1994 R32 GTR
Stock Tune
HKS Front Pipe 70-80mm
De-Cat
3.5" HKS Hi Power Catback
222.6 AWKW @ 14psi
Racepace Tune by Chris
Nistune
De-Cat
Adjustable Cam Gears
HKS GTSS/-9
Nismo FPR
306kw @ 17.5 psi
Edited by willL
first update since owning car :D
1996 R33 VSpec LM Limited
stock turbos
Power FC
Apexi intakes
700cc power enterprise injectors
walbro 550hp fuel pump
HKS silent pro cat back with catco highflow cat
Tomei cam gears
GReddy PRofec B-spec2 boost controller
237awkw or 317awhp @12psi
update:
found out standard fpr was dying on last tune and died 2 weeks after. fitted new turbosmart fpr800 and retune + a bit more boost (tuned in rwd)
353rwhp at 15 psi hi boost and 323 rwhp at 12 psi lo boost
update on my gtr
r33 gtr 1995
rb26
engine
honed/bored 0.20# , acid dipped all usual machining done ect
shot peened n1 rods with enlarged big end bearings , crank balanced re nitrided and oversized 0.60 acl race bearings
arias 0.20 over pistons , acl piston rings
tomei oil restrictor
tomei sump bafffle/trap doors
N1 water pump ,
nitto race series oil pump
genuine nissan gasket set throughout
cossworth drag series 1.5mm metal head gasket
head reconditioned with porting on exhaust side , hks 264 cams greddy adjustable cam gears
arp head stud kit
driveline
Very rare Autogallery yokohama 1-5 H/D set with double cone syncro's , redline shockproof oil
Os giken pro series twin plate push type clutch
Vspec rear active lsd diff
Turbo/exhaust/intake
Trust greddy t517z turbos with 10cm housings
standard manifolds match ported
hks non turbulent dump pipes
custom twin 3inch y pipes with 100cfm race cats y pipes individualy run to centre of car and then merge into 3.5inch exhaust with highflow muffler and 5 inch tip
apexi hard pipe intake kit with twin z32 afm
electronics/ignition/fuel
apexi power fc , with hand controller
blitz 4 stage electronic boost controller
bosch single 044 mounted intank
injector dynamics 1000cc injectors with convertors t fit 10.5mm standard rail
turbosmart adjustable fuel pressure reg
splitfire coilpacks
hks twin spark DLI amplifier
low compression engine tested 128- 132 across all 6 due to 1.5mm h/g , current power 405kw@wheels on mainline dyno at 23psi fuel pump is probably near its limits but this is plenty for me!!
1995 R33 GTR V-Spec100,000km
Mods
-Unopened Rb26dett
-Apexi power intake kit
-Garrett GT2860R Twin turbos
-4" Turbo Back
-555cc Nismo injectors
-HKS Extractors
-Mines ECU
-Highflow Cat
-Oil Relocater
-Oil Cooler
-Exedy Twin place clutch
-Stock Intercooler
-Stock Fuel pump
Tuned By IS Motor Racing
Made 216 awkw @ 1.0bar (14.5psi)
Should i be getting more power out of what i have????
Cheers.
What turbos are they? -7's, -9's? You should be seeing heaps more. My gts-t made more with a GT-RS on 12psi.. Maybe its just a "lets see how this goes for now" tune? Have you spoken to your tuner about it yet?
they are 7's, i haven't spoken to the tuner but I'm sure what you said about "lets see how it goes for now" tune sums it up pretty well. :)
Cheers
  • 3 weeks later...
1994 R32 GTR
- R33 GTR Block (Built Motor)
- 2860-5
- HKS dump pipes and front pipes
- Tomei Cams
- Mine's adjustable cam gears
- SARD Fuel Rail + Fuel Pressure Regulator
- SARD 700cc Fuel Injectors
- 110mm thick intercooler
- HKS intercooler hard pipe kit
- K&N Twin POD intake
- Platinum PRO
- HKS Silent cat back
- MAP sensor Maxed.
*will post dyno sheet tonight*
R33 gtr
ID 1000's
Walbro 400lph
Powerfc
Greddy profec b spec 2
NPC 10" sprung button (650hp)
Big front pipe
3" cat back
100cell cat (letting me down)
-9's with 1bar actuators
Standard afms (letting me down)
Standard airbox
Standard dumps
303 kw at 18psi (on the 20th run) I want to see what I get on a cold day :P.
