exhaust
Nismo Twin Plate Clutch
K&N Stock airbox
NGK coppers BCPR7ES
Stock boost control solenoid
NISTune Remapped ECU
240.2 RWKW @ 6654 RPM, 388.9 Nm @ 4801 RPM on 14 psi @ Status Tuning
Will post sheets up later
I know this is for upgrades but i thought id post mine just for comparission sake
cars a 90 r32 gtr mods-
-nismo fuel pump
-splitfire coils
-catback (that was already on the car)
everything else stock including boost car made 175kw at ISmotor racing
R32 GTS4 with R33 GTR motor
GT2860-5's
HKS dumps heat wraped
custom made front pipes with hi flow cat and 3 1/2 inch zorst
XTR 100mm front mount
sard 700's
Nismo pump
match ported manifolds to turbo's
Power FC D-jectro
standard air flow meters with internals removed
K&N pods
316rwkw (423.8rwhp) @ 18psi
Edited by DSTROY
