R34 GTR
Stock turbos
Power fc
OBX front pipes
100 cel venom cat
Apexi N1 GT cat back
nismo panel filter
Blitz spec r boost controller
Splitfire coils
Made 243kw at all fours
17psi dropping back to 16psi
Now 256kw, much cleaner tune thanks to GT Auto Garage
Updated in BOLD
1995 R33 GTR
Performance list:
garrett 2860 -7 running 20psi drops to 19psi
tomei dump pipes
trust front pipe
ballistic cat
nismo catback
1000cc injectors
splitfire coilpacks
bosch 044 fuel pump
haltech platinum pro (mafless tune)
bp ultimate 98
115 Greddy front mount intercooler and piping kit
Greddy air intake kit
280awkw at 19psi
Now 310awkw
300wKw at 20psi on 98RON
R34 GT-R V-Spec II
* -7 Turbos
* 700cc Denso Inj
* Power FC D-Jetro
* Blitz front pipe
* K & N Panel filter
* Greddy DSBC
* Tomei Poncams 260/10.25
* Tomei Cam Gears
* Bosch 044 fuel pump
* Nismo 3" Exhaust
* Hi Flo Cat
Now with 3.5" Kakimoto exhaust
Heya all :)
318kw
Specs:
80000 km old RB26 with 135-140psi compression and already done a Targa Tassie before I got it.
-7s on std dumps
Noname 3" exhaust with hiflow cat
Yellow Jacket coils on copper plugs
Cam gears on std cams
Nismo 550 injectors
19psi
98RON juice
Haltech Platinum Pro w/boost control tuned by HITman (MAP tune, although MAFs were still plumbed up to standard airbox)
Shitloads of blowby!! One 15min session at Wakefield dumped well over 500ml of oil.
Matty (HITman) made this power with the standard airbox, MAFs and snorkel in place. When the airbox was cracked open and a screwdriver handle jammed in there, he saw past 330kw. There's a brand new filter element in there, so contrary to what I've read, my standard airbox was definitely a restriction. Now I just have to bandaid the blowby issue, remove the standard pre-turbo plumbing (MAFs and airbox) and see how long this thing lasts! Hahahaa
This thing idles at 1100rpm on the dot, drives like an EcoTec V6 commo in traffic and will kick you in the nuts when told to. Mid corner throttle/power control is AWESOME and as you can see, the power is quite linear.
Definitely a shedload of fun on a very simple (read: cheap) setup.
HITman, 0417 259 391(Penrith, Sydney)
Mark :)
  • 4 weeks later...
1995 R33 GTR, Stock RB26
R34 N1 Turbos
Apex'i Intakes
Vipec ECU
Catback
Ceramic coated oem headers and turbo outlets
17 psi
383 awhp / 330 lb-ft
Going to upgrade fuel pump, injectors, fpr this winter, new coilpacks, maybe intercooler and fuel rail as well.
first update since owning car :D
1996 R33 VSpec LM Limited
stock turbos
Power FC
Apexi intakes
700cc power enterprise injectors
walbro 550hp fuel pump
HKS silent pro cat back with catco highflow cat
Tomei cam gears
GReddy PRofec B-spec2 boost controller
237awkw or 317awhp @12psi
1993 R32 GTR - 160psi compression across each cylinder
2860-7 turbos
r34 gtr dump pipes
trust front pipes
3" super hi flow cat
3.5" Fujitsubo power getter cat back
NIStune ecu
Sard 280lph fuel pump (14v power supply)
nismo 600cc injectors
Greddy cam gears
M's pod filters
profec b spec II
new coil packs with 7 heat range ngk copper plugs @ 1mm
tuned for midrange punch rather then outright power
low boost - 257rwkw @ 16psi
high boost - 295.3rwkw @ 19psi
  • 3 weeks later...
R32 GTR
ENGINE
built engine
stage 2 hks 272 cams
hks cam gears
TO4Z Garrett
6 boost
48mm turbo smart gate
twin z32 afms
fuel system
sx fuel pump
1450 fuel injector clinic
sard reg
tried running 60% methanol 40% bp 98
managed to pull 560hp at 1.5bar until fuel system ran out of puff, spewin i wanted to wind it up too 26psi. it ran 527 at the same boost on pump but the car does feel stronger through the middle now
will finish of this drum off methanol and give either e85 or a e50/e70 tune a go
Update
630hp at 1.6bar.. e42.5
-Forged Pistons (wisco)
- Eagle rods
-tomei Metal head gasket
-tomei Oil pump
-ACL bearings
-New crank
-port and polish
-tomei head restictor
-tomei sump baffle
-New belts
-Engine Blue Printed
2860-5 Turbo's
nismo Fuel pump
700cc sard Injectors
Larger FMIC
HKS Adj Cam Gears (std cams only)
HKS pod filters
custom 2.5" twin exhaust
hks twin plate clutch
power fc
Z32 afms
running 24psi 381kws
* 2860-5 garrett turbos
* CP forged 86.5mm piston and rings
* Fully prepped block
* Nitto H-beam forged rods
* ACL 1.2mm metal head gasket
* Linished and balanced crankshaft
* Nismo main bearings
* Tomei main bolts and head studs
* Hi-Octane extended and baffled cast sump
* Nitto high-volume oil pump
* Nismo high-volume water pump
* Tomei oil restrictor
* Tomei dump pipes
* Tomei dual layer head gasket
* CRD custom catch can and washer bottle K&N extreme air filters
* HKS 272' 8.5mm inlet and exhaust cams
* HKS cam gears
* Gates timing belt
* 1000cc injectors on Tomei twin entry fuel rail
* Sard fuel regulator
* x2 Bosch 044 in tank pumps
* Splitfire coilpacks
* Haltech Platinum Pro ecu
* HKS EVC 5
* HKS turbo timer
* Nismo thermostat
* Powertune custom fuel intake kit
Exhaust/ Induction:
* Trust titanium cat-back 3.5inch exhaust
* CRD high flow cat
* Nismo weldina front pipe
* HKS 700mm x 302mm x 102mm FMIC
* Cusco oil cooler
(Running 25 Psi on E85)
Edited by Hiroshima Screamer
random breakage 26
gt35/.82 6boost kit
pwr cooler
d jetro
044 intank
700cc inj
stock head + crower v/s and ti retainers
432whp bp98 20psi
haha i got the exact same setup tuned on my car 2 days before you posted this..
