hey ppls,
Can anyone tell me what the offset are for the r32 gtr?? im lookin at some set of 19's, the specs are:
Front: 19x9 offset +33
Rear: 19x9 offset +45
PCD 5 , 114.3
will these fit?? or theres these other ones which are:
19x8 with 215/35/19
PCD 5 , 112
cheers,
Edited by KAS_GTR
https://www.sau.com.au/forums/topic/93960-32-gtr-offset/
use
http://marksink.com/tire_wheel_offset/offset.html
stock r32 gtr offset is 8wide +30
so fronts will sit out 10mm wider (and 16mm less clearance from strut housing)
rears will retract 2mm (and 28mm less clearance from strut housing).
^ could look wierd, because fronts will stick out more than rears.
you haven't posted the offset for the 19x8 pair, so impossible to tell. However I gaurantee they will not fit as they are 5x112 stud pattern.
I'd also suggest 19's are too big for skyilnes, won't do much for handling over 17s and probably not much better than stock, just bling factor
Cheers
https://www.sau.com.au/forums/topic/93960-32-gtr-offset/#findComment-1697011
thanks for the reply.
i found out dat the 19x8 ones have an offset of 40 which would mean fronts and rears would retract 10mm. could i get spacers?
also as u said dat the stud patterns are 5 x 112, it wouldnt fit? wat are the stock stud patterns for the 32GTR? and could i get a conversion to fit my stud pattern?
https://www.sau.com.au/forums/topic/93960-32-gtr-offset/#findComment-1699698
40 offset is crap. You can get spacers, but they aren't legal.
You may be able to get spacers to convert stud pattern, but it's not really worth it. Just keep your eyes open for some rims in decent offset & the right stud pattern.
skyline stud pattern is 114.3x5
https://www.sau.com.au/forums/topic/93960-32-gtr-offset/#findComment-1700059
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
    • Nice, is there a post with the new 4" dyno curve?
