Time for another tuning results thread.
I approached Jim at CRD to tune my car following recent work and I an extremely happy with his efforts
The results shown below are based on a built RB26 with all the fruit, Tomei 260 degree Poncams and HKS GT-SS turbos
I will let the pictures below tell the story
The cars response is very good, its very agile around town and the exhaust note is simply awesome.
I can only say I am very pleased with the results
https://www.sau.com.au/forums/topic/93923-crd-tuning-results-r33-gtr/
  • Replies 40
Good results nick.
Post up the torque curve why dont ya :D
From the boost curve, you're making 21.5-22 psi @ 4400 rpm ? Thats pretty good.
It will be interesting to see what you end up pulling at wsid this week. Hope it bloody well doesnt rain. If it does, I will join you next week and we can race together :D
I take it this is awkw?
Very nice result.
Intersting to see your boost hit 21 and drop back down to 20 - what boost controller are you using? Is it set to 20 and just spikes to 21?
What rpm are you hitting 1bar boost (just want to compare to williamsf1 and tommy)...
Will be interesting to see how you go at the drag strip... are you going to take this on the real (circuit) track? :D
can't wait till i get my car back in a couple of weeks or so. I'm leaving stock cams in for now, see how they cope.
Ferni, yep thats awkw
The car made 320awkw but was brought back down a tad for the final run - my request was reliability and safety rather than absolute peak power
CRD believes that my cat is causing some problems and should be replaced with a better flowing unit, which could see a gain of another 10-15 awkw
I have been itching to take the GTR on a track for a long long time now, so I will fit my oil cooler and get out there!
Boost controller is the HKS EVC 5
Nick
Nice work. Glad Jim sorted it all out for you. Too bad I didnt stick around at Croydon to see the final run but after eating maccas I was feeling like shit (big suprise!).
I have doubts about my own cat after the weekend and will be sourcing one of those phat Catco ones which look like Magic cats from Batmbl i think.
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
