Im missing the before pic here but the buildings are approx. 80m away. The car is pointed upwards. In situations like this there is a stupid amount of foreground light (directly in front of the car) which is why I made up fore ground limiters (a bigger shield) to block some of it. I decided to drive around for a bit without them for a while first
the before pic there wasn't any real light on the building, it stopped at the cars
Nice work, massive difference aye.
Yeah the damn glass diffuses the output, I have like multiple cutoff and orange/yellow-ing.
I also found the driver's side projector to be pointing too much to the driver's side (from factory?).
Yeah its the glass shape, if it were a smooth curve most of this will probably be eliminated.
Im looking to borrow a H3/H3C (maybe H1?) HID kit if anyone has a cheap kit they are not using. I wouldn't mind seeing how the stock projector goes with some mods. Mainly thinking of shortening and making a custom cut off shield and foreground limiter.
Only need 1 side for 4 weeks max, prefer Sydney, im in Bankstown area
Euro Lux are bright and wide. They have ECE cut offs so expect to blind everyone in front of you on the side which has no real cut off. I was in front of one and it was reflecting off my side mirror, super annoying and distracting, I couldn't get my head out of the way. If you use them make your own cut off, if your following a cop and he see's that kind of stuff from his side mirror he will book you
Iv just ordered FX R stage IV with the following options
Thank to tom for help too cheers dude
Just had a quick look on TRS for you, if you're using D2S bulbs I'm not sure if you should be getting the 9006 relay or not since the H1/H3 relay is if you get H1 or H3 bulbs. Maybe start a chat with TRS and see what they say.
That wiring harness is correct. Input is H1/H3, output is 9006 (what the Denso's have).
  • 1 month later...
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
