OK, got some more pics.
The trim pieces cleaned up with a sand blaster to remove the chrome
After masking and painting and screwing it up about 5 times...
The headlight lens masked up to black out the edges
Finshed products
And how it sits at the end...
still dangling the carrot...
found these even more ricey headlights on Yahoo... not conversion to HID but shows what a black surround looks like
they went for the 5 series BMW 'halo' type light as well...
PS and I don't like the way the LED park lights are circular... I think it takes away from the 'stockness' of the retrofit...
Hey Ronin, i found another out of it set on yahoo... Im in the mix of finding a set of the angel eyes, in white!Any idea were to get them or what size they use.
Cant say i like the big cluster of LEDs hanging out the the parker , myyyaahhhh!
Or the strip on the headlights i found! but the angel eyes anr something that wuld look cool!
keep up the good work mate,
  • 4 weeks later...
where did u guys find angel eyes? i wouldnt even mind if i could get the the parts and convert my originals over but i reckon they look nuts. gotta agree with u ronin, the parkers do look crappy...
Heheheheh got 2 sets on their way fron japan....
well thanks to Troy (ylwgtr2) for buggering around with the plug so we don't have to butcher the back of the housing.
Fired them up for hte first time last night - they look awesome - but didn't have my camera...
so we'll have finished pics on the car when the car gets assembled :dry:
so close now...
I'd love to try this as well. My questions are:
Is it easier & cheaper to source a set of GTR headlights from importers such as Slidewise Imports, or source them locally?.
What projectors would you recommend eg S200, Accord, Euro etc??? i.e. is there any differences between honda projectors & car models??
I already have a set of H3C HID's fitted (not happy with them though), do all R32 GTR lights take this fitting??
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