Unopened rb26dett (115,000km)
tomei 260 9.15mm poncams type b
gt35 0.82 rear
6boost mani
tial 44mm w/g
700cc sards
stock rail
044 intake
tuned on BP98
485hp @ 20psi on a safe tune (at hubs)
full boost at 4300rpm, love it! shits all over my old twin setup in every way
thick line is gt35 + poncam tune, thin line is -7 tune
Apologies for the poor phone pic of my dyno graph!
Edited by snozzle
Just had my car tuned on Tuesday night
93' R32 GTR
HKS front pipes
HKS gutted 3" cat
HKS super dragged exhaust
HKS EVC 6
Power fc - tuned by steve knight @ skr
Unknown front mount
Unknown dumps
Unknown internals or anything else on the car
Made 244 awkw @13psi dropping off to 12psi actuators are bleeding off and full boost comes on late, any ideas what turbos these could be?
Unknown turbos
this is in my S13 silvia. 594 rwhp on 26psi.
R33 GTR motor
- CP forged pistons
- Eagle forged rods
- Tomei oil pump
- ARP main bolts
- ARP head studs
- ARP rod bolts
- N1 water pump
- 1.2mm oil restrictor
- acl race bearings
- Precision 6765 dual ball bearing turbo/billit front wheel
- precision 44mm wastegate
- custom steampipe exhaust manifold
- cometic metal head gasket
- complete cometic MLS gasket kit
- HKS cam gears
- trust 264/272 cams
- supertech valve springs
- supertech retainers
- motor fully blue printed/balanced/crack tested
- ATI 1000hp balancer
- LS1 coil packs
- 4" stainless dump pipe
- full 4" stainless straight through exhaust
- HKS tripple plate clutch
- indy white 1600cc injectors
- custom fuel rail
- SX racing FPR
- 3x bosch 044 fuel pumps
- walbro lift pump
- 3x proflow fuel filters
- 6 litre surge tank
- 2x -6 fuel lines
- custom 3" stainless cooler piping
- haltech platnium ecu
- 600x300x120mm cooler
- tomei sump baffle
Edited by 26_S13
For everyones information, I have compiled this spreadsheet of all the results from the RB26 dyno thread here:
SAU_dyno_comparisons.xls
This only includes results that aren't from standard turbos.
I hope this doesn't get deleted/moved.
And yes I did get really bored to find the time to come up with this one lol.
Edited by smithy85
Car back from being tuned at JEM (AWD dyno), mods as follows:
Garrett 2860-9's with Garrett 1 bar actuators
Split dump pipes
Trust 70mm into 80mm front pipes
X force 3.5" cat
Veilside JASMA 3.5" exhaust (centre muffler removed)
HKS pod filters
720cc denso injectors
HKS cam gears
Apexi Power FC
Greddy Profec Bspec II
Splitfire coil packs
Std internals
Std AFM's
Std fuel pump
High boost - 287kw @ 18 psi
Low boost - 248kw @ 14 psi (Compare to old standard turbos which made 233kw @ 14.5 psi)
R32 GTR
Pump fuel (98)
Stock bottem end
Precision 6262 plain bearing turbo
Unknown cams (9.1mm lift)
HKS 100mm thick intercooler and piping
Sard 700cc injectors
Power FC
Unknown fuel pump
HKS log style cast low mount manifold
HKS wastegate
4" dump pipe to a 3" cat back exhaust
492hp @ the wheels on 19psi.
New setup;
GT Block
Tomei 2.8 (86.5 mm pistons)
270 @ 10.25 cams.
Nismo Plenum
Nismo intercooler
Tomei dumps
Garrett -5's
Racepace motorsport twin 3 inch exhaust
Link G4 Plug in ECU
Ethanol flex fuel setup
Ross Tuffbond crank trigger. (Timing is no longer taken from the CAS)
Went back to a stock airbox.
United E85
Made 420 RWKW with EBC OFF. (boost spiked at 24 and trailed back to 22.5 psi top end)
More tuning will be done with the EBC on.
On PULP i made 403 RWKW at the same boost. But there is a noticeble difference in how the car drives.
Graph will be up soon.
1994 R32 GTR - probably with 1,000,000kms but 98xxx on the clock
Setup before:
Cat back exhaust
Pod filters
100k service
N1 waterpump
12psi through stock turbos
213awkw
Setup 2 weeks ago:
Garrett -7s
GReddy dump pipes
GReddy front pipe into existing 3.5" exhaust
HKS 264 camshafts
HKS camgears
HKS fuel rail
HKS fuel regulator
ID 1000cc injectors
New fuel pump
Vipec plugin ECU
Eboost solenoid controlled by ECU
Koyo 53mm radiator
320awkw at 18psi with clutch slipping
Track day at Eastern Creek 30/10/2011 - clutch was finished before I even got to the track slipping like crazy from 4500rpm in 3rd and 4th gear. Coilpacks and spark plugs weren't up to the job either.
Setup now includes new clutch, new plugs and splitfire coil packs. High boost tune to come once clutch is run in
Edit: WTF is going on with computers and the internet this morning???
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
