Thanks for reply. That’s great result. What power it made on what psi? I’m looking for get 8374 iwg or 9180 iwg. But no result I can find.
Search my posts they are all on here including the build thread. 8374 is an incredible turbo for rb26
14 minutes ago, WantGTR said:
No dyno sheet but car went 10.8@140mph. First and only pass.
2018-07-05_07-22-172018-07-05_07-22-44
Nice!  To be fair, this is a dyno result thread and posting a time slip but still no dyno sheet makes baby jesus cry.  Very interested to see the delivery of this
Yes i know. But mph is better than a dyno sheet. Mph doesnt lie.
  • Like 2
maybe just let us know how many rpm full boost?
  • 4 weeks later...
Fresh Dyno
1991 GTR
Stock RB26DETT
Garrett GT2860R-7 turbos
Stock R32 dumps, manifolds, etc.
Greddy downpipe
HKS Super Drager Exhaust
Custom hardpipe intakes (AFMs deleted and all inlet rubber changed to 2.5" Al piping)
Tapped a -6AN fitting into stock fuel rail
FIC 850cc injectors
93 Octane Pumpgas (USA)
BCPR7EIX plugs gapped to .025"
Haltech PnP Rev2 (love this! much better than rev1).
20.5 psig + 3 deg of timing over haltech base.
465 whp
patrick gtr 7-28-18.pdf
On 7/31/2018 at 7:06 AM, HarrisRacing said:
Fresh Dyno
1991 GTR
Stock RB26DETT
Greddy downpipe
FIC 850cc injectors
465 whp
RWHP or AWHP?
465 HP seems a little high for a fairly standard 26 on -7's at 20 psi of boost.
Good result none the less!
RWHP or AWHP?
RWHP.
The car did 384 whp before the stock AFMs cut me off around 17-18 psi...and at 10 psi did about 296 whp. Haltech, cam gears (rolled in about 6 deg of overlap) and intake pipes woke it up. This dyno is pretty dang accurate. Motor runs very well.
Also I just tuned another R32 GTR on stock RB26 on tomei cam gears, 8374 EFR .92 IWG, 6 boost manifold, on pumpgas 93 octane (your 98) and it did 570 whp on 20 psi. Did 636 whp on 23 psi on E30 and ran out of injector. Also on haltech platinum.
Both cars are strong...the -7 car definitely more laggy than the EFR single car though.download_20180806_220847.jpeg
  • Like 1
480kw at 23 psi
Dam bald egles  can tune
This is how that car showed up on stock turbos, stock haltech igniton map and a rough (rich) fuel tune at 15-16 psi. However you want to criticize the overall power, the gains in power are undeniable with only a turbo, injectors, fuel setup, and cam gear changes.
Have a mate with the same turbo at 28 psi e85) and only 380kw
the internal gate bw r junk for bulk power  In Australia
Americans make them sing ( thus the bald eagle comment which after discovering Cletus on YouTube I thought was a compliment)
  • Like 2
Whoa... there is definitely something wrong with that motor if that's all they got out of an 8374 EFR .92 iwg turbo on a stock RB26! I mean how can the iwg be to blame when it's simply a turbine housing that's still in the range of what most choose on the RB if you still stay external? (Referring to the 1.05).
I thought you were mocking me with the bald eagles comment... no sweat there I have a sense of humor (hell yeah brother).
I'll get some videos of the cars this week for y'all
  • Thanks 1
    • I've done a few BMS systems. Code in Canada use to force us to have any safety components outside of the PLC but with a code change back in 2018 I believe it was, we can now use safety PLC's to control everything. Sadly to your point, AB Guardlogix safety instructions for example are only available in ladder.  Machine safety is a very big thing here though, you're constantly forced to migrate to the next best thing by OSHA. I honestly prefer safety plc's, including anything from AB more then I do working with old school safety monitoring relays. PLC is only one portion of it, the rest of the electrical still has to follow to meet SIL (Mechanically linked dual contacts, bla bla)  Now tell me how to feel about safety over comm's (e.g Ethernet/IP CIP) on a unmaintained network haha
    • To your point, boolean logic. We're not only working with bools in ecu's, so it's very limiting. I wanted to setup a low WMI pressure alarm. After 1 second I want WMI line to hit 100PSI, 2 seconds 175PSI, etc. and trigger an alarm if it doesn't meet those thresholds. This would of taken me one very short line of text, but instead I had to bugger around with generic timers, conditions, etc. and so forth.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
