mmmm just a small note..
I have HID in my R32..
Why not just modify a H1 HID kit into the projector?
What I did was carefully drill out the standard bulb adaptor holder thing and the H1 HID bulb went straight in and it clips in using OEM clips..
All done..
Just wanted to know why you decided to go this way..
Good work on your conversion..
Where did the PCB board come from? Usually stupid things like that are expensive at dick smith etc.
I got them from dick smith... think they were 10 bucks or so for a 15x20cm board or so...
All done..
Because the cut-off line of a Euro projector is TASTY
this is the cut off of a left hand drive projector (taken from eBay)
see how there is a perfect straight line and no light leakage above the cut off?
sweet
I have a HID kit also.... But what Ronin is doing is not installing a kit but a retrofit.
Retrofit is when you take the projector and bulb from (typically) an OEM and (typically) install it into your car's headlight assembly.
The advantage is that you get the projector that is designed to handle the xenon bulbs. Typically the halogen assembly and/or projector design differ from what's required by xenons and you end up with hot spots, glaring and fuzzy cut offs (and subsequent leakage as he said already).
My HID kit is ok. The cutoff is crisp, almost no hotspots and works well. Not all cars are like this though - it's usually acknowledged if you want to do xenons properly and your car isn't factory equipped, OEM or retrofit is the only way to go.
So Ronin.. How's it goin? More pics??
  • 3 weeks later...
  • 1 month later...
w00t! *eagerly awaits pics*
hey, quick question...
with painting the insides of the headlights black, does it affect the throw/dispersion of the light at all?
I mean, i'm quite happy with my headlights at the moment (have standard wattage narva +50% bulbs in there, and adjusted the lights so they shine up a bit higher... the lighting is phenomenal.. my low beams are like most cars high beams.. possibly even better), but the silver finish on them is a bit tatty, and i reckon it would look alright with black housings :thumbsup:
black housing won't make a difference to the headlight performance... look at the std new Holdens with projectors - they have black housings.
anyway, update pics:
New LED setup
Attaching old bracket to new projector:
First I tacked on the bracket with "JB Weld" - a 'metal' epoxy
See I had to cut the section of the old bracket between the two screw holes so that I can access the screw that holds the cut-off shield in place on the new projector bowl:
Then I adjusted it to level (by eye, didn't have a spirit level, so will be pissed if it's fixable not within std height / tilt adjustment of the headlight) and let it set
After that I went around and secured the whole bracket with JB Weld. I'm told this stuff is tough as so I won't have any issues. I've used it before on other stuff and given the amount I put on, there is NO WAY the old projector bracket and the new projector bowl are ever going to part company - they're joined forever...
Tonight and over the next few days I'll prepare the chrome cover to be sprayed matte black, and attach the new parkers into the cover
:laugh: cheers
  • 4 weeks later...
I've been looking for JB Weld all over the place; where did you source it? This has reminded me to get on to retro fitting the E55 Hella Bi-Xenons I have. Unfortunately I think I will have to fab some new mounting plates as the E55s are bigger than the standard projectors.
Will be following your progress with interest now that I have found the thread :D
by Bi-Xenon i guess you're referring to both hi and low beam being Xenon?
i thought that Xenon for high beam wasn't worthwile as it's hard for the hi-beam to be instantly on? or is that not an issue anymore...
man, Bi-Xenon, i know the newer bimmers have em... but fark... that's gotta be bright..
can you Bi-Xenon stock OEM R34 Xenon assembly's? i haven't put in my Kaixen lo-beam Xenon's yet..
hey marcus :worship: i see you decided to have a bash at this yourself :D good to see!
Yes, bi as in high and low beam. They are out of an E55 Merc. You obviously need an assembly that's designed for both hi and low beam and I imagine there is no way to modify the OEM assembly replacing and using a retrofit. I haven't been following the 'xenon scene' lately so I don't know if there are any aftermarket hi/lo solutions.
Ronin 09: out of interest, who makes the assemblys out of the Accord?
lucien - got the JB Weld from Ebay... as far as I know I couldn't find it anywhere in Australia!
Not sure who the manufacturers of the Euro projectors are... will have a look for stampings but dont think there are any.
In other news - I melted my other chrome plastic surround... Idiot left it in the oven too long. Had to source another headlight (thanks 'twisted') and will pull that apart.
More shortly :thumbsup:
  • 4 weeks later...
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
