1990 R32 GTR
Done about 9,000km since rebuild
ACL Forged Pistons
ACL Piston Rings
ACL Big End Bearings
ACL Main Bearings
Ported and polished head
Stock polished crank and rods
N1 Oil pump
N1 Water pump
Tomei Oil Gallery restrictor
Gates timing belt
R34N1 turbos C106/GT25 A/R 0.60/0.64
3" Trust Front pipe and Cat back Exhaust
3" Metal cat
Twin Apexi Pods
Apexi Power FC & Hand Controller
Greddy Profec B Spec II boost controller
Nismo fuel pump
Still running stock cooler, dumps, injectors, camshafts and cam gears.
257KW at all 4 wheels @ 14psi. approx ~ 280rwkw or so
Injectors running out of capacity. Dumps, cam gears and injectors are the next step and a bit more boost, hunting for around 300KW at all 4's. :P
Edited by PhilGTR
Since I had to post up a pic of my dyno graph in the for sale thread of my turbo's I may as well post the results in here too. This was done just after I put the poncams in which increased the midrange heaps as you can see.
1999 R34 GT-R V Spec
HKS 2530 turbos
Aria Pistons
Tomei 260-9.15 poncams (int and ex)
Power FC
Cam Gears
Apexi Front Pipes
Blitz NUR cat back exhaust
Twin Apexi Pods
  • 4 weeks later...
BNR32
Dead stock bar,
- PFC
- Nismo AFM's
- K&N's (dirty)
- Trust PEII cat back (80mm)
Cars been on stands in my garage for 5months with the following work (for power) back on road in 4months F.ck Knows :P
- GT35XX, custom manifold, 45mm Ex gate
- Blitz ID III
- 3.5” zhaust from turbo to metal’cat (then PEII)
- 044 in tank, dedicated +12v feed, twin feed rail, 700cc SARD’s, SARD FPR
- Relocate battery to boot, full +12v feed to 044
- JUN cams
Other
- Ogura twin plate
- HICAS lock bar, cooler loop, all lines removed
- Battery relocate to boot
- Coilovers
- Defi's
- Billet oil filer remount & cooler
Edited by PranK
Fix img url
  • 4 weeks later...
1990 BNR32 GTR
34 N1 Turbos AA403 (rebuilt with 5mm oversized compressor wheel)
N1 Pistons
Tomei Cams (Will check when covers get attention) Standard cam gears
Fcon Pro V
3.5 inch Trust/greddy Extension front pipe
3.5 inch exhaust
Super high flowing cat
Arc cooler
Hks Hard pipe kit
Hks cooler pipes
Hks evc black limited
Hks pods of death
Angus performance exhaust manifolds
Made 410hp at wheels with bleed valve (before turbo rebuild, dumps and boost controler)
expect to see 500+hp next time
Edited by Angus Smart
98 Stagea Autech wagon
Rebuilt motor
CP forgies
REV rods
N1 Group A turbos
TuneAgent exh manifolds
HKS dumps, Nismo front pipe, Trust PE2 exhaust
Blitz 102mm cooler
Std afms (have z32s waiting)
Pods on CF tubes.
Sard 720's
Tomei cams (both set a zero)
044 pump
Greddy rail
301rwkw @ 16psi.
Soon to be retuned by Dr Drift with cams dialled and z32's fitted. All in the Darwin heat too!
Edited by RBNT
'90 model, 85,000 klms with up to date log books
Near stock, currently sitting at 286 rw kw (approx 383 rw hp)
Currently being tuned for more mid range as it seems the turbo's are
at their max.
Mods:
Kakimoto 4'' from dump pipes
Roguepi Hard pipe intake and cross over pipe
Apexi 115mm intercooler (couldnt find a 130mm one)
F.E.T ignition coils
IRIWAY plugs (could be iritop, cant rememeber)
At this stage, the car was making 240 rw kw (321 rw hp)
Added an original Profec B- now making 260 or so rw kw (252 rw hp)
on 1 psi less then previously
Added Power FC Dejetro (AFM's still fitted) 286 rw kw (383 rw hp)
Cam belt being done along with cam gears, waiting to hear back from tuner
but probably wont make any more power. Hopefully it wil have a bit more
mid range.
Looking to get 400 hp atw with stock turbo's but not sure what I can do next.
My brother is suggesting alloy pulley kit (Water, powersteering, alternator)
along with a billet 5.2kg flywheel which should free up some power putting
it close to the mark. Everyone on here laughed when I said I wanted 300 rw kw
(400 rw hp) with stock turbo's. Im not far off my mark and havent done half the
shit they said I would need to do.
I will update this with a scan as soon as I get the car back (next week maybe)
P.s Ramp rate is 100, should be good for a flat 12 if the clutch holds it. This is also
a summer tune. It might get closer to 400 rw hp in winter but thats not the point....