Edited by eat_me
R32 GTR 1992
Stock RB26
ID 1000's
Bosch Intank pump
Autronic ecu
Autronic 500r ignition system
Hks 2530's
Xforce exhaust
Standard manifold
Just jap pod filters
Stock intercooler
Hks evc-s boost controller
Running 20psi@319awkw on eflex
Tuned by JEM
Had another tune as the car is mechanicaly finished (for now)
Autech 260RS
Stock bottom end
Stock FPR
R34 GTR turbos < Terry's old turbos :whistling:
Nismo 555cc injectors,
Walbro fuel pump
Power FC
AVCR
Z32s
Greddy suction kit and cold air box with factory snorkel
HKS 264 deg cams
HKS cam gears
HKS hard piping kit
Yoshida Garage custom ported head and port matched exhaust manifolds
Greddy extended split dumps and front pipe
Fujitsubo Cat back
Gutted cat
N1 oil and water pumps
Greddy oil cooler kit
Turbosmart BOVs
312.5kW at 16.5 psi
272kW at 13 psi
Edited by numleg
  • 4 weeks later...
1991 R32 GTR
Rebuilt engine to N1 specs
Rebuilt Nismo turbos
3.5'' exhaust
Custom front pipe
HKS pod filters
191.2 awkw @ 8psi
Apexi Power FC
HKS Cam Gears
Nismo fuel pump
Nismo 600cc injectors
302.1 awkw @ 18 psi
Edited by 91BNR32
1993 R32 GTR
work done by mrc performance from receipts when i got the car.
stripped engine and rebuilt,
Greddy rb26dett cams- can someone tell me what size these may be
Greddy head gasket, inlet gasket kit
greddy cam gears, exhaust gaskets
tomie sump baffle
for mods-
hks 2530's
3.5" xforce exhaust system from dumps back
power fc, avcr boost controller
sard 600cc injecters, unsure on fuel pump brand and size
splitfire coil packs
pod filters
hks sequential bov's
thats all i can think of for now but the car made 320kw on 21psi at the rears, ive been told that seems a little low for the mods. Any ideas??
cheers steve
1990 R32 GTR Group A Nismo Edition
PFC
Tomei Type B Cams
Jun Cam gears
BeeR Front Pipes in kaki catback
Tomei S2 dumps
2860-5
Sard 700s
Sard FPR
Tuned by DVSJEZ
331 on 21psi safe tune using bp98
thing pulls like a frieght train, jez worked his magic on the mid range and i think for -5 on a 2.6 its a pritty fat section, you can deff feel it on the street, pull really hard all the way to 8k
e85 tune coming soon!!!
GTR r32 silver 93
79km
Le mans turbos
Tomei cam gears
HKS ehxaust
HKS dump pipes
Z32 afm
Nismo 555 injectors
Hi flow walhbro type petrol pump
Nistune ecu
Nismo main bearings
N1 water pump
Silicone hose kit
ACL race big end bearings
Greedy boost controller
Dyno run 27/04 316.1kwatw @ 20psi
1997 R33 GT-R V-Spec SII
Odo: 116,500kms
Mods:
  • Stock turbos
  • Stock intercooler
  • Stock dumps
  • Blitz front pipes 2x70mm into 80mm
  • 3" X-Force ceramic cat
  • Apexi N1 Pro catback - 3" into 3.75 into a 3.5" muffler
  • K&N air filter panel
  • Gearbox fluid - Motul
  • Diff fluid - Motul
  • Racepace cam gears
  • Apexi Power FC
Tuned by Chris at Racepace Motorsport - 269.4rwkw @ 14psi
R32 GTR with R33 GTR engine
new king bearings + sump baffle etc, standard pistons
trust t517z turbos
76mm HPI stainless dump pipes to 65mm front pipe and 3" cat back
ARC 70mm front mount
sard 700cc injectors
bosch 044 intank pump
power fc
blitz i-colour boost controller
apexi pods
OS Giken twin plate solid center clutch
331.6kw safe tune to match standard internal engine
bigger front pipes and cat back are next, plus tomei type B cams then retune.
Edited by SiR_RB
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
