Rb26 Turbo Upgrade, All Dyno Results
SLY33
this is the engine that Allan (SLY33) built after he started this thread, mine now :) just had a very conservative tune at 18psi and made 526rwhp, will turn it back up to 25psi soon and repost results..
HKS step2 2.8 stroker, full counter crank and rods kit, CP pistons.
Brand new head from Nissan, Jun 272 in and ex cams, 10.8mm(?) lift, special retainers and all the jazz needed to support the cams and high revs, heads extensively ported.
Big dollar hypertune plenum and single throttle body setup
Custom alloy breather tank etc
Jun oil pump, N1 water pump, cant recall the brand of balancer, but its a good one.
Trust sump extension.
Turbonetics GTK-850 turbo and big Turbonetics external gate
OS Giken 2 way front diff
OS Giken cross mission 5spd gearset with input shaft 800+hp rated, quick shift kit
OS Giken triple plate clutch 800+hp rated
Carbon fibre super lightweight tailshaft (not currently fitted)
ATTESSA system fully inspected with all fluids changed
V-Spec active rear diff
engine made 760HP on engine dyno at ~25psi with screamer pipe
Current street setup with wastegate plumbed back into HKS 4inch exhaust
Huge alloy radiator, disgustingly thick Trust intercooler.
Fuel system to cater for 1000hp, in boot setup as in pics,
1000cc HKS injectors,
HKS fuel rail,
splitfire coilpacks
Motec M800 ECU
  • 4 weeks later...
R32 GTR
pod filters (do they actually add any power???)
cat back exhaust (3" one muffler)
10 psi boost - stock turbos
other wise completely stock
206kw atw More than I expected.
93 R32 GTR
M's pod air filters
stainless steel front pipes
3" x-force hi-flow cat
3" HKS Legal cat back exhaust
profec b @ 14psi
205kw @ four wheels (mainline dyno @ Boost Bitz dyno day today)
forgot to ad:
180km/h @ 6020rpm (stupid standard ecu speed cut) still had 1500rpm's in her ;)
time for an aftermarket ECU
My R32 made 222.6kw at all 4 on RE Customs dyno at the last dyno night.
Mods:
Boost restrictor removed - (Running 1Bar)
3in Fujitsubo Jasma Catback
De-Cat
Nismo Computer
Updated tune. Degreed cams. 3 degree intake and 10 degree exhaust correction expanded torque curve like a balloon. Torque comes on 200-300 rpm earlier, bumps peak from 330 ft.lb (445 Nm) up to 425 ft.lbs (575 Nm), and drops off less at 7500 rpm.
Power at the wheels on a DynaPack 4 wheel dyno bumps from 390 WHP (290 kW) to 527 AWHP (393 kW) at 17.5 psi on my boost gauge and 16.5 psi (corrected for atm conditions) on the dyno.
Setup is:
VEHICLE: 1989 GT-R
ENGINE: RB26DETT, 88mm bore, CR=8.7:1
MILEAGE: 20,000 Kms or so on engine
OIL/WATER PUMP: Nismo/OEM
OILING SYSTEM: Tomei Orifice, Tomei pan baffle, Greddy oil cooler and filter relocation
INJECTORS: 600cc Nismo
FUEL SYSTEM: Bosche 044 in-tank
TURBO SETUP: twin GT2860R-5
MAP or MAF's: MAP
INTAKE SETUP: Apexi Power intake, HKS hardpipes
INTERCOOLER: HKS
VALVETRAIN: JUN 264/264 9.7 mm lift - adjustable gears - Timing set to JUN spec
HEAD WORK: Intake mildly ported and left rough, exhaust opened up about 15% and polished, combustion chamber polished
EXHAUST: HKS dumps, Tomei DP, 85 mm HKS Priest
BOOST LEVEL: 1.2 bar = 17.5 psi - Blitz Dual SBC Type R
ECU SETUP: ViPEC Speed Density
  • 4 weeks later...
Just replaced stock turbos with -5s. wasnt a planned upgrade so the car is still mostly stock engine wise.
Car: '97 R33 GTR Vspec
Mods:
GT2860R-5 x2
Blitz Nur Spec front pipe
De-cat
Tanabe 3" cat-back
Apexi pods
Hard piping kit
Car is all stock apart from that, still running stock boost too. tried removing the restrictor but then the fuel pump was getting maxed out so leaving it in til i get the chance to do some more supporting mods.
now makes 255.8rwkw
  • 3 weeks later...
95 R33 GTR
fresh 26 from 260RS
120,000kms
Nismo fuel pump
sard 700cc injectors
Trust drag cooler
Garrett 2871-10 turbos (GT-RS)
HKS dumps, JJR front pipes, decat, and Kakimoto exhaust
Apexi pods
powerFC
333.7rwkw @ 18.5psi
Freshly Rebuilt RB26
VEHICLE: 1989 GT-R
ENGINE: RB26DETT
MILEAGE: About 1500km on the engine
OIL/WATER PUMP: Billet gears in Stock housing/N1
OILING SYSTEM: Tomei pan baffle and restrictors to the head
INJECTORS: 700cc Sard
FUEL SYSTEM: Unknown in-tank
TURBO SETUP: twin HKS2510
MAP or MAF's: MAF
INTERCOOLER: ARC
VALVETRAIN: Tomei Poncams and adjustable gears
HEAD WORK: Lightly ported
EXHAUST: Greddy 'extension' kit and then 3.5 inch straight through to some generic cannon
BOOST LEVEL: 17psi
ECU SETUP: Power FC with z32 AFMs
POWER: 301kw
will post up graph when i get it!