Edited by amosite
96 stagea rs4
Engine: RB26DETT
INTERNALS:
N1 block
JUN 2.7L stroker kit
JUN forged crank
JUN forged connecting rods
JUN cosworth forged pistons
JUN oil pump
JUN head stud kit
JUN big end stud kit
JUN high lift cams
JUN adjustable cam gears
JUN titanium retainers
JUN heavy duty valve springs
Nismo bearings
HKS metal gasket kit
Tomei valve guides
Gates timing belt
n1 waterpump
ATI harmonic Balancer
INTAKE:
HKS T04Z (0.81) turbo
K&N pod filter with 6" inlet
Trust stainless steel exhuast manifold
custom 3" aluminium intercooler piping
HKS 50mm external wastegate
EXHAUST:
4" dump pipe into 4" exhaust, to 3.5" after cat
3.5" stainless steel muffler
FUEL SYSTEM:
sard 1000cc injectors
sard dual entry fuel rail
sard adjustable fuel pressure regulator
bosch 044 external fuel pump x2
bosch 040 intank fuel pump
3L aluminium surge tank
1/2' feed line to engine
3/8' return line to surge tank
OTHER ENGINE BITS:
Autronics SMC ecu
Autronics CDI ignition amplifier
MSD coilpacks
custom 9L baffled sump
Apexi Drag 600x240x140mm thick intercooler
tuned on 18psi (had issues on higher boost with misfiring, soon to be sorted) it managed 545rwhp (407rwkw) with rpm limit of 8500rpm
Edited by CruiseLiner
  • Like 1
Update on my R33 GTR.Previously made 370rwkw with HKS 2530's,stock bottom end,HKS cams,Z32 AFM's,Power FC,Nismo 600cc inj
Currently
Arias pistons
Tomei rods
Jun oil pump
HKS 1000cc inj
Trust T88H-38GK
Trust exhaust manifold
Trust wastegate
HKS fuel rail
Tomei in tank pump
2 x Bosch 044 pumps
HKS step 1 cams
Ross balancer
OS Giken triple plate
Made 420rwkw @ 19 psi,problem with the spark,HKS DLI box coming,will post up dyno sheet when sorted,hoping for 450rwkw at 25psi on 100 oct Shell.Work done by Racingline.
90' GTR
5,000kms on Engine
Engine:
Fully Balanced Internals
ACL Forged Pistons
ACL Piston Rings
ACL Race Series Metal Head Gasket
N1 Oil Pump
Head Port and Polish
Arospeed Adjustable Cam Gears
Drivetrain:
Exedy 6-puck Single Plate
Lightened Billet Flywheel
60% Reduction Short Shifter
Strengthened Rear Driveshaft
Intake:
Hi-flowed Turbos by ATP
HKS Pods
HKS Drag Intercooler
HKS Hard Piping Kit
Exhaust:
Standard Manifolds Ported and Polished
Standard Dumps Polished
Full Stainless 3inch Exhaust
Tanabe Stainless 3inch Rear Muffler
CATCO Stainless 3inch Cat
Fuel:
Rochester 650cc Injectors
CSP Fuel Rail
Aeromotive FPR
Bosch 044 External Pump
RPM EFI 2L Surge Tank
Management:
Apexi PowerFC
Apexi AVC-R
Result:
274.0kw on 18psi with Racepace PFC Tune.
R32 GT-R
Power FC
HKS GT2530's
HKS Cam Gears
Nismo AFM's
Blitz DSBC Spec-R
Big HKS FMIC
Trust split dumps
3.5" cat back
Punch through CAT
Stock everything else
311rwkw
Edited by sav man
Update to Post #13
I've had my GT-SS turbos and JUN cams fitted and fettled. Mid range power improvement is dramatic. This is like a new car, almost no turbo lag whatsoever. The car pulls hard in any gear. I use for daily driver and occasional track day. The dyno run speaks for itself. 500Nm of torque at 3000rpm! The tuning was done on a Dynapack 4WD hub dyno. 488hp @ A4W. Turbos running at 1.5bar.
1997 R33 GTR VSpec
Engine
GT-SS Turbos
JUN 264 Cams
JUN Adjustable cam gears
Mines cam baffles
Tomei sump baffles
Power Enterprise Super Strong Timing belt II
Nismo engine mounts
Tomei metal head gasket
Tomei oil restrictor
Custom oil cooler and filter relocation
Electronics
Power FC
Apexi boost controller
Nismo AFM's
Breathing
K&N Pods
HKS Dump Pipes
Apexi Front Pipes
De-Cat
HKS Hi-Power cat back
Standard intercooler (probably needs upgrading, blew a pipe off recently)
Drivetrain
Exeddy twin plate clutch
Fuel
Trust fuel rail
Nismo fuel pump
Saard 700cc injectors
Nismo fuel regulator
I can recommend this setup for anyone after fast road / track day use.
