  On 17/05/2016 at 1:47 PM, -oliveR said:
Twin GTX2860R 0.72 rear housings
Precision 46mm ext gates
Custom stainless steam pipe equal length high mount manifolds
Tomei oversize oil pump
ID 1000's
Twin Walbro 255's
2.5″ stainless dumps, 3" dump back
CNC Steel adjustable cam gears
Twin 6″ K&N pods
PWR Aero2 cooler with 3″ outlets
PWR twin pass X-flow 55mm radiator
PWR 21 row oil cooler
SPAL 16″ skew blade 2000CFM thermo fan
3 Quart Accusump
Custom RWD R33 GTR sump
Stock cams
Stock bottom end
Stock head
373.2kw @17psi on E85
Compression test prior to the dyno came up with 185-190 across all 6, not sure why it was so high. Tried wounding out some power but caused misfires, so wouldn't make any less.
New cams, ECU and valves coming in the next few months, no idea what it will make when retune happens.
Nice, in 4th gear what rpm would see 17psi?
  On 04/05/2016 at 7:03 AM, .R33. said:
Hi all just got my R33 GT-R le mans tuned.
Unopened r33 rb26 done just under 100,000 (whether it is legit or not lol)
Mods:
r34 n1 turbos
Ported stock manifolds
Split dump pipes
Xforce front pipes
100cel cat 3"
3.5" cat back
Apexi pods
Trust fmic
Hks evc-5
Link g4+ ecu (no afm's)
Siemens 660cc injectors
Nismo fuel reg
Walbro 255
OS Giken twin plat clutch
Probably more i missed.
Made 300hp on 14psi
365hp on 20psi
Was hoping for abit more after seeing some of the results here, but tuner said to do cams/gears/springs and should get near the 400hp mark.
Added a set of tomei adjustablecam gears. Car now makes 385hp atw 18psi on 98 :) dropped 2psi and gained an extra 20hp...
Impressive gain, wish i did it sooner!
First tune, ran out of dyno time. Boost on graph is PSI * 10 (for scaling purposes) and is straight from the log. It literally rained while we dyno'd so 100% humidity and 83 deg F ambient.
This is STOCK Haltech timing advance (untouched). Only would knock at 20 psi at 4400 rpms during spike. I'm DEFINITELY losing boost response on this because the logs with the wastegate hose pulled are showing 21 psi at 4100 rpms (as opposed to my lazy 4400 that was kinda of spiking at first). This was on the MEDIUM EFR wastegate cannister - now I have the high on and boost onsets even faster.
Pumpgas 93 (with the 10% ethanol they have in my area).
2.75L BC stroker
New N1 block 86mm bores
tomei poncam A
6boost manifold - divided for IWG EFR
8374 EFR .92 IWG divided
ported head
SS +.5mm valves
squish pads removed
Hypertune V2 90mm single TB
stock intercooler
800cc injectors (at the time, now 850cc)
DW 300 pump (at the time...running out of pump on dyno...now as sump and AEM380)
Haltech PnP Platinum Pro
Fluidampr harmonic balancer
Nismo Super coppermix twin clutch
Cam gears are '0' '0' (didn't have time to change them yet)
Boost 18 dropping to 16-17 on top.
Basically this is my "baseline" dyno, but I wanted to share since it's data. Car is very quick on the street and super responsive. I LOVE the turbo! I think with the added timing that I have done street tuning since this the car HAS to be making 500 or more whp.
  • 4 weeks later...
  On 25/06/2016 at 11:56 PM, SiR_RB said:
Hks 2.8 stroker
N1 block
Ported head
tomei procams
Hypertune plenum - 90mm throttle
Hks100mm cooler
Precision 7175 1.12
4" dump/mid pipe/cat back
Vipec v88
625kw @ 32psi tuned by DVS JEZ
Expand
Must have a nice exhaust
  On 29/07/2016 at 12:21 PM, GTR_JOEY said:
It's 4 inch where it matters,
right behind the turbo
Expand
I don't mean to be seen to be picking on your posts but that is incorrect, it could be 4" all the way and have a 3.5" tip and that is enough to cause a restriction. Does not matter where it is along the pipe really.
Expand
I disagree... cooler exhaust temps = more dense.. right out the turbo temps would be say 700~900 degrees, at the axle back I'm sure those temps are no where near it..
  • Like 3
Expand
Yes because of heat transfer through the pipe which is nothing to do with what I said.
You have a 3.5" restriction, put it anywhere along the 4" pipe, it will do the same thing.
nope. for a given pressure and mass flow, Air velocity through a given cross sectional area at 800 degrees C is approx. double that of air at 290 degrees and triple that of air at 100 degrees with pressure held constant.
no idea what the gas temperature at the rear muffler is though.
Edited by burn4005
  On 20/03/2016 at 8:40 AM, nakameguro said:
I did a dyno run yesterday to get a base power figure before upgrading the turbos and getting a good tune.
93 BNR32
Mods:
HKS EVC
APEXi PFC
HKS Exhaust
SARD Metal Cat
R34 Turbos ceramic
Spitfire Direct Ignition System
HPI R35 AFM
TRUST/GReddy Intercooler
Tomei Type-R Poncams + Cam Gears
Nismo 555cc Injectors
Nismo Fuel Pump and FPR
ARC airbox
Nismo coppermix twin plate clutch.
Currently the car is running rich.
Dyno run boost at 1.1 bar, 238.3kw @all 4 wheels, with 351ft/lb torque.
which is calculated at 298.7kw at the crank (400hp) , and 48.6kgm
power curve wheel and crank:
Torque curve:
406ps at the crank
Expand
Had the car retuned with GT-SS turbos, I'm still working out some issues before i'll be upping the boost too much.
current dyno sheet at 1.2bar of boost 260wkw but the low and midrange feels so much smoother/better now.
1994 R32 GTR relatively stock
95k (ish) kms
Full 100k service with all the usual suspects changed and replenished.
Spitfire coil packs
Adjustable cam gears
Haltech Platinum- Pro V2 with wide-band controller
5bar Map sensor & Haltech boost solenoid
Cat back exhaust
221kw @15psi
CRD tuned
Given 5th is 1 : 1 ratio in an R34 6spd is that what people are using for power runs?
We're doing some testing right now and my curve only looks like others in terms of response if we use 4th.
Added plazaman 76mm cooler, pods, and a bit more boost.
Pods made the bigger difference (14 of the total 20kw gained) and were added on the dyno AFTER everything else had been done so we had proof the gain was purely pods at that point.
This was done in 4th, in 5th it made more power but less torque, I went with 4th as thats what we used last time when it made 334kw.
Car is driving nice and sounding good.
Expand
should dyno in 5th... 4th is cheating
  • Like 1
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
