Impul Exhaust
Impul front pipe
X force split dumps
GT2860-7 turbos
HKS hard piping kit
700cc injectors
040 fuel pump
HKS Cams
Apexi FC ECU
Apexi Pods + Carbon airbox
Tuned by CRD - 21psi
308AWKW
3.5" Exhaust
GT2860-5 turbos
Pod filters
700cc injectors
Tomei fuel pump
Cams
Cam Gears
Fuel Regulator
Vipec Plug-in ECU
Tuned by ERD and EFI Performance at 19PSI
Ross Harmonic Balancer
Stock internals
480rwhp
VEHICLE: R32 GTR
ENGINE: RB26DETT Stock internals, Giken cam gears,
MILEAGE: 100,000+km's
OIL/WATER PUMP: N1 Water pump
OILING SYSTEM: Oil cooler
INJECTORS: Sard 700cc jectors
FUEL SYSTEM: Bosch 044 pump
TURBO SETUP: 2x Garrett GT2860R -5
MAP or MAF's: Z32 AFM's
INTAKE SETUP: Crap HKS mushroom pods.
INTERCOOLER: Greddy 100mm
EXHAUST: HPI bellmouth dumps, Knight Sports Metallit cat, 4" exhaust.
BOOST LEVEL: 18psi
FUEL: VPower
ECU SETUP: PowerFC/Launch control
POWER: 301.8awkw
Tuned By CRD
CYLINDER BLOCK NISSAN STD.
CRANK SHAFT " (FULL BALANCED)
PISTON " (86.0Φ)
CON-ROD "
HEAD GASKET TOMEI METAL (1.2mm)
INTAKE-EX.MANI GASKET "
CAM PULLEY " (ADJUSTABLE)
CAM SHAFT IN. APEX V-MAX (270° 9.15mm)
" EX. " (280° 9.15mm)
VALVE NISSAN STD.
VALVE SPRING " (REV.LIMIT 8300rpm)
TURBINE TRUST T88-34D 15cm
EX.MANI " ALL STAINLESS
WASTEGATE " TYPE-C HIGH FLOW
MUFFLER ORIGINAL TITAN 100Φ
CLUTH EXEDY METAL TRIPLE(TYPE Drag)
MISSION GEAR OS-GIKEN 1-2-3 CROSS RATIO
FRONT LSD. CUSCO 4-PINION 1WAY
REAR LSD. NISSAN STD. 4-PINION 2WAY
FINAL GEAR RATIO 4.1
ECU APEX POWER-FC D-JETRO
FUEL INJECTOR DENSO 720cc/min LOW RESIST
FUEL PUMP DENSO 280L/min ×3(DIRECT DRIVE)
FUEL DELIVERY PIPE TRUST 11.0Φ
FUEL REGULATOR SARD TYPE-J HIGH FLOW
FUEL CORRECTOR TANK " (5L)
MAX BOOST 1.6 K
MAX HORSE POWER 710HP
1995 R33 GTR
Performance list:
garrett 2860 -7 running 21psi drops to 19psi
tomei dump pumps
trust front pipe
ballistic cat
nismo catback
1000cc injectors
splitfire coilpacks
bosch 044 fuel pump
haltech platinum pro (mafless tune)
bp ultimate 98
280awkw at 19psi
Hi All,
RaceTech 86.5 mm piston
TOMEI 1.5mm @ 87mm metal head gasket with oil restrictor
Jun Oil Pump
Balance crank, piston, rod, clutch, main pulley
Refresh Standard Head
HKS step 1 IN/EX 264 cam
Jun Cam gear
BC valve spring
Greddy type 6 throttle intake manifold
SARD 720cc injector
HKS type fuel rail
Tomei Fuel regulator
Garrett GT35R AR1.06 split type
aftermarket ex manifold split type
Tial 44mm ex wastegate
Power FC D Jetro
ETC ETC...
