On 28/3/2022 at 9:34 AM, hattori hanzo said:
good to see some results from the new G series turbos getting on the board.
Still getrag or gone sequential?
Yeah I’m quite surprised how well they go. Feels just as laggy as my old 84rs.
This was the final numbers with the g42-1200. Turbo has still got more left in it.
1011hp (753kw) @ 37psi e85
923hp (688kw) @ 35psi e85 (high boost)
753hp (561kw) @ 24psi e85 (low boost)
685hp (510kw) @ 20psi on BP98
  • Like 1
  • 2 months later...
Engine
Stock internals RB26
 Turbos
Garrett GT2860R-7s, 15.5 psi (currently boost is limited due to 7psi actuators)
Intake
Apexi power intake kit (twin pods)
Twin turbo pipe mod (plate welded into the TT pipe) to separate air to front and rear turbo to promote laminar flow and reduce turbulence
Stock intake pipework with AFMs inactive (O2 controlled by Link Wideband)
Exhaust
HPI stainless dump pipes
HPI stainless equal length front pipes
Apexi N1 3.5 inch stainless cat back
Stock cast exhaust manifolds, metal multilayer gasket, new genuine Nissan studs and nuts
Fuel System
1000cc Bosch Dynamic Flow Matched Injectors
Walbro 460lph Fuel Pump inc wiring upgrade direct to battery
Turbosmart FPR800 Fuel Pressure Regulator
Ignition System
Stock Ignitor
Splitfire Coil Packs
BCPR7ES plugs gapped to 0.7
ECU and Sensors
Link G4X ECU
CAN Wideband O2
Link Flex Fuel Sensor
Syltech fuel pressure sensor
Syltech oil temperature and pressure sensor
Syltech coolant temp sensor
Syltech air temp sensor
3 port MAC valve (electronic boost control via the ECU)
Tune
Dyno tuned for full flex
262kW on 98
282kW on E85
Was told by the tuner that I was limited by the small actuators (7psi) meaning they could only get 15.5psi with the boost controller, I have some HKS 14psi actuators incoming and will run it up again on 18-20psi.
Edited by flavzz
added ignition system info
  • 2 months later...
Does VCAM work ... why yes, yes it does ....  On vs Off, only tuning the low end, boost on gate.
yr7sOuifEiZbjOyAk6868KJ_6VfWMXm8GKcjG15JQUd4kIHamEpEm0HOeBttKe9ASq9aZHdUr0oRom2n0fDAzpD2pfrG4fjN8SeP5Gy1DBsFWQg9Usvw-nTyqn6zsvhkNo2y60H60gi8RtqdWjv7Z7StvJqKrS4NnekLP03VsqE4q-kjThFXlwIHUeeh3Y3Vna1guDeiKiYkLWe35X1Z-FK2NptgjCj9FWAtXLz3hA2vB9cjFBu_jHAgT3Jurgbaji2V-2_gXyMNbyxn5-lfzli2i0tHTNtF8y6j0hvKEGpv3czuw6VT9feKXvHPMHpwFEX79Q0c8z2AJ-YU8lLPNug8LhC0LNCVaZOXnyjNOS_wgFibQzS0mMm6g4KKX0GqKYuSkpxSHShRQ5EQX-tGd536tLhBNV9MawkaB3ZEuLHxvm-EkmaLza6BChvVef7QHt67BfcPV4k3Ry9vSCziV6LYQpfVRpDwF6HKWSsSLaOGe5tVVydE1DcO_Bdp4ozD0Q3a4cTGYY0CxKkMjlvVkKPMXV4Pyg75houLQfDZkCq8-HDp24jEeg8ihRez0yxRxWpAphJTAozwxBdpX4GAN6mftOGzB-iYRUYx3mBGYXwN6r6ns5nKVq1W0jonKLR44o2ERFu6-XAKgZZnHZV81vAIr8tn4Vx8CU4fVFyDdkd62og-Q5fTFgRmwOSytAT6mNCoEx_Iyo_kinOfx0SL5trSSaK7NSUCISQdx-se-pG2kviApDLk1J2jsqMvFQ2FoR8RxS46pDGIXscVXadVm5eW2kUc_YF8feT1msh6r8a_DILzIzkIfsXCL3jMZ59n6ZVb688UewHF3ZHQiGRfTRs5yqzzKLQyWOk0k-YOAJ2Zs8AvLdISSdDOGk7Ez5key8OdGq5BY_IRip4QgCKY9oLlCZUIkY99ihdMkbqI_v7EoDm71_JqaMVtGj5k0uczeOXyooJ0ECXXxbs=w2630-h1973-no?authuser=0
