R33 GTR
Racepace built engine
Racepace cam gears
Power Fc pro
Nismo afm
ID 1000's
Walbro e85 pump
Tomei dump pipes
Modified Apexi front pipes
-5's turbos
Racepace 3.5inch exhaust
High flow cat
Nismo coppermix twin plate clutch
K&N panel filter
Trust front mount cooler
Racepace 9.5l sump
N1 oil pump
N1 water pump
Oil catch can
Large oil cooler
Aluminum radiator
360kw at 19psi on E85
Hey There,
my car is a 95 S14,
Fully built RB,hks stroker 2.8,
290/11.5 tomei cams and complete tomei head,
GT4202R with Full race manifold,
1600cc injectors, 3X044 pumps,
Link G4 ecu, Ls coils,
Made 767hp (572kw) with 98 fuel @ 17-18PSI
(dyna pack hub dyno)
  • Like 1
  • 3 weeks later...
forged bottom end
stock cams and valve springs
metal head gasket with ARP head studs
precision 6266 0.84 T4 divided rear
3.5" dump/cat back
GFB EX50 50mm external gate
1200cc injectors with walbro e85 pump
power fc d-jetro
409rwkw @ 26psi on Caltex eflex E70, at the limit of stock cams and injectors :(
  • Like 1
RB26dett (120,000kms)
Stock internals
T04-r Turbo
HKS copy manifold (braced)
Tial 44mm v-band wastegate
3" stainless exhuast with 1 HKS rear muffler
HKS intercooler kit
Greddy oil cooler kit
Greddy magnetic sump plug
Nissmo oil filter
Koyo copper radiator with viscous and shroud
HKS air filter
HKS earth kit
Yellow jacket coil packs
modified factory sump
N1 water pump
surge tank setup with walbro and bosch 044
stock injectors
Link G4 ECU
10 psi boost
  • 1 month later...
R34 GTT
R33 GTR engine
Metal Head Gasket
Nismo AFM's
550cc injectors
Super Spark coil packs
Nismo fuel regulator
BMC air filters
Blitz intercooler
Greddy external oil cooler and GREX oil filter relocation kit
Apexi Power FC ECU (R33 GTR)
3.5" Exhaust cat back - stock dumps, front pipe and cat.
Driveline
Rebuilt 5-speed transmission less than 5000 km's ago
Jim Berry 5 puck custom race clutch
Bought this and just ran it up to see if its safe - AFR's are low 10's so its way over fuelly...will get back with an update when retuned!
  • 3 weeks later...
1990 r32 gtr
PFC
3.5 inch exhaust, unknown aftermarket dumps
Apexi pods
removed boost restrictor
rest completely stock
228kw @ 13 psi
Now with Garrett -5's
Turbosmart eboost street
289kw @ 15.5 psi
I have 2 R32 GTR's
R32 GTR 1989 Drift car
crank setup balanced
Factory block
Factory head (cams, cam gears and ports etc all stock) with heaver valve springs
factory rb25 harmonic balancer
Steel head gasket
Chinese manifold twinscroll t4 flange
garrett gt3582
tial 44mm vband gate
cp forged 86.5mm pistons
eagle forged rods
factory crank with collar
nitto oil pump with 1 spring removed
1000cc fuel injector clinic
tomei fuel reg
10an feed
bocsh 044
link g4
made 385kw atw and 2250nm on 18 psi at 7000rpm on BP 98, on a dynapack hub dyno.
tuner said factory cams ran out of puff and were making almost no gains with higher boost.
looking at doing cams and cam gears etc in the future to get more revs
1991 R32 GTR (brought this one this way with intentions to modd then found out it had all this gear
r33 rb26dett
factory block
factory crank
factory harmonic balancer
factory rods and pistons as far as i can see
factory manifolds i think
aftermarket aggresive cams (ruff idle)
bigger injectors 600cc maby
power enterprise ball bearing pe1520 turbos and dump pipes
steel head gasket
hks actuators
am guessing oil pump is after market
unsure of fuel pump
link g4
makes 304kw on 15.5psi peak power at 7200rpm and 95 octane fuel (limit 7500) on a dynapack dyno
will take for a re-tune with my tuner at some point once ive sorted a few things and try it on 98
any ideas for good simple mods from here?
R33 GTR
Nismo 1.2mm metal head gasket
Racepace cam gears, but not yet adjusted
Garrett -9's with 1 bar actuators
Nismo fuel pump (rewired)
Mine's front pipe
3" test pipe
3.5" Tomei Ti Expreme
Greddy Profec B spec 2 (disconnected)
17psi on standard ecu
Soon to be added: PFC, ID1000, Z32 AFM, E85
R32 GTR
HKS 2530's
Apexi Power FC
z32 afms
Apexi Pod filters
3.5" catback exhaust
HDI boost controller
R34 GTR Dumps
ID1000s
Walboro 460lph fuel pump
Splitfire Coilpacks
333kw @ 20psi
Up next: Cam gears, full 4" exhaust, E85
Edited by France
  • 3 weeks later...
2002 R34 GT-R
Power FC D-Jetro
Nismo in-tank fuel pump
Sard FPR
HKS fuel rail
Unknown injectors
Stock 2.6lt bottom end
Stock head + Tomei Tye B cams
Stock cam gears
Tomei Expreme exhaust manifolds
HKS 2530 Turbos
HKS Actuators
Trust Intercooler
Nismo cast dump pipes
Midori Seibi 90mm titanium front pipes
3" high flow cat
HKS Super Turbo cat back exhaust
19/20psi
1st Dyno Graph:
Old Tune: 349.6 rwkw (4th gear)
New Tune: 353.4 rwkw (4th gear)
2nd Dyno Graph:
New Tune: 359.6 rwkw (5th gear)
Apparently the dyno was hitting some limiter in 4th gear?
