Sorry, Forgot to post specs
Rhemac RB29 - destroked RB30 crank
Eagle H beam rods
CP forged pistons and rings
ACL race series bearings
CNC ported head
Ferrea 1mm stainless valves
HKS 264 10.2mm step 2 intake cam
HKS 272 10.2mm step 2 exhaust cam
Bronze valve guides
ACL 1.2mm MLS head gasket
Gates adjustable timing gears
Tomei oil restrictor
Greddy Oil pump
ATI balancer
HKS 25/30 with HKS actuators
HKS pod filters
Xspurtz 1550cc injectors on factory fuel rail
Turbosmart Fuel regulator
Twin Walbro 460LHP pumps
OS Giken triple plate clutch
100mm Blitz intercooler
custom 4" exhaust
Tech edge 2J9 wideband O2 sensor
Haltech Eflex fuel sensor
Vipec V88 ECU
Trent @ Chequered Tuning E85 and 98 Octane tuned
E85 - 481rwKW; 775Nm @4900 rpm
98 Octane - 431 rwKW; 662Nm@5404
Responsive?
Eagle H beam rods
CNC ported head
Bronze valve guides
Greddy Oil pump
ATI balancer
HKS pod filters
custom 4" exhaust
Vipec V88 ECU
Responsive?
Did this car used to belong to Mark from Rhemac?
The Borg Warner thread got shut down so I'll post here for those interested.
BW EFR 8374
Stock bottom end rb26
256 cams
E85
504kw - 30psi around 4600rpm.
Has another 30-40kw in it. I told him to stop at 30psi due to standard bottom end.
  • Like 5
BW EFR 8374
256 cams
E85
got any plans to race it?
r34nur
stock engine
gtx3576 0.82a/r
walbro 450
id1300
260kw@18psi n1 turbo 98 fuel
310kw@18psi gtx3576 ( same boost response as n1s) 98 fuel
287kw@14psi gtx3576 e85
346kw@20psi gtx3576 e85 (tuned boost build a bit slower then 98 tune, cause I don't want boost spike)
Model/Make: 2002 R34 GT-R M-Spec
Mileage: 110,000 kms
Output
320rwkw / 430rwhp
Head / Turbo
- Garrett 2860-9s - fitted with HKS oil feed restrictor banjo bolts
- Garrett 1bar actuators
- Tomei dump pipes
- Standard cast manifold - Port matched to turbos
- Tomei Poncam Type A - lifter shim clearance within OE spec
- Jun adjustable cam gears (OR gears modified to be adjustable) - set to 0deg/0deg
ECU/AFMs
- Apexi Power FC
- Nismo AFMs
Cooling
- Plazmaman Pro Series 76mm intercooler
- Koyorad 48mm aluminium radiator
- Trust 13 row oil cooler with filer relocation kit
Exhaust / Intake
- Amuse R1 Titan Extra cat-back exhaust 90mm
- Apexi Super Catalyzer Cat - 80mm
- Mines Pro front pipe (2 x 70mm into 80mm)
- Nismo inlet piping
- OE Airbox with Nismo panel filter and snorkel
Ignition / Fuel
- Sard 650cc top-feed Injectors
- Splitfire coilpacks
- Wiring specialties coilpack harness
- Nismo 255L fuel pump
- Denso iridium spark plugs
Edited by squareznboxez
  • Like 4
  • 4 weeks later...
I've posted this in a separate thread earlier this year. I do have to go back and retune again as brand new power FC boost controller did not work again so we ended up running it on manual boost controller. I will probably dump PFC altogether and try "Link G4 ECU"  plus play with cams/gears--currently set at zero. My main question is, what are some general boost levels that many of you run on your cars? I plan on running this motor regularly at 22-25psi.. car will only be used for couple of monthly coffee meets and occasional evening night rider passes.. along with few drift events each year.
Most importantly, I'm thinking of dumping the brand new GTX3582 for an EFR8374 rear 1/05 a/r divided housing in hopes for quicker spool and more power at the same boost level. Can anyone share their experience with 8374 in comparison to my set up? I hear 700whp should be no problem and that's my ultimate target goal.
Any feedback is greatly appreciated!
Set up is as follows in S13 chassis:
Mildly built R33 (pistons, rods, upgraded oil pump, HG, head studs, tomei poncams type B
ID1000cc injectors running power FC d-jetro
e85 race gas
all the misc bolt-on's you can think off
running GTX3582R, .82 rear T4 undivided with two 50mm gates
Here is what it made at 22-23psi..
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
