G'day lads,
I'll cut to the chase, I bought a really cheap R32 with an RB20 that is only running on 5 cylinders. I have done a compression test and all cylinders are around 127-130 psi, which I think is pretty good? Except for cylinder #3. It has 0 psi compression. And yes I mean 0
I was wondering how I can determine whether it is top or bottom end problem? I am going to embark on taking the head off as I have a feeling that a valve is not closing correctly on that cylinder, if this is the case it should be a fairly easy job. But if I was to rip the head off with the engine still in the car, than it could get a bit messy.
Is there a quick way of trying to work out whether the piston is cracked/rings gone without removing any parts? I have tried the squirting oil into the cylinder and doing the compression to no avail. As it has no compression anyway.
Cheers :D
https://www.sau.com.au/forums/topic/93896-5-cylinder-rb20/
You should get a cylinder leakage test done to determine where the compression is going.
this is where you get the engine on TDC No 3 cyl and feed compressed air into the cylinder and listen where its coming from i.e. remove oil cap if you can hear a fair bit of air then it has excessive blow by on that cyl (prolly cracked rings), if the majority of air is coming from radiator cap then blown head gasket, from intake tube then the intake valve is not sealing, from exhaust then the exhaust valve is not sealing.
you must make sure the piston is at TDC compression stroke so that the valves are closed and when you feed the compressed air in make sure the crank doesn't try to spin back a turn or forward as it will if its slightly off TDC. Also where the compressed air is fed in through the spark plug hole it must have a tight seal (use the compression tester rubber or tube and seal it) so you can hear the air inside the motor.
https://www.sau.com.au/forums/topic/93896-5-cylinder-rb20/#findComment-1695745
Thanks champ I thought that's how I could do it. Whats a good way to get the #3 cyl to TDC with the motor still in the car?
Also how would you be able to determine the exhaust valve is leaking with the full exhaust on? Other ways?
Cheers again
https://www.sau.com.au/forums/topic/93896-5-cylinder-rb20/#findComment-1695792
Yeah, pull out the third spark plug and insert a piece of straight wire, turn the crank clockwise so you can see when the piston reaches the top (when the wire stops moving up). Remove the cam covers and look at the cam lobes over the third cylinder, make sure they are not pushing the valves down at all (valves closed). When you have this its at TDC cylinder 3 compression. The piston gets to the top twice in a cycle once on compression (valves closed) and once on exhaust stroke (exhaust valves open)
Good luck
https://www.sau.com.au/forums/topic/93896-5-cylinder-rb20/#findComment-1696135
give the head bolts a thourough inspecton for anything obvious but they should be alright.
try scotts auto one, repco, coventry auto parts for just the head gasket but it would be worth getting a full VRS kit that contains all the gaskets you'll need, get these from engine specialists possibly the above mentioned.
https://www.sau.com.au/forums/topic/93896-5-cylinder-rb20/#findComment-1698694
The head most definitly needs to come off if its a valve prob.
A VRS kit is like a bag full of all the seals and gaskets you will need like intake gasket, exhaust gasket, head gasket, cam cover gasket/s, thermostat gasket, water pump gasket (if you change it), new cam seals, 'd' rubbers, cam cover bolt seals and any other gaskets and o-rings you may need to disturb to get the head off. Its cheaper than buying each seperately and way better than using the old ones. Be sure to buy a little bottle of 'permatex' or somthing similar to put on the water gaskets (thermostat, water pump, o'rings on water pipes etc).
https://www.sau.com.au/forums/topic/93896-5-cylinder-rb20/#findComment-1701455
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
