Alright done a search, well several actually to no avail...
I have a SII R33, standard turbo standard everything, never boosted.
Today after starting it, (it had been sitting there for 3 weeks unstarted) I noticed at idle a strange squel, high pitched similar to a rattle noice through the pod filter. It is very intermittent...ie is not a constant tick tick etc, but on occassion...
Now we all know the knee bone is connected to the leg bone, so is this noise from the turbo I am assuming, also this goes away as soon as the rev's increase...which makes me think the turbo shaft may be slightly out of balance...but then why intermittent.
On boost no noise other than the normal compressor noise...has anyone had this???
Should I pull the gear off and check for shaft play, is the compressor wheel rubbing on the housing????
https://www.sau.com.au/forums/topic/93968-funny-tubo-noise/
if it has been sitting for a while and not done any moving and its only at idle i would be pointing the finger at the bearings inside the turbo.
I would take off the intake pipe and see if the shaft spins freely and check it for shaft play. if it seems ok. I would take off the oil supply line and pour about 100ml of fresh oil the same as what you are currently using into the supply line hole. and give the shaft a few good spins for a minite or so. connect the supply line back up and the intake and start the car (you can drain 100 odd ml from the sump if needed)
sometimes if a turbo is hot when last run and then it sits for a long period the oil inside the bearings semi solidifies. I think this may be your problem.
hope this helps.
https://www.sau.com.au/forums/topic/93968-funny-tubo-noise/#findComment-1697156
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast andĀ veryĀ unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If IĀ lieĀ about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley hasĀ terribleĀ reviews but @DuncanĀ made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
Ɨ
Ɨ
