mattie4270 Posted July 29, 2012 Share Posted July 29, 2012 1990 GTR R32 stock bottom end 260cams Gt35 turbo 650cc injectors big intercooler twin 44 pumps haltech pro 20psi 3.5 exhaust 340awkws tuned by JEM cars now getting fitted with head studs,1000cc injectors,E85 conversion,so with a bit more boost hoping to get around 380kws,see how we go! Link to comment https://www.sau.com.au/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/page/20/#findComment-6464441 Share on other sites More sharing options...
R33RWKW Posted August 2, 2012 Share Posted August 2, 2012 Forgot to post my results in here last year. I have now upgraded a few things this year and I will post the differences in mods and power/response gains. Last Years Results using: 1997 R33GTR V-SPEC Series 2 New RacePace Stage 1 R34 RB26 Engine New R34 GTR Head New Garrett 2860r-5 Turbos with 14psi actuators OEM Camshafts Tomei Cam Gears OEM EX Manifold X-Force Dumps HKS Front Pipes HKS Hi-Power/Silent Exhaust System Trust/Greddy Sump Kit Trust/Greddy FMIC 100mm Thick/The Big One Trust/Greddy Alloy Radiator Trust/Greddy Oil Cooler Trust/Greddy Type R BOV's RPM Oil/Water Seperator/Catchcan Power Fc HKS EVC 5 (Black Edition) New Nismo AFM's Sard 800cc Injectors Sard FPR After Market Fuel Rail/HKS copy? Bosch 044 intank pump Series 3 GTR Gearbox with short shifter OS Giken Twin Plate Clutch & Flywheel Tuned by RacePace 365rwkw @ 19psi http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach§ion=attach&attach_id=318964 Upadates From Earlier This Year: New RacePace 3.5" Custom Exhaust System with Twin Pipes New RacePace Tuned Length Front Pipes New Tomei 72mm Dumps (older style) New Nismo Super Coppermix Twin Plate Clutch & Flywheel Kit(COMP MODEL) Tuned By RacePace 380rwkw @ 20psi Cant Get these pics working will try again tmrw. Link to comment https://www.sau.com.au/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/page/20/#findComment-6471865 Share on other sites More sharing options...
Tommy Kaira RL Posted August 3, 2012 Share Posted August 3, 2012 1996 R33 GTR Mods Nismo front pipes and Apexi Exhaust with 100cell metal cat Nismo intake and HKS IC APEXI Suction and pod filters Aftermarket cams ?? 9.1mm lift HKS Cam gears N1 R33 Turbos 21PSI ??? bottom end Nismo FPR stock injectors stock AFM 301AWKW Link to comment https://www.sau.com.au/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/page/20/#findComment-6473096 Share on other sites More sharing options...
Hadouken Posted August 6, 2012 Share Posted August 6, 2012 *will post dyno sheet tonight* R33 gtr ID 1000's Walbro 400lph Powerfc Greddy profec b spec 2 Tomei Cam Gears NPC 10" sprung button (650hp) Big front pipe 3" cat back 100cell cat (letting me down) -9's with 1bar actuators Standard afms (letting me down) Standard airbox Standard dumps Heres the dyno sheet. Can a mod please join it to my post? Updated with some Cam Gears dialled in for a little extra down low and a bit more up top. Link to comment https://www.sau.com.au/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/page/20/#findComment-6475945 Share on other sites More sharing options...
usmair Posted August 17, 2012 Share Posted August 17, 2012 -9s Haltech 1000cc injectors 3.5" exhaust stock cams stock bottom end e85 Link to comment https://www.sau.com.au/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/page/20/#findComment-6492456 Share on other sites More sharing options...
gtraaron Posted August 18, 2012 Share Posted August 18, 2012 -5s , tomei type b cams , nismo fuel pump , sard 800cc injectors , ti front pipes and tomei ti cat back , cat in place (intact) rebuild engine (forged) 2.6 Link to comment https://www.sau.com.au/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/page/20/#findComment-6492863 Share on other sites More sharing options...
just_racing Posted August 26, 2012 Share Posted August 26, 2012 Standard RB26 Twin RB25 afms Ebay intercooler 3" pretty much straight through exhaust 6 Boost exhaust manifold GT35R Twin 044 pumps 880cc injectors E85 Lightened flywheel 485hp @ 7300rpm Link to comment https://www.sau.com.au/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/page/20/#findComment-6504107 Share on other sites More sharing options...
