  • 10 months later...
I'm going to bring this one BACK FROM THE DEAD
I'm thinking of doing another set because my LED parkers have died.
I have found a few pairs of Honda Euro RHD projectors in the shed - if anone wants them PM me.
Thinking of doing something similar myself - might be needing those Euros for my r32. I want clear covers like sinnersta (and self diffusing reflector case), and want clear HIDs with red angels - or white/reddish HIDs to match red and black style of car. Stockies are crap - cannot see more than 10 metres in front of me and high beam adds 1 extra metre of vision. That's right they are that good. I crave more light.
Do you guys know of an easy simple method for doing this other than simply adding HIDs to the current projectors?
you're going to have to split them open and swap them.
if nothing else the OEM projectors and inside of the lights are probably filthy now and aren't operating optimally.
it looks like the coy doing after market plastic fronts is no longer doing them; you could get a perspex company to mould one from an R32 headlight if you're super keen.
Folks looking at buying a set of morimotos in a kit from here... http://www.theretrofitsource.com/product_info.php?products_id=227
Need to find out what wiring harness is required for the R32 GTST type M projector headlights? Also the adapter plate recommendation if possible otherwise I will wait for the headlight to arrive and measure then.
  • 4 months later...
I'm about to do this conversion with a set of Bosch Audi A4 Bi-Xenon projectors - They're the latest spec of the BMW E46 Projectors, with the metal rear end and D3S Bulbs.
I'll also to a dual Hi Beam mod at the same time, so I will be getting the high beam from the projectors as well as the original High Beam center lights. Of note this will be a similar setup to my wife's BMW X5. So I'm hoping for a massive improvement.
Will keep you all posted on how it turns out.
  • 1 month later...
Ok, so finally got around to doing the my Bi-xenon install... Here are some pics of how I went about it. As mentioned above this is one of the lastest versions of the E46 projector, and is common to late model Audis. This is the projector:
Edited by Ryno
As I purchased it from the US, the sheilds suit LHD - see below:
Fortunately this model of projector is relatively easy to modify to suit RHD, but you have to be handy with a die grinder and have a fair amount of patience.
To do the mod, firstly I removed a shield, traced it onto a thin sheet of alloy and cut out two copies of it with a die grinder.
Edited by Ryno
If you look closely at the image above I have tapped two holes near the top - which enabled me to screw the new projector to this bracket (in the reverse orientation).
If you compare the modified projector with the stock one below, you will see that the projector is positioned forward of the bracket almost the exact same amount as stock, and as such it fits into the headlight, without any modification to the stock headlight surround.
The below image shows how I've screwed the projector to the new bracket:
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