VEHICLE: R33 GTR
ENGINE: RB26DETT Forged pistons , rods , crank , oversized .20 , balanced blueprinted
HEAD: Ported polished , hks step 1 cams , Greddy adjustable cam gears
MILEAGE: 97,000
OIL/WATER PUMP: N1 Water pump , N1 oil pump
INJECTORS: 800cc injectors ,
FUEL SYSTEM: 2X highflowed GTR pumps
TURBO SETUP: 2x Trust/greddy T617z (10cm)
INTAKE SETUP: Greddy Hard pipe
INTERCOOLER: standard
EXHAUST: Hks twin 2.5 higflow dumps , single 3.0 inch centre with 250cfm cat and resigantor , hks twin rear mufflers
BOOST LEVEL: 16psi 22psi
FUEL: ultimate 98 ,, soon E85
ECU SETUP: PowerFC
POWER: 360 all4 KW @ 1.6bar
Looking for 400kw @1.4 BAR E85tune Soon To Come!!!
  • 1 month later...
1994 BNR32
Engine: 150,000km standard head and all internals. Sump baffle.
Turbos: Genuine r32 NISMO turbos.
Boost: 8psi
Mods:
Slipt dumps
HKS front pipe
Fujitsubo cat back
Highflow panel filter
Power: 205rwkw
R32 GTR 1990
STANDARD HEAD AND STANDARD REBUILD 30,000 AGO
R32 N1 TURBOS
Z32 AFM
690cc INJECTORS
POWER FC
3 INCH EXHAUST
NISMO IN TANK PUMP
TUNED BY SEAN AT EFI PERFORMANCE
POWER: 98 PUMP FUEL @ 17PSI = 330WHP
E85 @ 17PSI = 380WHP
E85 @ 20PSI = 420WHP
:worship: E85
VEHICLE: 1997 R33 GTR V-SPEC
ENGINE: NEW CUSTOM RPM STAGE 1 LONG MOTOR, NEW R34 GTR HEAD, NEW GT 2860R-5 TURBOS, Standard Cams, Tomei Cam gears, NI OIl and Water Pumps.
Trust Oil Coiler & Sump
Trust Blow-Off Valves
SARD 800cc Injectors
SARD Fuel Regulator
HKS Fuel Rail
Apexi Power FC
New Nismo AFM's
Bosch 044 Intank Fuel Pump
HKS SIlent Exhaust 3.5"
X-Force Exhaust Manifold & Dump Pipes
Standard Aiirbox - No pods
HKS EBC
OS GIKEN Twin-Plate Clutch
365 RWkW on 19psi. I will be changing exhaust manafold and dump pipes to new Tomei items next year, and most likely a new RPM exhaust system. This will gain another 20 rwkw.
1993 R32 GTR
Modifications:
Unopened
Bosch 040
Apexi Power Intake Kit
Custom Cold Air Intake / Heat Shield
3.5" Stainless Invidia Dump Back Exhaust
Larger Front Mount Inter-cooler (specs unknown)
MS T-BAC 3 Boost Controller - Piece of shit
Nistune
HKS Adjustable Cam Gears
Boost Controller and replacement clutch required.
Results: 253Awkw @ 14PSI - PULP
  • 3 weeks later...
Stock 2.6L running 150psi compression in all cylinders
Nismo GT lemans turbos
nismo 550cc injectors
Apexi power FC
3 inch dumps, with after market front pipes and 3 1/2 inch exhaust, (high flow cat and cannon as muffler)
Twin apexi intake filters
N1 oil pump
Tomei sump baffle
Made 307RWKW untill AFM's were maxed out, second line was a safer tune at 285 with more boost through mid range
Autech 260RS
10 PSI, 11.6 AFR and very safe timing ( i'm told its got 2-3 degress in it) this tune was just to get the car running after over 12 months off the road.
Stock turbos
Stock injectors, FPR
Walbro fuel pump
Power FC
AVCR
Z32s and shitty pod setup
HKS 264 deg cams
HKS cam gears
HKS hard piping kit
Yoshida Garage custom ported head and port matched exhaust manifolds
Greddy extended split dumps and front pipe
Fujitsubo Cat back
De-Cat pipe
N1 oil and water pumps
244KW at the wheels
Built at Japlink Motors
  • Like 1
99 R34 GTR non-vspec
Unopened engine. Done approx 70K.