Hi all,
Couple of people have PM'd me asking me to put up the dyno sheet.
R33 GT-R.
HKS GT-SS
Apexi Power FC
HKS 3" front pipe
3" Gutted cat
3.5" HKS cat-back exhaust
HKS pod filters
302rwkw at 18.6psi (controlled by HKS actuators, no boost controller).
I reckon I could go further, just need fuel pump, injectors, Nismo AFM and boost controller.
Hope these are much of a help in your turbo selection.
Freshly Rebuilt RB27
VEHICLE: 2000 R34 GTR
ENGINE: RB27DETT - Nitto RB27 Stroker Kit with Nitto I-Beam Rods, Nitto Billet Full Counter Crank & Pistons
MILEAGE: About 300km on the engine
OIL/WATER PUMP: Nitto Oil Pump, N1 water
OILING SYSTEM: 9L Sump, sump breather, baffles, restrictors to the head
INJECTORS: ID2000cc x 6
FUEL SYSTEM: 2x Magnafuel protuner 750 pumps, sard lift pump
TURBO SETUP: Garrett GT4718R
MAP or MAF's: MAP
INTAKE SETUP: K&N Pod
INTERCOOLER: Apexi 150mm thick
VALVETRAIN: Tomei Type C springs, oversize valves, custom cams
HEAD WORK: Extensive portwork
EXHAUST: 5" Dump pipe, 4" cat back, 4" oval muffler, 4" cannon muffler
BOOST LEVEL: ~35psi
FUEL: Sucrogen (CSR) E85 (108 octane)
ECU SETUP: Autronic SM4, Autronic CDI
POWER: 1014hp @ rears, 970hp @ 4 wheels.
Tuned By Mercury Motorsport
http://www.youtube.com/watch?v=Cx__4Y4rIB8
Edited by NITTO R34
R32 GTR RB26DETT ON E85 TUNED BY JEM 380KW (500HP) 950NM TORQUE ATW,
HKS 2530 TURBOS,
3"EXHAUST,
APEXI POWER FC,
STANDARD INTERNALS,
STANDARD R34 INTERCOOLER, STANDARD PIPES,
STANDARD EXHAUST MANIFOLDS, STANDARD PLENUM,
STANADRD INTAKE PIPES,
RB20 AFM'S,
DRIFT STAINLESS AIR FILTERS,
http://www.youtube.com/user/GM45TR
1995 R33 GTR - 81,000kms
Unopened motor.
Garrett GT2860R-7 Turbos
Adjustable Actuators
16psi - a VERY safe tune to preserve engine life.
Apexi super suction kit.
Blitz FMIC
Full 3" titanium exhaust
New spark plugs
Oil cooler + catch can
Power FC + Hand Controller
Adjustable Cam Gears
284.8rwkw - which is somewhere around the 260awkw mark.
Makes full boost around 4000 rpm, and sounds incredible. No turbo kick, just smooth increase in power all the way, great for all types of driving.
Would highly recommend this setup to anyone with a budget.
Thanks to the guys at Racepace, Bayswater VIC
Edited by ash-s13
R32 GTR
ENGINE
built engine
stage 2 hks 272 cams
hks cam gears
TO4Z Garrett
6 boost
48mm turbo smart gate
twin z32 afms
fuel system
sx fuel pump
1450 fuel injector clinic
sard reg
tried running 60% methanol 40% bp 98
managed to pull 560hp at 1.5bar until fuel system ran out of puff, spewin i wanted to wind it up too 26psi. it ran 527 at the same boost on pump but the car does feel stronger through the middle now
will finish of this drum off methanol and give either e85 or a e50/e70 tune a go
Just had another tune, heres the set-up
ATI balancer
Garrett TO4Z .84 rear, turbo and big Turbonetics external gate
HKS fuel rail,
splitfire coilpacks
Motec M800 ECU
@ 25psi made 680awhp on a hub dyno (so probably about that at rwhp ? ) what ever it is it comes on hard,
300rwkw r32 gtr
hks t04z turbo straight throught 3" exhaust
660cc injectors
nitto oil pump
forged pistons
040 fuel pump
intercooling and piping
apexi afc neo
15 psi boost
maxed my fuel pump am getting new one and 3.5" exhaust soon then will pump it up to 20 psi should start making some good numbers then :D
1989 r32 gtr
Fresh built motor with forged bottom end and r33/34 crank.
r33 N1 turbos (Rebuilt)
N1 oil pump
N1 water pump
Sump baffle
aftermarket front pipes
3 inch exhaust
Power FC
1.5 bar boost
313rwkw
ATI balancer
HKS fuel rail,
splitfire coilpacks
Motec M800 ECU
ok heres the latest,
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