Final Result with some more boost - 718rwhp @28psi (Dyno reads boost high)
tonAnex_QAjsQYj-9R2of-i8Y4vK6DMzSQIy_a0X340fxNgvVZM4Y0SJqxGIoz33R_oXS4zARjZLGIdpGEW1m6tjH9mC1-BsUikLwICyaDcCY4LTuICO16HM9rpn5_Ajp0QBfjTxH1CMaeDCkFCrxV4mim9Kh1PbcQGHT3eThWLyNdgg72i2P1x6vbf1KaYsVSW_Com_UCMC0eKKXv7YUY0qSNA6QSeCXc91mhssWNF6_Ropw-Do2LUGPAALhklXANwx-2tLmpx1xIUEuqTnxHPj33X1pxIHpBXby-v9nzFtNJwl0o9cZPdCcmx04y7reg9k0PKah5T_XNheY1LxMeisr7UEE-NnZb_pm9F-omtvc9hutrvSiGbTzrq3T3fZ0riWgojOBJgcnhp_g2BNJR5GEPyx68PWCg46hoo26Fe3oa-iMawq0jUE0U5bQAKvdleyX079pCfnlCqYqRADOjZv1r2tAnKUffMu-dDRk8hxsiHve6PfOw2nR5-znjp7SEYqLJsMnB0aHBsAIH7he3JNff7lrEpACTQt2WbB4t8e1WN6dkQkAU6ZOoWBZ1SSXEMAIUinQU8CpFe7qWPA-zcjzkRw_rsACQx5XlqWRexWbtdkM_tmx8Yf0bJ7iVnbLr1gNWsNQs5H59wgs-VMZIXYI87WlfjPOVFpVGL5usNdHJOgyZHY5y-HyLmHNh8XZYL_w1czGGZEn5hq1y8LDXF0MkMzMRjRS9W_N5ELWBMA9gFEFzvL-W6GWSb-V9W7N3Aa-oXuF_7-20J4Jdelvz3WGANzB1QkpKWw=w2630-h1973-no?authuser=0
Short nose RB26, stock bottom end.
G35-1050 .86 rear vband
VCAM and 264 exhaust cam
Standard head, rebuilt , metal HG and ARP studs.
E85
Link G4X plugin
Edited by Butters
1995 R33 GTR V-Spec
Forged Build completed 1 September 2022 by Racepace
Pre-build mods included:
- BC Racing gold adjustable coilovers
- Tomei dump pipes
- Garrett -9's
- Nismo Super CopperMix Clutch
- 3" exhaust with Midori Seibi cat
- HKS adjustable cams
- Flex tune (made approx 380kw @ the wheels on E85)
Post Build:
- Racepace 2.8 Stroker kit
- fully counterweighted crankshaft
- H Beam forged rods, CP forged pistons
- Low friction piston skirt coating
- RPM oil gallery modifications
- Block strengthening process
- Nissan Engine gaskets (valve cover, oil pump etc)
- Nitto MLS head gasket & intake gasket kit
- ARP2000 Head studs and main studs
- Custom machine of combustion chamber shape
- RPM custom main and big end bearing sets
- New idler and tensioner bearings
- Full engine balancing and blueprinting
- Nitto high volume oil pump
- RPM custom 9lt baffled and trap door circuit sump
- HKS Step 2 VCAM system with Valcon Controller
- HKS Step 1 Exhaust camshaft
- HKS Valve springs
- ATI Super Damper 750hp
- ARP balancer bolt
- Haltech Elite 2500 + adaptor + wideband controller
- Platinum racing crank trigger kit (upper & lower)
- RPM transfer case mod
- Nismo front 1.5way LSD
- Nismo intake plenum
- Plazmaman 76mm Pro Series intercooler
- HKS SPL Turbo intake kit and AFM delete kit
- Racepace/PWR Multipass Circuit Radiator
- Kept the Garrett -9's
- Flex tune
- 440kw @ the wheels on E85, 22psi (dialed back to 423kw @ the wheels on E85, 19psi)
IG: stangbarrazilla
Edited by R33GAS
  • Like 6
On 14/09/2022 at 1:40 PM, R33GAS said:
1995 R33 GTR V-Spec
- Tomei dump pipes
- Garrett -9's
Post Build:
- H Beam forged rod, CP forged pistons
- HKS Valve springs
- ARP balancer bolt
- Flex tune
IG: stangbarrazilla
This would definitely be the best -9 results out there I would think, great job 👍
  • Like 2
  • 6 months later...
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
