I'm sacking the nissan projectors and retro-ing some Honda Euro HID projectors in... they're a bitch to do...
If anyone is interested, will post up some pics as I go.
Got the headlight apart at the moment, done some cutting of the euro HID projector and that's about it
https://www.sau.com.au/forums/topic/93963-xenon-hid-lights-conversion-for-r32/
Headlight apart (sorry no glass pics):
Chrome headlight cover (being sprayed matte black) :D
Standard projector on left, Honda Euro on right (already cut an 'ear' off it)
As you can the Honda projector is shorter, and mounts further forward. Will have to fabricate a bracket for it to fit the standard adjusters... (in progress)
Cutting ears off Euro projector
Because the new projector sits so far forward in the assembly, i may have to cut the rear of the housing off and move it further back. If that's the case I'll plastic weld on a bit of PVC pipe with a press-fit lid on the back. Also, I need more diameter than the standard rear cap to get my fingers in to get the bulb out :D
I'm moving REALLY slow with this and probably won't get it done until xmas... so stay tuned
Update :D
Inspiration struck... here is the old projector
Another view
disassembled
So i cut off the front lens side, so i can use the existing mount points, and just bond in the new projector :D
Trial fit ;) is there nothing masking tape can't do??
back side
Trial fit again... stock you say...
Original...
New xenon trial fit :)
Bored yet?? ...To be continued
oh and to fit the xenon i had to cut the other side of the xenon light too
small DIY I made for taking the glass off, which you'll need to do for this mod:
http://www.skylinesaustralia.com/forums/in...showtopic=53353
Couple of questions:
Where'd you get the Honda Euro projectors from, how much, and do they come with the Xenons and ballasts etc?
And... have you test run the light to see if the throw is any better than the standard projector?
Funkey, the oven method works very well to get these apart... preheat oven to 180C, turn OFF oven, put headlight in for 10 mins and pry apart :)
The Euro projectors I bought off a wreck... $250 (!) for the pair. I had to ebay some ballasts and globes.
I have a couple more sets of Euro projectors only, that (when i get off my ass) will post on Ebay... unless anyone here wants them.
Will also be making a wiring harness that uses relays, and allows the lows to stay on when the highs are switched on... my harness also will ensure that when you just flash someone without the parkers etc on, only the highs will flash.
Good on you Ronin that looks like a professional start. The planned loom and things are definately very professional.
I reckon before you set the actual projector please just blue tac it and actually turn it on so you make sure the focus point is throwing the light properly past the enclosure (headlight assembly). Unless off course you've measured where the honda projector sits in relation to the honda light assembly already.
Looks like a great project, if you're in Sydney and ever on a cruise I'd like to check em out.
Don't know about the led swap. I've been thinking of a led swap on the rear of my cefiro but since I'm selling it can't be bothered.
For the price of $250 and getting some extra bulbs and ballasts you'll have a great retro there - the honda xenons are very damn good and probably quite a bit cheaper than the audis.
What bulb connector are they for ?
Love your work Marcus. Once you're done, could you summarise the time/effort involved please mate? Cause it looks the business and I'm dead keen to follow up.
ps I picked the car up a few weeks ago, looks great. No cam, so no pics :P Is yours finished?
well.. its funny i see this thread today... I was at the car wash today and i did the motor and some green shit went into the headlights..
NOOOOO, so i pulled one apart and did it gold..
need advice? or should i go BLACK????
OR maybe even gold chrome?? do places do that?
Edited by kezza
someonestolecc - the bulbs are xenon specific designation; they're D2S globes.
Mark - I'm going to need pics :P mine's still a fair way off :( gives me more time to play with other stuff though. I'll give a final run down of time / cost when I'm done. They're going to be expensive though - partial summary
HID projectors - $250
headlights (if you get another pair) - $250
Ballasts / globes - $300
various bits for wiring harness - $80
various bits from bunnings (paint, dremel stuff, silicone etc) - $120
Is it worth it? probably not. Is it trick? I think so.
kezza... oh no!
I've done a step by step for opening them below:
1. preheat oven (mine's fan force) to 180C. NB - leave the tray that you're going to bake the headlight on OUT OF THE OVEN. Bakey goodness:
2. SWITCH THE OVEN OFF! Place headlight and tray into oven for ~10mins... will vary at bit between 8 and 12 mins.
3. Pull the headlight out of the oven (wear gloves if you're a sissy like me). Get a screwdriver (not a good one because goop will stick and is a bitch to get off) and pry off one corner between the glass and the housing. If it's sufficiently hot it, once you get one edge apart it will be simply a matter of grabbing the two halves and pulling! voila! open headlight :)
So there it is complete with girlies on the newspaper :)
will probably not get time to work on this for a few weeks, but will keep updating this thread :)
Are we bored yet?
OK, finally got an hour to do some work on the lights... bear in mind that I have no idea about electronics, so this is a pretty good effort as far as I'm concerned.
Bought some LEDs from Dick Smith - 8000mcd white ones
Planned my circuit using led wizard (just search these terms in google)
Chose the correct resistors for my circuit, as provided by led wizard
Found a voltage reg to maintain 12V to the leds
Did some pretty dodgy soldering and dodgy looking circuit board work to get this:
Front side on silver painted 'prototype board', cut to fit within the parker section of the headlight:
Rear side with the *ahem* excellent circuit planning and solder work:
It's alive :( didn't think first go it would fire, but hey, I'm a guru :blink:
Looks blue I think because it doesn't have enough voltage... but hey I can live with a little blueness :)
More to follow around Xmas / new year :)
Thanks mate. Good to know. Wasn't sure if it was gonna be D2S or not. I might try to hunt some around.
Where did the PCB board come from? Usually stupid things like that are expensive at dick smith etc.
32 projectors just arent good
Actually the projectors themselves are quite good. It's the bulbs behind them and the electricals that are getting old.
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