100K service done with all OEM parts, including water pump, timing belt, bearings and seals.
Adjust Cam gears
Garrett -7s
Stock injector
Stock fuel pump
Stock air box with high flow air filter
Stock intercooler with full HKS hard piping
Nismo fuel regulator
Spitfire Coilpacks
Iridium spark plugs
EVC 5 boost control
Power FC
Stock dumps and manifolds
Full NISMO WELDINA NE-1 Exhaust De-Cat
Koyo Radiator
EXEDY hyper multi twin plate clutch
Tuned @ Racepace
Pulled 288.7 RWKW @ 18.2 psi, on BP 98.
Bought Sard 700cc and Bosch 044, but told no need to install them as I had -7 only. Stock injectors cycle duty @ 98.8%. Knocking rarely exceeds 25 under the sun. Feels hell a lot better to drive.
  • 3 weeks later...
Adjust Cam gears
Garrett -7s
Stock injector
Stock fuel pump
Spitfire Coilpacks
Iridium spark plugs
EVC 5 boost control
Power FC
Koyo Radiator
Tuned @ Racepace
Fitted a new set of Sard 700 cc injectors, Re-tuned @ RE Customs, fixed up boost drop @ high rpm.
286AWKW.
Andrew your first dyno sheet power output looked familiar lol.
Here's mine
Stock engine
Stock fuel system
stock afms
Apexi PFC
Bigger intercooler
2860-9's, stock actuators
Bigger front pipe and exhaust, ceramic cat
panel filter
Boost controller
Injectors at 92% duty
(Figure is at the rear wheels)
Have since fitted, HKS actuators, nismo metal cat, HKS hi power silent exhaust. New dyno sheet will be done at some point.
Sorry for the poor quality picture, don't own a scanner at the moment.
Car was having boosting issues and dumping so much fuel at 5200RPM it was choking itself out. Almost like it was hitting a fuel cut/ rev limiter.
Fuel is E85
Engine stock top and bottom end
HKS GT2530 turbos
HKS dumps
ID1000 injectors
Nismo fuel pump
HKS fuel rail
Tomei FPR
Nismo MAFs
M's induction pods
Veilside teardrop titanium exhaust
Edited by Ricky Ricer
gtr-r34 vspec2
TOMEI Head gasket
TOMEI RB26DETT Camshaft
TOMEI Adjustable Pulley
NISMO timing belt
NISMO racing spark plugs
NISMO Fule Pump
NISMO intake plenum
NISMO 600CC Injector
HKS GT-SS Sports Turbine Kit
APEXI Power FC
NISMO Air Inlet Pipe
NISMO air cleaner
NISMO Air Flow Meter
NISMO R34 GTR Z-Tune triple layered intercooler
NISMO Oil Cooler Kit
HKS stainless front pipe
SARD cat converter
FUJITSUBO exhaust
TOMEI Manifold
304 kw at all wheels, running 21.5 psi. Am i maximising my set up ? or, there's more potential in it ?. All comments are appeiciated, thanks.
R33 GTR v-spec
95oookm
Mods -
Garrett 2860-5
R34 gtr dump pipes
HKS cam gears
Jun 264 cams
Nismo fuel reg
Nismo fuel pump
Hks 600cc injectors
Z32 afm's
Apexi filters
Result 334kw @ wheels on 1.2 bar
Need to upgrade exhaust as quiet restrictive and restricting power
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
    • Should have asked what is the car?
    • I've had two super conflicting experiences with blue slips. My 30 year old E39 waltzed through with no issues but my brother in law was knocked back on 12 y/o 3 series due to wiper blades and some cracking in a control arm bush.  What kind of coil overs? Do you want to keep them after?  If it was me I'd get some dirt cheap shocks and springs from eBay or scumtree. Not ideal but will get you over the line and might even be less than $1k.