Shoota_77 Posted August 30, 2012 Share Posted August 30, 2012 -7's Forged bottom end Z32 AFM's - Apexi Super suction 3 - 3 1/2" Exhaust ID1000cc injectors Nismo fuel pump Stock cams Tomei adjustable cam gears Power FC Hi flow cat (apparently!) Topped out at 322kw, backed off a bit to 315kw. Love to get anyones feedback on the power and curve! Seems a bit soft to me?? Link to comment https://www.sau.com.au/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/page/20/#findComment-6510095 Share on other sites More sharing options...
Hadouken Posted August 30, 2012 Share Posted August 30, 2012 e85, also comments will be removed by the mod. this only a results thread. Start a thread so we can talk about it Link to comment https://www.sau.com.au/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/page/20/#findComment-6510985 Share on other sites More sharing options...
Sinista32 Posted September 13, 2012 Share Posted September 13, 2012 1993 R32 GTR Rebuilt RB26 2860-7's Haltech - mafless Tomie Type B cams, Adjustable cam gears 700cc injectors Nitto/JE pistons 98ron 326kws at 18psi 350kws at 21psi 1993 R32 GTR Rebuilt RB26 2860-7's Haltech - mafless Tomie Type B cams, Adjustable cam gears 700cc injectors Nitto/JE pistons 98ron 326kws at 18psi 350kws at 21psi Correction - ^ 2nd run at a different Ramp Rate skewing output figures ^ Link to comment https://www.sau.com.au/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/page/20/#findComment-6531216 Share on other sites More sharing options...
Rizzz Posted September 18, 2012 Share Posted September 18, 2012 2000 GTR 34 Unopened Engine. Wolf Ecu. 2000cc Injectors. 2860 -5's Hypertune plenum. hks intercooler and piping. Tomei cam gears. Spitfire coil packs. 360awkw on E85 19.5 PSI Link to comment https://www.sau.com.au/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/page/20/#findComment-6538391 Share on other sites More sharing options...
Tommy Kaira RL Posted September 18, 2012 Share Posted September 18, 2012 1996 R33 GTR Mods Nismo front pipes and Apexi Exhaust with 100cell metal cat Nismo intake and HKS IC APEXI Suction and pod filters Aftermarket cams ?? 9.1mm lift HKS Cam gears N1 R33 Turbos 21PSI ??? bottom end Nismo FPR stock injectors stock AFM 301AWKW New 1000cc injectors and E85 now 341awkw dyno.pdf Link to comment https://www.sau.com.au/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/page/20/#findComment-6539045 Share on other sites More sharing options...
R33huntme Posted September 26, 2012 Share Posted September 26, 2012 redo garret 35r turbo new thicker cooler [unsure of brand] full 3.5inch stanless turbo back exhaust pipe 750cc injectors Tomei poncam camshafts and a retune Link to comment https://www.sau.com.au/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/page/20/#findComment-6551921 Share on other sites More sharing options...
R33huntme Posted September 26, 2012 Share Posted September 26, 2012 (edited) ^^^^^...video of the tune..^^^^ http://s1160.photobu...t=stagea002.mp4 Edited September 26, 2012 by R33huntme Link to comment https://www.sau.com.au/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/page/20/#findComment-6551923 Share on other sites More sharing options...
binga85 Posted September 28, 2012 Share Posted September 28, 2012 5 months ago. R33 GTR Vspec Standard Motor 2860-5s blitz dual intake 1000cc ID's Haltech Pro Ecu PWR intercooler Greddy Cam gears Walbro Fuel Pump. 330Awkw new build with single kit and other stuff now. new results with dyno shortly Link to comment https://www.sau.com.au/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/page/20/#findComment-6555381 Share on other sites More sharing options...
