im sorry but did we go over how to seperate the side-blinkers also? i have the clear ones and ofcourse i want those to match black also...
do i do it the same way... with heat and such?
What i want to know is how the hell can they charge $450 for a set of full clear R32 blinkers
like them=
And i know their is a place somewere hidden in japan that can make th full clear plastics for the winkers, EVEN the orange curb marker built into the winker plastic!
like this-=
The only question is WHO makes them!!!! then we can all change them over to CLEAR with no gay little orange curb light,
:thumbsup:
anybody seen the headlights on yahoo auction japan. the ones that are all mesh with a small round light in the corner... ill try to find a pic... found it..
guess i should ask does anybody have them, and have a better pic?
Do you think it will be good if we only replace the stock projector with an hid projector?
So i will keep the stock h3c bowl and put an hid cutoff shield with an hid projector.
Then, buying an hid h3c bulb kit.
is that a good? i'm just thinking that it will be easier, but i'm not sure how the h3c hid kit will light up.
i'm doing the same retrofit, but i'm using the e46 projector.
i have the same problem as you, the projector are smaller in lenght. So i will have to cut the back, in order to fit the ballast adapter wire to the bulb.
i got my over cooked ones out, and fitted a fresh set of headlights, and decked them out with blue angel eyes,! looks nice i think!
If anyone wants to get a set of angel eyes, be sure not to get squid rings, or LED eyes... they suck
They cost me about $170 and 2hours of fitting! but look trick!
i started my retrofit using E46 projector. They are very similar to the honda euro.
here are some pics.
e46 projector
e46 projector with the bracket
fitted inside the headlight
Back of the headlight.
now i will have to screw the projector to the bracket and use soem jb weld.
Then cut the back of the headlight, so i can fit the bulb adapter
I am looking to get some, where did you get em from and can you get like other colours??
Sir D, I totally agree with you on that one. for some reason, nissan feels that the reflectors are better than projectors. For halogen lighting, they might very well be right.
All the r32s/s14/s13 with the projectors have absolutely shit light output. The r33 reflectors actually have pretty good light output compared to the r32 ones.
PS: My gtr lights are almost here. woohhooo. then comes the hardbit - trying to fit them. I might have an excuse to get gtr front bar, bonnet and possibly even guards just to fit these lights on.
lol
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
