Sorry, Forgot to post specs
Rhemac RB29 - destroked RB30 crank
Eagle H beam rods
CP forged pistons and rings
ACL race series bearings
CNC ported head
Ferrea 1mm stainless valves
HKS 264 10.2mm step 2 intake cam
HKS 272 10.2mm step 2 exhaust cam
Bronze valve guides
ACL 1.2mm MLS head gasket
Gates adjustable timing gears
Tomei oil restrictor
Greddy Oil pump
ATI balancer
HKS 25/30 with HKS actuators
HKS pod filters
Xspurtz 1550cc injectors on factory fuel rail
Turbosmart Fuel regulator
Twin Walbro 460LHP pumps
OS Giken triple plate clutch
100mm Blitz intercooler
custom 4" exhaust
Tech edge 2J9 wideband O2 sensor
Haltech Eflex fuel sensor
Vipec V88 ECU
Trent @ Chequered Tuning E85 and 98 Octane tuned
E85 - 481rwKW; 775Nm @4900 rpm
98 Octane - 431 rwKW; 662Nm@5404
Responsive?
Eagle H beam rods
CNC ported head
Bronze valve guides
Greddy Oil pump
ATI balancer
HKS pod filters
custom 4" exhaust
Vipec V88 ECU
Responsive?
Did this car used to belong to Mark from Rhemac?
The Borg Warner thread got shut down so I'll post here for those interested.
BW EFR 8374
Stock bottom end rb26
256 cams
E85
504kw - 30psi around 4600rpm.
Has another 30-40kw in it. I told him to stop at 30psi due to standard bottom end.
  • Like 5
BW EFR 8374
256 cams
E85
got any plans to race it?
r34nur
stock engine
gtx3576 0.82a/r
walbro 450
id1300
260kw@18psi n1 turbo 98 fuel
310kw@18psi gtx3576 ( same boost response as n1s) 98 fuel
287kw@14psi gtx3576 e85
346kw@20psi gtx3576 e85 (tuned boost build a bit slower then 98 tune, cause I don't want boost spike)
Model/Make: 2002 R34 GT-R M-Spec
Mileage: 110,000 kms
Output
320rwkw / 430rwhp
Head / Turbo
- Garrett 2860-9s - fitted with HKS oil feed restrictor banjo bolts
- Garrett 1bar actuators
- Tomei dump pipes
- Standard cast manifold - Port matched to turbos
- Tomei Poncam Type A - lifter shim clearance within OE spec
- Jun adjustable cam gears (OR gears modified to be adjustable) - set to 0deg/0deg
ECU/AFMs
- Apexi Power FC
- Nismo AFMs
Cooling
- Plazmaman Pro Series 76mm intercooler
- Koyorad 48mm aluminium radiator
- Trust 13 row oil cooler with filer relocation kit
Exhaust / Intake
- Amuse R1 Titan Extra cat-back exhaust 90mm
- Apexi Super Catalyzer Cat - 80mm
- Mines Pro front pipe (2 x 70mm into 80mm)
- Nismo inlet piping
- OE Airbox with Nismo panel filter and snorkel
Ignition / Fuel
- Sard 650cc top-feed Injectors
- Splitfire coilpacks
- Wiring specialties coilpack harness
- Nismo 255L fuel pump
- Denso iridium spark plugs
Edited by squareznboxez
  • Like 4
  • 4 weeks later...
I've posted this in a separate thread earlier this year. I do have to go back and retune again as brand new power FC boost controller did not work again so we ended up running it on manual boost controller. I will probably dump PFC altogether and try "Link G4 ECU"  plus play with cams/gears--currently set at zero. My main question is, what are some general boost levels that many of you run on your cars? I plan on running this motor regularly at 22-25psi.. car will only be used for couple of monthly coffee meets and occasional evening night rider passes.. along with few drift events each year.
Most importantly, I'm thinking of dumping the brand new GTX3582 for an EFR8374 rear 1/05 a/r divided housing in hopes for quicker spool and more power at the same boost level. Can anyone share their experience with 8374 in comparison to my set up? I hear 700whp should be no problem and that's my ultimate target goal.
Any feedback is greatly appreciated!
Set up is as follows in S13 chassis:
Mildly built R33 (pistons, rods, upgraded oil pump, HG, head studs, tomei poncams type B
ID1000cc injectors running power FC d-jetro
e85 race gas
all the misc bolt-on's you can think off
running GTX3582R, .82 rear T4 undivided with two 50mm gates
Here is what it made at 22-23psi..
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
