I'm in Ryde and I need to get my engine from the ground to the back of a ute that I'm going to hire to take it to the engine builder down near Canberra.
Need 3 strong people plus me to lift it as they are quite heavy bastards.
Around 7pm or so, slightly flexible.
Anyone available?
The engine is on a pallet so you wont get dirty.
Beers available for the duration of the job :D then I've gotta run.
I can't on friday mate, but the best advice that i can give you is that hiring a ute and driving the engine down to canberra yourself may not be the most economical way to get it there. the excess kms charge will be a bitch. plus the time you will spend driving. I would seriously investigate pack and send, or busfrieght or toll etc. could save you time and money, plus let the pick it up with a pallet jack :D
edit: try scotts transport too.
Adam ,
I cant help because i wont be at home but a couple of tips mate :
Hire a table top not a ute , it will be much easier and you will need 4 people one on each corner and the bloody pallet weighs about 5o kg if it is a standard 46"x46" so all up a bit over 200 kg .
It would be heaps easier with an engine crane if you can get your hands one one .
Thanks mate.
It's now moved to sunday arvo about 3ish as I have found a cheaper/better option with regard to freight.
I'll be in touch in a little while guys but if you could post whether this changes anything for you I would appreciate it.
Thanks.
ps, thanks Glenn - You know who you are.
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
