G'day lads,
I'll cut to the chase, I bought a really cheap R32 with an RB20 that is only running on 5 cylinders. I have done a compression test and all cylinders are around 127-130 psi, which I think is pretty good? Except for cylinder #3. It has 0 psi compression. And yes I mean 0
I was wondering how I can determine whether it is top or bottom end problem? I am going to embark on taking the head off as I have a feeling that a valve is not closing correctly on that cylinder, if this is the case it should be a fairly easy job. But if I was to rip the head off with the engine still in the car, than it could get a bit messy.
Is there a quick way of trying to work out whether the piston is cracked/rings gone without removing any parts? I have tried the squirting oil into the cylinder and doing the compression to no avail. As it has no compression anyway.
Cheers :D
https://www.sau.com.au/forums/topic/93896-5-cylinder-rb20/
You should get a cylinder leakage test done to determine where the compression is going.
this is where you get the engine on TDC No 3 cyl and feed compressed air into the cylinder and listen where its coming from i.e. remove oil cap if you can hear a fair bit of air then it has excessive blow by on that cyl (prolly cracked rings), if the majority of air is coming from radiator cap then blown head gasket, from intake tube then the intake valve is not sealing, from exhaust then the exhaust valve is not sealing.
you must make sure the piston is at TDC compression stroke so that the valves are closed and when you feed the compressed air in make sure the crank doesn't try to spin back a turn or forward as it will if its slightly off TDC. Also where the compressed air is fed in through the spark plug hole it must have a tight seal (use the compression tester rubber or tube and seal it) so you can hear the air inside the motor.
https://www.sau.com.au/forums/topic/93896-5-cylinder-rb20/#findComment-1695745
Thanks champ I thought that's how I could do it. Whats a good way to get the #3 cyl to TDC with the motor still in the car?
Also how would you be able to determine the exhaust valve is leaking with the full exhaust on? Other ways?
Cheers again
https://www.sau.com.au/forums/topic/93896-5-cylinder-rb20/#findComment-1695792
Yeah, pull out the third spark plug and insert a piece of straight wire, turn the crank clockwise so you can see when the piston reaches the top (when the wire stops moving up). Remove the cam covers and look at the cam lobes over the third cylinder, make sure they are not pushing the valves down at all (valves closed). When you have this its at TDC cylinder 3 compression. The piston gets to the top twice in a cycle once on compression (valves closed) and once on exhaust stroke (exhaust valves open)
Good luck
https://www.sau.com.au/forums/topic/93896-5-cylinder-rb20/#findComment-1696135
give the head bolts a thourough inspecton for anything obvious but they should be alright.
try scotts auto one, repco, coventry auto parts for just the head gasket but it would be worth getting a full VRS kit that contains all the gaskets you'll need, get these from engine specialists possibly the above mentioned.
https://www.sau.com.au/forums/topic/93896-5-cylinder-rb20/#findComment-1698694
The head most definitly needs to come off if its a valve prob.
A VRS kit is like a bag full of all the seals and gaskets you will need like intake gasket, exhaust gasket, head gasket, cam cover gasket/s, thermostat gasket, water pump gasket (if you change it), new cam seals, 'd' rubbers, cam cover bolt seals and any other gaskets and o-rings you may need to disturb to get the head off. Its cheaper than buying each seperately and way better than using the old ones. Be sure to buy a little bottle of 'permatex' or somthing similar to put on the water gaskets (thermostat, water pump, o'rings on water pipes etc).
https://www.sau.com.au/forums/topic/93896-5-cylinder-rb20/#findComment-1701455
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
