R33 GTR V-spec EAT26
97000km
Mods -
Garrett 2860r-5
Tomei Dumps
Nismo fuel reg
Nismo fuel pump
Nismo 600cc injectors
Cooling pro 600x300x100 Intercooler Core
HKS Intercooler Hard Piping
K&N Pod Filters
Power Fc
Greddy Profec B Spec II Electronic Boost Controller
Result 274Kw @ wheels on 18Psi Tuned by John @ Mercury Motorsports
Plan to upgrade and put in
Tomei cams and cam gears.
Custom 3" to 3 1/2" front pipe.
97000km
Mods -
Garrett 2860r-5
Tomei Dumps
Nismo fuel reg
Nismo fuel pump
K&N Pod Filters
Power Fc Greddy Profec B Spec II Electronic Boost Controller
Tuned by Sean @ EFI Performance at 21.5psi :D extremely happy.
1989 R32 GTR
HKS F-CON V PRO 3.0
Greddy Air Intake Plumbing,
HKS pod filters,
Sard 700CC Injectors
Rebuilt engine with HKS internals (engine built in Japan and exact spec unknown)
Unknown Turbos
Unknown fuel system
Unknown dumps
Custom stainless front pipe back exhaust, no cat no resonator, 3.5"
400.1rwhp @ 20psi (drops back to 18 - limit of turbos)
Edited by Ten Four
N1 GTR turbos.
Apexi power FC
Turbosmart e-boost2
BP ultimate
bigger cams
Adjustable cam gears.
3inch exhaust.
Bigger fuel injectors.
Bigger fuel rail.
Thats about all i know the car has on it, as I purchased it with alot of stuff already being done to it.
  On 10/02/2011 at 7:29 AM, Ricky Ricer said:
Sorry for the poor quality picture, don't own a scanner at the moment.
Car was having boosting issues and dumping so much fuel at 5200RPM it was choking itself out. Almost like it was hitting a fuel cut/ rev limiter.
Fuel is E85
Engine stock top and bottom end
HKS GT2530 turbos
HKS dumps
ID1000 injectors
Nismo fuel pump
HKS fuel rail
Tomei FPR
Nismo MAFs
M's induction pods
Veilside teardrop titanium exhaust
New dyno sheet. E85, 18PSI (1.35bar)
i forgot to post my results in here:
Unopened RB26DETT
Stock cams
HKS Cam gears (inlet at 0 Exhaust retarded 2 degrees)
-7 turbos
TOMEI s/s dump pipes
3.5" do luck exhaust
Trust 100mm fmic
walbro fuel pump
stock fuel reg
Sard 700cc injectors
Power-FC D'jetro
398.3hp at all 4 hubs @ 1.2bar
Power vs torque
Power vs boost pressure
Car also ran 353.5hp on a roller dyno with the shaft out
Car seems to be getting wheelspin on the dyno as it flat lines at 350 for quite some time... damn roller dynos!! lol
Edited by snozzle
hey guys
r33 gtst with engine conversion to rb26dett
unopened motor
sard fuel reg and rail
e-boost 2
bosch 023 intank pump
steel wheeled standard turbos on 15psi
and standard ecu made 246rwkw
  • 3 weeks later...
s13 silvia with r34 v-spec engine
stock r34 turbos
hdi 600x300x100 front mount
stock r34 dumps, aftermarket 2.75" to 3" front pipe, decat pipe , 3" decat back
hks cam gears
16psi boost, HKS evc6
Microtech LTX12s tuned by 101 motorsport
HKS pod filters
361bhp worth of wheelspin
300wKw at 20psi on 98RON
R34 GT-R V-Spec II
* -7 Turbos
* 700cc Denso Inj
* Power FC D-Jetro
* Blitz front pipe
* K & N Panel filter
* Greddy DSBC
* Tomei Poncams 260/10.25
* Tomei Cam Gears
* Bosch 044 fuel pump
* Nismo 3" Exhaust
* Hi Flo Cat
93 R32 Gtr V-spec II 100xxx kms
hks 2530 turbos
greddy y pipe
hks catback
catco high flow cat
bosch 040 pump
apexi intake
greddy profec b spec II boost controller
splitfire coilpacks
PFC+tune at dart automotive @ 14 pound boost (254.3 kw) bp ultimate98
everything else completely stock...
