Xenon Hid Lights Conversion For R32
Ronin 09
21 minutes ago, niZmO_Man said:
See this http://www.jwspeaker.com/blog/how-to-aim-headlights-driving-beam-or-high-beam-headlights/
From your second picture, seems like your passenger (left) side needs to go down, and your driver side (right) needs to move to the left.
But you really need to find a level ground with a wall.
Thanks NiZmo Man!
  • 7 months later...
Any updates on this for the R32 Projectors?
niZmO_Man.... is the Mini D2S 4.0 still the one to go for?
I'm looking for something that will be relatively easy to fit (don't mind a little dremel work) and stealth as HID in NZ is a WOF fail.....
do elaborate the procedure >_< when you get a chance
20 hours ago, niZmO_Man said:
Diode on the high beam wire, so the current flows to the solenoid when you hit the highs.
The high beam bulbs on my car have a separate relay wiring, so I use the standard wires for activating the solenoid.
  • 5 months later...
I didn't take pictures of my dodgy wiring, but I'll make a neater harness so will take pictures then.
In the mean time, Morimoto D2S 3.0 projector with Osram CBI bulb, did a quick retro:
Try getting that with a H1 LED bulb :P
  • 3 months later...
  • 1 year later...
So, I have a set of projector headlights that I intend on retrofitting and then performing a transplant for the N1s.
I have read through a lot of posts about HID conversions and some date back a few years. Is the best option the latest Mini D2S and stick to 35w / 4200k? I.e. no point in going above 35w and I am not interested in bright white / blue headlights.
Looking at Lightwerkz, it seems like you can buy the brackets as mentioned above:
https://lightwerkz.net/collections/retrofit-brackets/products/nissan-r32-to-d2s-brackets
Then build your own kit:
https://lightwerkz.net/collections/universal-kits/products/bi-xenon-morimoto-mini-stage-iii-d2s-1
Cheers
Rob
Not sure why Lightwerkz didn't list it anymore, but they used to let you select D2S or G5 projector to go with their R32 bracket.  G5 is cheaper and has identical dimensions to D2S, except the housing isn't painted black.  D2S has a more centralized hot spot and G5 is more spread out, you can check it out on their comparison videos.
https://www.youtube.com/c/LightwerkzGlobal/search?query=g5
Thanks @TXSquirrel I will check it out.
BTW, it does mention G5 at the bottom of the page:
2x Nissan R32 to D2S 4.0 / G5 Conversion Brackets
  • 4 years later...
    • Hello from Germany,   i build my RB25DET Series 2 -> Target 600hp i have now ordered solid lifters from Tomei for the cylinder head and will replace the original hydraulic lifters. Which cams can you recommend ? It is only a street car.... Maybe i order a Garrett GTW38 or something like that.   and what is with the VCT ? is it blocked with the solid lifters ?   Attention is a RB25DET with solid lifters!   Thank you for your help
    • Diff arrived from Japan last week.  Nismo gt pro 1.5way for gtr. Still deciding whether to use 4.11 or 3.9 gears before installing.  Spent some time yesterday going over what's needed to finish engine bay fuel lines. Got a list so will order soon. Played with radiator placement and decided on stock location with bottom spaced a bit for a small amount of angle. So ordered standard mounts and rubbers. Reason for this is the 180sx was a pain to work on any of the coolers and was also going to take longer to fabricate mounts. Today made a bracket to mount the dbw throttle pedal. Factory location wasn't great to work with the pedal box. Luckily there's a rail that pedal box mounts too so did some measuring, drew up a design and got stuck in.  It's made of 3mm aluminium and has a lot of strength just need some bolts, washers and nuts to finish up.   If I get time tomorrow I'll pull the front bar and lights to start intercooler mounting, it will be flipped under the rad support which will require some trimming.
    • Got my first gold. Deep Forest Lancer Gr.4.
    • Der its not even a 4 door. 🤣
    • Thanks mate yeop be good ! Understand the kid thing for sure lucky mines a bit older and I can bring him over etc he gets treated like a rockstar 😁 go the RB   yeop wont be doing this forever prob so why not 100% everyones always been good but going back this year was different and more interaction and def more support Def thought about changing uprights etc waiting for @Komdotkomto sort out whats needed for those and do the r & d haha  but yeah hard thing for gtst nothing direct fit as all made for GTR which is slightly diff but moving to the r35 gtr bearing will be big improvement - its just budget allocation as its a $10K to $30K exercise dependent on how mild or wild you go and seems something always comes up - ontop of the crazy travel / racing