Adz2332 Posted October 11, 2012 Share Posted October 11, 2012 - Desno 800cc injectors - 2860 -5 Turbos - Tomei Cam gears - Power FC and Controller - Z32 Afms - Apexi AVC-R Boost controller - Trust 100mm Intercooler - Tomei Expreme TI cat back - Venom 100 cell 5 inch body cat - Apexi Super Suction Kit Pods - Air Box and Cold Air Intake - Engine - Forged Pistons with standard Rods - Metal head gasket - GTR crank - ACL bearings - Extended Sump - New Rings - Honed Bore Pretty happy with it. Much more responsive and when it hits 4000rpm wow..... Thinking some drop in cams, push a bit more boost and ill be done Link to comment https://www.sau.com.au/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/page/20/#findComment-6575262 Share on other sites More sharing options...
HIRISK Posted October 18, 2012 Share Posted October 18, 2012 R34 GTR V-Spec II RB26 Standard bottom end Apexi Power FC D-Jetro Tomei Poncams Sard 700cc Injectors HKS Fuel Rail Sard FPR Tomei Exmprere Exhaust Manifolds HKS 2530 Turbos HKS Wastegate actuators Trust Intercooler Trust Hard Pipe Kit K&N Pod Filters Nismo Z-Tune (cast) dump pipes Power House Amuse Titanium Front Pipes Hi flow 3" Metal Cat Tomei Expreme Ti Cat Back 349.6kw @ 19psi 391.9kw @ 22psi I am going to stick 19psi due to stock bottom end. -------------------------------------------------------------------------------------------------------------------------------------------------------------------- 22 PSI BOOST -------------------------------------------------------------------------------------------------------------------------------------------------------------------- 19 PSI BOOST -------------------------------------------------------------------------------------------------------------------------------------------------------------------- Link to comment https://www.sau.com.au/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/page/20/#findComment-6585383 Share on other sites More sharing options...
vspecIInur Posted October 22, 2012 Share Posted October 22, 2012 Here's mine: R34 GTR VS2 Nur N1's HKS Actuators Racepace 3.5Inch full exhaust Nismo Twin Coppermix (Comp) HKS EVC-S HKS Cam Gears Nismo Fuel Pump Nismo FPR Nismo Airflow Meters ID1000's E85 Power FC 379kw @ 21psi. Link to comment https://www.sau.com.au/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/page/20/#findComment-6590164 Share on other sites More sharing options...
gtraaron Posted November 15, 2012 Share Posted November 15, 2012 Now on eflex -5S , 2000CC INJECTORS 400L IN TANK PON CAMS TYPE B Link to comment https://www.sau.com.au/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/page/20/#findComment-6626715 Share on other sites More sharing options...
GTR_JOEY Posted December 2, 2012 Share Posted December 2, 2012 Capacity 2.6L R33 GTR crank Tomei rods CP pistons Jun Oil pump Standard water pump Standard sump filled to 6L (Race pace sump to be installed soon!!) Tomei type B cams Breathers from sump to head (passenger side) Tomei oil restrictor Tomei cam gears Exhuast and Turbo Full-Race twin scroll manifold BW S300 83/75 .91 housing 4inch dump pipe High flow cat 3.5inch exhaust after Cat Twin Tial 38mm waste gates Koyo 100mm intercooler Electronics and ignition Link G4 ECU Apexi AVC-R Boost controller Ross balancer and Crank trigger Ethenol Sensor and digital readout screen Split fire coil packs After market Ignitor New OEM coil pack loom Copper plugs Fuel system Nismo intake Fuel pump ALPHA OMEGA Billet steel CNC'd Surge tank Twin Walbro 400LPH pumps in surge tank Sard FPR ID2000cc injectors Twin entry fuel rail Braided lines all round Duel filters E85 Tune, top line is just more boost through the mid range Link to comment https://www.sau.com.au/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/page/20/#findComment-6651746 Share on other sites More sharing options...