Edited by DVSTRK
Stage1
- Nismo Weldina front pipes
- highflow cat
- Nismo factory optioned exhaust
- Cam Gears
- PFC
- K&N panel filter
- Z32 AFM
parts alone cost around $5,300.00
standard power: 189 rwkw
after dyno tune: 270.8 rwkw
power gained: 81.8 rwkw
Autech 260RS
16.5 PSI, 11.6 AFR and mild timing, more in it just not wanting to push the car too much just yet.
Running Caltex 98
Stock bottom end
Stock FPR
R34 GTR turbos
Nismo 555cc injectors,
Walbro fuel pump
Power FC
AVCR
Z32s
Greddy suction kit and cold air box with factory snorkel
HKS 264 deg cams
HKS cam gears
HKS hard piping kit
Yoshida Garage custom ported head and port matched exhaust manifolds
Greddy extended split dumps and front pipe
Fujitsubo Cat back
Gutted cat
N1 oil and water pumps
277KW at the wheels
Built and tuned by Japlink Motors
Edited by numleg
here is mine it needs to be returned to finish it up. It had 0 km when it was tuned
motor built by red r racing
Pon cams type b's
Tomei valve springs
tomei cam gears
Cp pistons
Eagle rods
2860-5 tubros
r34 gtr v spec dumps
veilside front pipe
z32 afm's
stock air box
1000cc injectors
Power fc
320 awkw or (430 hp ) at 20 psi but drops back to 18 psi
  • 3 weeks later...
My R32 GTR
Tuned today by Croydon Racing Developments.
Mods.
Arias Forged Pistons
HKS 264* Cams
SARD 720cc Injectors
Tomei Cam Gears
Tomei Sump Baffle Kit
Yellow Jacket Coilpacks
NGK Spark Plugs
Apexi AX53B60's Twin Turbos
Apexi Power FC /w Hand Controller
Z32 AFM's
JUN Oil Pump
Nismo Front Pipes
HKS Cat Back Exhaust
Custom Catch Can
Earl's 18 Row Oil Cooler /w Braided Lines
ARC Front Mount Intercooler
Turbosmart T Piece Manual Boost Controller.
Aftermarket Fuel Pump
Stock Airbox
Stock Dumps
334.3 AWKW @ 21psi
Edited by Sloane
97 R33 GT-R ~88,000km
Mods:
-Std internal RB26
-Std injectors
-Std dump/JJR front pipe/high-flow cat/catback
-Bosch 044 fuel pump
-Turbosmart E-Boost street boost controller
-Apexi PowerFC
-Gates Racing cam gears/timing belt
-RB26 high-flowed steel wheeled turbos
-Protek tuned 258awkw @~16psi
89 R32 Gtr
Tuned by Ben at Racepace....
Mods
R33 GTR N1 24U Motor 32000 Km (Brand new motor fitted not a rebuild)
R34GTR N1 BB Turbos
Greddy Adjustable Cam Gears
HKS Drag Intercooler 600x300x100
Sard 800cc Injectors
Trust 3-4.5" Exhaust
R34 GTR V Spec N1 Dumps & Manifolds
Stock Afm`s
Bosch 044 Mounted Intank
Power Fc
Twin Apexi Pod Filters
Greddy Catch Can
Greddy Remote mount Oil Cooler Kit
Custom Hard Piping Kit
320AWKW @ 20Psi
Am planning on putting it back on the roller in a few weeks after a few small things are taken care of.
New dyno sheet to come....
Edited by sven
1995 BCNR33
120xxx std engine
mod list:
2860-9 turbos
Nismo fuel pump
HPI dump pipes (76mm diameter)
Z32 AFMs
Tomei adjustable cam gears
Kakimoto exhaust
high flow cat
Apexi Power FC Pro
Standard air box with blitz drop in filter
The result:
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