Dyno_488hp.pdf
Edited by Project mu
Further to my previous post above here is the finial figure
With the addition of cam gears and finishing the tune it broke 300 kw (403 hp)
on 11.8:1 AFR
Paul (Pulse Racing) double checked that I wanted it richer. I confirmed- FAT in the mid range,
around 11:1, then to Mid 11's and above 6500 keep dumping fuel to cool it. That he did and the
result was 6 rw kw less.
I would say that this particular car would probably make 305, maybe 310 rw kw on 12.2:1
but I would rather be safe.
After driving the car, its fast but not really as fast as previous cars. I will drive it tonight to
get a better impression of what its capable of. If I keep it I will put the 550cc injectors in,
SARD Fuel reg and the GT3040R on it- but limit it to 350 rw kw as per Pulse/Advans advice
(stock rods). Only problem with is with the next stage I will need to change EBC's as I want
to run 22-24 psi as it spools up then taper the boost curve back to 18-19 psi above 5000 RPM.
R32 GTR
N1 block,
87mm Tomei pistons,
Tomei rods,
R33 crank,
Tomei cams (not sure what size)
HKS valves, springs and guides,
Trust T88-34D kit
720cc inj,
Power FC
Z32's
4" exhaust
Power extreme FIC,
Tomei fuel rail,
Nismo fuel reg,
1 x GTR intank pump, 1 x Bosch 044 pump with surge tank,
446 rwhp at 8,000 rpm on 1.3 bar boost on 98 ron.
Waiting for PPG gearset for high boost tune. (Should make 600+rwhp on 2 bar with more rpm)
Pic of dyno graph to come
1992 R32 GTR.
Standard engine
standard cams
apexi power fc
adjustable cam gears 2 degree advance inlet 4 degree retard exhaust Thanks SK
nismo 600cc injectors (new)
twin bosch 910 fuel pumps
2560-5 garret turbos (new)
HKS split dumps
ported stock exhaust manifolds
FMIC
hard piping kit
twin RB 25 AFM
pods
no cat
90mm exhaust system no brand names
atmo bov
Dyno run was done at .9 bar as boost controller didnt arrive in country in time.
Had higher runs but settled for a fatter AFR up top.
Edited by tacker
R32 GTR 1990
Standard rebuilt motor with JE pistons.(forged)
HKS 264/264 cams step 1
660cc injectors
Standard ECU remapped
Z32's
3" exhaust
2xWalbro Fuel pumps mounted intank
Adjustable Cam gears
BLITZ K5-660R turbocharger
401kw @ 1.4bar boost...
EDIT 10/03/2007 3.08am.
We have retuned the car on the street and will be putting it on the dyno tomorrow now with 100octane shell fuel and more timing with 1.5bar boost we hope to make around 430rwkw with bucketloads of power as fullboost is by 4500rpm
Edited by GTR-026tt
Same as before except changed worn r33n1's with r33n1's with stock Gtr rear housings, which is smaller than N1 housings.
R33 N1 turbos (bush bearing)
720cc injectors
Nismo pump
ex cam gear
split fires
blah, blah
268 RWKW @1.1Bar
295.49 RWKW @1.4Bar
Some big numbers in here, makes my figure look lame... :P
1990 R32GTR
77'000kms
It did run 400rwHP, and suprisingly had plenty of injector duty cycle left (And Boost), but 2 degrees was pulled from the timing as at the end of the day it is an old motor and no point in killing it just yet!
Still all in all not to bad for the sum of its parts
Engine: RB26DETT
Internals: Stock
Cams: Stock
Cam Gears: Stock
Injectors: Stock
Fuel Pump: Stock
AFMs: Stock
Intercooler: Stock
Turbos: Garret GT2560r's
Front Pipe: Trust / Greddy
Dumps: Trust / Greddy
Catalic Converter: N/A
Exhaust: Jasma 3"
ECU: PFC (Non D-Jetro)
Boost Control: PFC Boost controller (Set 18psi)
1990 R32 GTR
showing 111,000km with tomei cluster
Engine: RB26DETT
Turbos: Slide Hi flow turbos
Intake: k&n hi flow panel
Front Pipe: aftermarket, dunno what brand
Dumps: Xforce
Catalic Converter: Xforce hi flow cat
Exhaust: hks super dragger
ECU: mines ecu
Boost Control: hks evc III @ 1bar.
everything else stock.. i dont really know how to read dyno's so dont ask lol. i thought the figure was pretty good for the mods i had.
250.7 rwkw (will post up dyno sheet once forum is fully operational)
