1990 R32 GTR - Standard motor - 105,000km's
Garrett 2860R turbos
Split Dumps
3" Exhaust
600x300x115 cooler
Apexi PFC
Hybrid Boost Controller
Splitfire Coils
Car made a surprising 238KW @ 4 wheels on 14 PSI and 275KW @ 4 wheels on 18psi.
Will post pics tomorrow.
Edited by markk
  • 3 weeks later...
I own a 1989 gtr with r34gtr turbos running 17psi with 9% air fuel ratio on a re mapped standard computer i am making 260rwkw. Standard internals and cooler etc.
I have just puchased SARD 700 injectors, turbosmart fuel regulator, bosch 044 fuel pump, garret -10 turbo's, power fc d-jetro, greddy profec-b specII, dump pipes, tomei 260 cams and adjustable gears, nismo twin plate clutch, 600x300x100mm intercooler.
I am aiming for anything over 300 to 340rwkw safe with standard internals. All these parts, i have been told, will make me 400+rwkw with internals to match and hold.
93' R32 GTR
hks 25/30 x 2 turbo's
trust 550cc injectors
apexi power fc
blitz boost controller
large front mount
hks pods
3.5'' exhaust
nismo g-max twin plate clutch
376rwhp @ 1.2 bar. stock fuel pump run out of legs :laugh:
1992 BNR32 GTR - 78,000klms
HKS GT-SS Turbos
Port matched standard manifolds
HKS Split Dumps
CES Custom Designed front Pipes
3 1/2in Catco Metal Cat (5in Body)
Trust Cat Back Exhaust
Air Pod Filters
Demeshed Standard AFM's
PWR Intercooler
Sard 700cc Injectors
Bosch 044 Fuel pump, intank
OS Giken Cam Gears
E-Boost 2 Boost Controller
Power FC
HKS GD Pro Twin Plate Clutch
The Car was tuned by APC for mid range torque and power and got a max of 280awkw @ 20psi. The attached dyno sheets are from the recorded run and show the three different boost settings.
Dyno_after_APC_tune_190806.pdf
Edited by SLVR32GTR
01 R34 GTR V-spec II
standard turbos running 1 bar controlled by HKS EVC 5 ebc
power fc
custom 3 1/2 inch exhaust from turbos back
HKS adjustable cam gears
Trust R-SPL intercooler
HKS fuel rail
700cc injectors
Trust lightened pulley kit
260 awkw on dyno dynamics dyno not shootout mode i think it equates to roughly around 290 rwkw tuned by Gavin Woods on the gold coast
1993 R32 GTR
Apexi panel filter in standard airbox with CAI
HKS S/S front Y pipe (standard dumps)
HKS Supper Dragger exhaust
Rebuilt standard turbos with steel exhaust wheels
Apexi PFC
Varrible cam gears
Standard everything else
265rwkw @ 16PSI
Engine feels strong & responsive throughout rev range. Happy with result.
96' GTR33
Garrett 2860R-5(HKS 2530 Equivalents)
Hks Split dumps
Tune agent manifolds
Nismo oil pump
Nismo water pump
Nismo fuel pump
Nismo fuel regulator
700cc Sard injectors
Iritop sparks
Split-fire coils
Trust oil cooler,with relocation filter.
Cusco catch can
Tomei air intake with Pods
3"Cat, Custom 3" exhaust,3" Resinator :) with 3" Xforce Hotdog
Apexi power fc
AVCR boost controller
ARC FMIC
HKS Cam gears
@ 4 Wheels
Max Power 260.3kW @7183RPM (1.3 Bar)
Max M.A.P 223.6kPa @7055RPM (1.3 Bar)
Future plans> Z32 AFMS, Tomei Poncams 260 Degree with 9.15 lift . :)
91 BNR32
Tomei 260 9.15mm
Tomei valve springs/guides
Ported head, squish areas removed on exh side
Nismo 1.2mm HG
Tomei 86.5mm pistons
Trust twin entry 115mm intercooler
Stainless exh manifolds
Tomei dump pipes
HKS 85mm front pipe
Apexi 90mm exhaust
Ball bearing HKS GT2530-Nismo Group A hybrid (2530 turbine wheel, housings, core and Group A comp wheel and housings)
HKS actuators
Getrag 6 speed, 4.11 final drive.
