  • 3 weeks later...
18 hours ago, Nosure said:
Cam adjustment done.
That looks much better. You said you didn't have too much trouble with drive-ability before. Can you feel the difference on the road?
It's got twice the horsepower at 4500rpm! That would be a massive difference
Hi. Yes it drive better, feel faster again. But still room to improve:)  response feel like N1s on 2.6, but a lot more power.
  • Like 1
  • 1 month later...
Original setup made 354rwk @ 24-25psi.
  • Haltech Platinum Pro
  • N1 manifolds
  • -9s
  • HPI dumps and 3" front pipes
  • Full 3.5" exhaust after merge, catless
  • Big K&N pods in partial enclosure.
  • E85 with 1000cc Injectors and 460lph walbro.
  • Cam gears,
  • Twin turbo pipe mod
  • Plazmaman 76mm Intercooler
Added/changed.
  • BC Springs
  • Kelford L182A Cams
  • Delete pressure valve in fuel line in tank.
  • Aeroflow fuel filter.
  • Rewired fuel pump with higher gauge wire after realising the current wiring was 15amp max and the pump can draw into the mid 20s.
Fuel mods done as fuel pressure couldn't keep up.
Now peaks at 23-24psi but tapers off to 21ish. I think these turbos are out of puff now, but not a bad result for -9s. Pretty happy given the bay looks fairly low key.
Edited by ActionDan
  • Like 5
 R32 GTR
530hp@19psi
2.8l (supposedly)
tomei cams
tomei manifolds
700cc injectors
nismo fpr/pump
R34 N1 (AA403) turbos
hpi elbows
mines frontpipe
Decat
HKS exhaust
tomei ecu
Edited by Trailmix
  • Like 1
Sorry missed that.
Maybe someone else can comment, is a 2.8 and Cams enough to get that number? I'm assuming they're Type B's so around 264 duration.
19psi is not a lot of airflow from N1s.
Must be nice to drive :)
I don't know which cams they are, when the car was listed for sale in Japan. It stated tomei 2.8l stroker kit with tomei poncams with cams gears. Though the tomei ecu causes the afr to drop into the 10s underfull boost. Going to switch to a platinum pro. I expected quicker spool with the N1s, might get better numbers with timing adjustment.
Edited by Trailmix
  • 1 month later...
92 GTR
RB26 Stock bottom end
HKS 2530's, divorced dumps
Trust Intercooler
3.5" exhaust, SARD high flow cat
Nismo 555cc injectors I think
Stock cam gears
Unknown fuel pump but definitely not stock
Unknown oil pump (but more pressure than stock)
HKS EVC @ 1.3 bar
HKS FCON V
This is how the car came to be, off the boat from Japan.  It made 400 WHP in AWD mode on a Dyno Dynamics dyno.  The idle AFR was 10's so I knew I needed to get it re-tuned as this is my daily driver.
RECOMMENDATIONS?
Since that dyno, I picked up a Haltech Platinum Pro PNP, removed the HKS EVC and bought a MAC valve.  None of that has been installed yet.  I'm not looking for huge power but I do want it to be fun and reliable enough to take to the occasional track day.  The age of the current injectors and fuel pump are unknown.  Originally I wasn't looking for more power.  400 is fun enough, just wanted to fix that fat idle mixture.  A local tuner suggested Fuel Injector Development 630cc injectors ($375 USD) and a new pump but I'm more inclined to spend that on adjustable cam gears for more responsive low end if my current injectors and pump are sufficient.  If I did new injectors and pump, what's a good drop in solution? Other thoughts?
  • 1 month later...
R34 GTR Vspec
-9 Turbos at 22 psi (set to spike to 23-24 psi at around 4000rpm through midrange)
Plazmaman 76mm intercooler
HKS Super Turbo cat back with Venom 100 cell cat and Fujitsubo front pipe
HKS EVC-6
ARP head studs
Tomei cam gears
Walbro pump
700cc Sard injectors
Twin Turbo pipe divider
Vipec ECU
98 Pump fuel
314.3 AWKW/ (420HP)
**Note - wavy dyno curve due to 4wd kicking in on Dyno
  • Like 1
  • 2 months later...
New results now that I'm on E85.
2.75L stock bore (86mm) BC stroker (79mm stroke).
BC SS valves, valve guides, retainers, springs
Tomei Poncam A's
Hypertune V2 intake
6 boost manifold for IWG Borg Warner 8374 EFR turbo .92 IWG on turbosmart actuator
ported head
ID 1300x injectors (nearly maxxed)
2x 460 walbro fuel pumps with 3rd as a lift pump to the sump
ECU masters EMU black
LS2 DBW TB
the low 7xx runs are 26 psi tapering to around 24
the 740 run is 30 psi tapering to around 24-25.
I have added 5th gear spoolup log because this is an inertia dyno and falsely makes this setup seem laggy.
boost is all in at 3800 usually in 3rd gear.
Now for the crazy stuf...STOCK intercooler, STOCK trans, 3" exhaust.
  • Like 3
  • 1 month later...
Tomei Poncam A's
Hypertune V2 intake
ported head
LS2 DBW TB
US HP?
US HP?
Sure. Stock cadillac ctsv makes 485 whp on this dyno. Stock focus RS mashes 318 whp on this dyno.
But it's inertia so mine looks like it spools late. I also live AT sea level. Was like 5 C in shop that night so cold dense air.
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