Apparently that is why you see the sudden drop at the end of the power curve?
But the 5th gear run allows the run to rev right out?
Can someone explain this to me?
  • 1 month later...
Had the Stagea tuned after a few upgrades and the switch to flex-fuel/E85.
Very happy with how quickly it comes on boost but looking at the dyno graph it does start to fall over pretty early. I'm thinking that maybe the 3 inch JDM cat -back (probably got a 2.5 inch restrictor) is starting to hold it back.
Tomei valve springs
ARP head studs
-9 Turbos
Nismo Fuel Pump
Xspurt 1000CC injectors
Walbro E85 fuel pump
Haltech Plugin ECU, 3 bar MAP sensor - Flex fuel and boost control
Zeitronix ECA and AFR meters
Plazmaman 76mm intercooler
Splitfire coil packs
Autech 260RS
Stock bottom end
Stock FPR
R34 GTR turbos < Terry's old turbos :whistling:
Nismo 555cc injectors,
Walbro fuel pump
Power FC
AVCR
Z32s
Greddy suction kit and cold air box with factory snorkel
HKS 264 deg cams
HKS cam gears
HKS hard piping kit
Yoshida Garage custom ported head and port matched exhaust manifolds
Greddy extended split dumps and front pipe
Fujitsubo Cat back
Super hi-flow cat
N1 oil and water pumps
Turbosmart BOVs
339.9 AWKW & 830FtLb @ 23 PSI on E85
263.7 AWKW & 533FtLb @ 13 PSI on E85
312.5kW at 16.5 psi
272kW at 13 psi
Edited by numleg
R34 GTR Vspec
Standard except for:
1 bar boost (restrictor removed)
Apexi Power FC
Catco metal cat
Apexi N 1 cat back
Tuned by Paul at Pulse Racing
Wasn't expecting this much power atw..... Not sure if inflated but Def happy with the response. Pulls much harder and feels smooth.
  • Like 1
  • 3 weeks later...
Heya guys, my setup.
R32 GTR RB26
Assembled, blueprinted and balanced by Tarmac Solutions in Sydney
OEM rods/pistons/crank (with moly rings)
Garrett GT2860R-7 turbos on OEM manifolds (port matched to turbos) and dumps
Tomei PONCAM Type-B cams on OEM valves and springs
Haltech Platinum Pro
550cc injectors with OEM pump, reg and rail
2.5" front pipes to 3" exhaust (no cat, streetable Jasma muffler)
Twin filter pods, no MAFs
OEM intercooler and pipework
Yellow Jacket coils
Reliability:
Tapped crank oil feeds
Crank collar
Tomei oil pump
9L baffled and gated sump
N1 water pump
ACL Race Series bearings
Permaseal MLS-R head gasket
OEM gasket kit
340kw (~450hp) @20psi with fat midrange and great pull from 4500rpm (9000rpm redline)
Previously made ~330kw @20psi with more power under 4000rpm. Only change was a refresh (hone, rings and bearings) and Tomei cams.
This setup found 20-30kw from 4500rpm upwards and makes for a much more 'thrashable' setup on track.
Cruising fuel consumption is down (we pulled fuel out under 4000rpm and added fuel above that rpm)
http://youtu.be/yZWgEWPTFqc
I don't care for the number it produced, I only care for driveablity, thrashability and reliability. With more area under the curve and better economy around town, I'm more than happy with the addition of cams on an otherwise pretty tame setup.
Mark :)
  • Like 2
  • 5 weeks later...
  • 3 weeks later...
R32 GTR : Built & Tuned By Race Pace Motorsport
Racepace Stage 1 Motor (with N1 Block)
Garrett 2859-9’s (GT-SS) – Racepace Modified
HKS Adj. Actuators – Racepace Modified
Power FC
Racepace Adj. Cam Gears
Nismo AFM’s
Standard Airbox with Blitz Filter
Nismo 600CC Injectors
Nismo Fuel Pump
Splitfire Coilpacks
Exhaust : Tomei Dump Pipes>Racepace 3” to 3.5” Front Pipe>Racepace Spec High Flow CAT>Racepace 3.5” Catback with two custom stainless steel mufflers.
Other Info –
Tomei Oil Pump
Race Pace 9L Extended Sump
SFIDA 19 Row Oil Cooler
Ron Davis 3 Layer Alloy Radiator
Factory Intercooler
N1 Water Pump
Nismo Thermostat
Nismo Coppermix Twin Plate Competition Clutch
335.9rwkw @20PSI - 98RON Track Safe Tune
  • 3 weeks later...
On 11/01/2014 at 8:49 PM, portaz said:
See 400kw thread for specs tuned by jez now just have to get traction in high 3rd still pushes sideways !
Rb26
Eagle rods
Cp pistons
Tomei type b cams
Tomei gears
Mild head porting
Exh manifolds ported
Rotomaster 2860-5
2200cc injectors
120mm intercooler
Adaptronic ecu
Lc-1 wideband
Tomei dumps
Jim berry full Monty clutch
Apexi front pipe
100 cell cat
3.5" exh to x force cannon
B/c valve springs
Mac valve controlling boost via ecu
Best run of 360. On low but left it fat at 350 ish 19 psi
426 kw on 26 psi both united e85
Interestingly was 415 and we cracked airbox (std) and jumped to 426 so I will mod it. Another tuner said couldn't crack 400 with pump (walbro e85) and airbox or that I couldn't go over 24 psi on -5 guess he was wrong
yes, you can thank me later Portaz (saves people searching for your specs)
Edited by PranK
Fix links
  • Like 1
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