560hp @ 4 wheels 1.45kg
415kws @ 4 wheels (700hp flywheel)
Dynapak hub dyno
Edited by RH9
GTR R32 November 1993
Engine 4000kms
R34 GTR N1 Turbos (front one stuffed)
Nismo fuel pump
SARD 700cc injectors and fuel reg
Splitfire Coils
N1 Oil pump
JE Pistons
Tomei Poncams 260 degrees in/ex
Eagle rods
Gates Timing belt
Os Giken Adjustable Cam Gears
Os Giken Twin Plate Clutch
HKS Super Drag 3.25" Exhaust System
TRUST FMIC with HKS Piping
Apexi Super Suction kit (Pods)
HKS Super BOV's
HKS EVC III Electronic Boost Controller
HKS Electronic Torque Controller & Drag Controller
Apexi PFC
305rwkws @ 18psi
Need to replace turbs. Good thread but still confused. HKS 2530's, GTRS, GTSS ???
Post Dyno results after turbs replaced.
Edited by Sinista32
R32 GTR 90 model 86000km
Standard top and bottom end
HKS 2530's
split dump
twin 3 to 3.5 inch front pipes
3.5 inch decat pipe
3.5 inch cat back
Sard 700cc injectors
Bosch 044 pump
PFC
Trust 4inch intercooler
standard AFM's
309.4 rwk on 17PSI
260 rwk on 13psi
I dont know why i havnt posted up in here yet so....
GTR
Completely stock motor
Microtech LT-12S ECU
3.5 exhaust
ARC airbox
Standard turbos running 15psi
Had Nismo Single plate at the time, then Nismo Twin
262rwkw
Motor is now being rebuilt though, so ill update later
Stock R34 N1 Motor
HKS 264's
HKS 2530's
Stock unported exhaust manifolds
ATTKD 76.5mm extensions
Nismo down pipe 70mm x 2 to 80mm
ARC Ti 100mm exhaust
HKS filters
Custom ic pipes
Greddy 5 row dual entry IC
Blitz DD BOV's
Greddy intake manifold
Greddy fuel rail
RC 750cc injectors
AEM FPR Regulator
AEM EMS with 3.5 bar Map
Earl's oil cooler with thermostat
110 and 93 mixed gas
599whp @ 19 psi with injector duties at 105%
533whp @ 16 psi
John
Edited by JaS3113
R33 GTR - RB26
HKS GT-SS Turbos
HKS dual Dump and Exhaust system
HKS air pods
HKS intercooler
Tomei Poncams/Gears
Sard 700cc Injectors, rail, and reg
Nismo Fuel pump, intank
Splitfire coils
Power FC and AVCR
Power output is 340rwkw @ 8,000rpm @ 1.5 bar BP ultimate fuel
Edited by HKS26T
Stock Turbos and engine exept for Forged pistons.
Air temp is a tad high as the run was done at the end of a full tune so the engine bay was very hot.
These turbos have put up with 18psi for 3 years without the wheels falling.They are stock R33 GTR turbos on an R32.
  • 4 weeks later...
R32 GTR
Genuine R33 N1's with .48 rear housings
HKS dumps, uas front pipe+barrel cat
HKS Exhaust.
splitfire coils
S 40 plugs
720cc inj
nismo pump
F con v pro comp
ex cam wheel
hks pods
bigger front mount
Had 33 N1's before but they were worn out.
Need to get leaner a/f as graph shows.
At least it's safe till I get it retuned
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
