1990 GTR R32
stock bottom end
260cams
Gt35 turbo
650cc injectors
big intercooler
twin 44 pumps
haltech pro
20psi
3.5 exhaust
340awkws tuned by JEM
cars now getting fitted with head studs,1000cc injectors,E85 conversion,so with a bit more boost hoping to get around 380kws,see how we go!
Forgot to post my results in here last year.
I have now upgraded a few things this year and I will post the differences in mods and power/response gains.
Last Years Results using:
1997 R33GTR V-SPEC Series 2
New RacePace Stage 1 R34 RB26 Engine
New R34 GTR Head
New Garrett 2860r-5 Turbos with 14psi actuators
OEM Camshafts
Tomei Cam Gears
OEM EX Manifold
X-Force Dumps
HKS Front Pipes
HKS Hi-Power/Silent Exhaust System
Trust/Greddy Sump Kit
Trust/Greddy FMIC 100mm Thick/The Big One
Trust/Greddy Alloy Radiator
Trust/Greddy Oil Cooler
Trust/Greddy Type R BOV's
RPM Oil/Water Seperator/Catchcan
Power Fc HKS EVC 5 (Black Edition)
New Nismo AFM's
Sard 800cc Injectors
Sard FPR After Market Fuel Rail/HKS copy?
Bosch 044 intank pump Series 3 GTR Gearbox with short shifter
OS Giken Twin Plate Clutch & Flywheel
Tuned by RacePace 365rwkw @ 19psi
Upadates From Earlier This Year:
New RacePace 3.5" Custom Exhaust System with Twin Pipes
New RacePace Tuned Length Front Pipes
New Tomei 72mm Dumps (older style)
New Nismo Super Coppermix Twin Plate Clutch & Flywheel Kit(COMP MODEL)
Tuned By RacePace 380rwkw @ 20psi
Cant Get these pics working will try again tmrw.
Edited by PranK
Fix link
1996 R33 GTR
Mods
Nismo front pipes and Apexi Exhaust with 100cell metal cat
Nismo intake and HKS IC
APEXI Suction and pod filters
Aftermarket cams ?? 9.1mm lift
HKS Cam gears
N1 R33 Turbos
21PSI
??? bottom end
Nismo FPR
stock injectors
stock AFM
301AWKW
*will post dyno sheet tonight*
R33 gtr
ID 1000's
Walbro 400lph
Powerfc
Greddy profec b spec 2
Tomei Cam Gears
NPC 10" sprung button (650hp)
Big front pipe
3" cat back
100cell cat (letting me down)
-9's with 1bar actuators
Standard afms (letting me down)
Standard airbox
Standard dumps
Heres the dyno sheet. Can a mod please join it to my post?
Updated with some Cam Gears dialled in for a little extra down low and a bit more up top.
-7's
Forged bottom end
Z32 AFM's - Apexi Super suction
3 - 3 1/2" Exhaust
ID1000cc injectors
Nismo fuel pump
Stock cams
Tomei adjustable cam gears
Power FC
Hi flow cat (apparently!)
Topped out at 322kw, backed off a bit to 315kw.
Love to get anyones feedback on the power and curve! Seems a bit soft to me??
1993 R32 GTR
Rebuilt RB26
2860-7's
Haltech - mafless
Tomie Type B cams, Adjustable cam gears
700cc injectors
Nitto/JE pistons
98ron
326kws at 18psi
350kws at 21psi
1993 R32 GTR
Rebuilt RB26
2860-7's
Haltech - mafless
700cc injectors
Nitto/JE pistons
98ron
326kws at 18psi
350kws at 21psi
Correction - ^ 2nd run at a different Ramp Rate skewing output figures ^
1996 R33 GTR
Mods
HKS Cam gears
N1 R33 Turbos
21PSI
??? bottom end
Nismo FPR
stock injectors
stock AFM
301AWKW
New 1000cc injectors and E85 now 341awkw
dyno.pdf
5 months ago.
R33 GTR Vspec
Standard Motor
2860-5s
blitz dual intake
1000cc ID's
Haltech Pro Ecu
PWR intercooler
Greddy Cam gears
Walbro Fuel Pump.
330Awkw
new build with single kit and other stuff now.
new results with dyno shortly
- Desno 800cc injectors
- 2860 -5 Turbos
- Tomei Cam gears
- Power FC and Controller
- Z32 Afms
- Apexi AVC-R Boost controller
- Trust 100mm Intercooler
- Tomei Expreme TI cat back
- Venom 100 cell 5 inch body cat
- Apexi Super Suction Kit Pods
- Air Box and Cold Air Intake
Engine
- Forged Pistons with standard Rods
- Metal head gasket
- GTR crank
- ACL bearings
- Extended Sump
- New Rings
- Honed Bore
Pretty happy with it. Much more responsive and when it hits 4000rpm wow.....
Thinking some drop in cams, push a bit more boost and ill be done
R34 GTR V-Spec II
RB26 Standard bottom end
Apexi Power FC D-Jetro
Tomei Poncams
Sard 700cc Injectors
HKS Fuel Rail
Sard FPR
Tomei Exmprere Exhaust Manifolds
HKS 2530 Turbos
HKS Wastegate actuators
Trust Intercooler
Trust Hard Pipe Kit
K&N Pod Filters
Nismo Z-Tune (cast) dump pipes
Power House Amuse Titanium Front Pipes
Hi flow 3" Metal Cat
Tomei Expreme Ti Cat Back
349.6kw @ 19psi
391.9kw @ 22psi
I am going to stick 19psi due to stock bottom end.
22 PSI BOOST
19 PSI BOOST
Here's mine:
R34 GTR VS2 Nur
N1's
HKS Actuators
Racepace 3.5Inch full exhaust
Nismo Twin Coppermix (Comp)
HKS EVC-S
HKS Cam Gears
Nismo Fuel Pump
Nismo FPR
Nismo Airflow Meters
ID1000's
E85
Power FC
379kw @ 21psi.
  • 4 weeks later...
  • 3 weeks later...
Capacity 2.6L
R33 GTR crank
Tomei rods
CP pistons
Jun Oil pump
Standard water pump
Standard sump filled to 6L (Race pace sump to be installed soon!!)
Tomei type B cams
Breathers from sump to head (passenger side)
Tomei oil restrictor
Tomei cam gears
Exhuast and Turbo
Full-Race twin scroll manifold
BW S300 83/75 .91 housing
4inch dump pipe
High flow cat
3.5inch exhaust after Cat
Twin Tial 38mm waste gates
Koyo 100mm intercooler
Electronics and ignition
Link G4 ECU
Ross balancer and Crank trigger
Ethenol Sensor and digital readout screen
Split fire coil packs
After market Ignitor
New OEM coil pack loom
Copper plugs
Fuel system
Nismo intake Fuel pump
ALPHA OMEGA Billet steel CNC'd Surge tank
Twin Walbro 400LPH pumps in surge tank
Sard FPR
ID2000cc injectors
Twin entry fuel rail
Braided lines all round
Duel filters
E85 Tune, top line is just more boost through the mid range
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
