  • Replies 41
Id say its a good thing to do while the heads off.
Remember boost is a measurement of restriction of airflow. Anything that helps the motor breathe better is good imho.
You will get better power out of it for the same boost that you had before....
On a side note, the guys who did mine and Cubes did it for roughly $200 ish...anymore spent wasnt worth the $ to power gain....
https://www.sau.com.au/forums/topic/94018-port-and-polish/#findComment-1698640
As you guys were saying, porting isn't really necessary or needed at mild modding.
But, wouldn't polishing the combustion chamber be a nice measure to help control Knock if and when he plans on upping the boost?
I bet that would be rather inexpensive to just polish without porting.
https://www.sau.com.au/forums/topic/94018-port-and-polish/#findComment-1699787
I agree with RB240av and clayoth
better flow = more power, more efficiently (free kilowatts so to speak)
the amount of power an engine can develop is dependent on the mass of air it can breathe per unit of time – a simple mathematical fact of life for an engine builder.
I have seen (or read about) up to 30% gains when porting the RB25 head, and I'd think it would be worth while no matter what the boost level (IMHO)
Modern heads may be good - but they are still mass manufactured and include castings and dags.
At a minimum you should look at port matching, a polish up of the combustion chambers (for a cleaner burn) and a polish up of the inlet and exhaust valve bowls. Keep in mind you may also need to replace valve seats and seam seals at the same time (if you are not doing so already)
get it tidied up - you know you should ;)
https://www.sau.com.au/forums/topic/94018-port-and-polish/#findComment-1703742
yeah I don't see the point at mr crusts level of modification... unless bigger turbo and fuel system are waiting in the wings... even then I would be looking at cams instead... however it all changes if the head is stuffed and needs a recondition or you plan on running sky high revlimits
in a GTR its a different story
https://www.sau.com.au/forums/topic/94018-port-and-polish/#findComment-1703835
Its not really free kilowatts at all. Same could be said by adding 1-2psi in, doesnt "cost" you anything.
With a better flowing head, itll make same power @ less boost, potentially...
But if you want to make more power you need to screw more in anyway.
On a stock turbo your limited to the boost you can run, so there is no benefit either way that can be justified. Even a mild 2530 upgrade or something to 220-240rwkw
I mean i ran a 100% stock head, flowed fine for the 270rwkw on 17psi outta the gt30, 330rwkw on some 104/24psi
I was on a budget then, and i couldnt justify the cost at all.
I didnt do cams for that reason either.
It was $1000+ that could be better much spent on a PowerFC/AFM/Fuel system IMO, and it was ;)
https://www.sau.com.au/forums/topic/94018-port-and-polish/#findComment-1703864
totally... I spent a grand on cams and there is no contest between the effect of that mod vs when the cooler went in... the cooler won hands down! but I kinda knew that would be the case;)
so yeah, save your money
https://www.sau.com.au/forums/topic/94018-port-and-polish/#findComment-1703900
My head has been ported and has a set of Tomei cams. Was advised NOT to polish the head, something to do with the fuel spray, this came from the porter.
Unlike those that have not experienced the benefits of porting and cams, but still like to talk it down, i can not speak highly enough of the benefits i have felt and gained.
BUT: As stated b4, this should be done after a turbo upgrade. Wether you decide on just a "hi-flow rb25/vg30 turbo" or go crazy with a "T78", gains can be had with porting and cams.
My "hi-flow rb25/vg30 turbo", with porting and cams is making 270rwkw@15psi, compared to Ash's GT30 making 270rwkw@17psi. I have also the added bonus of looking standard, as the turbo has the factory comp cover/housing and factory shields.
Once again: these should be one of your last power mods, but i beleive that they shouldn't be overlooked.
https://www.sau.com.au/forums/topic/94018-port-and-polish/#findComment-1704230
But you did all the mods at once, but hard to judge how good one thing is when you do a complete package of mods.
We made the same power (although would loved to have tested that same dyno to compare much more accurately) but i saved what... $1500? :D
More beer money for meeeeeeeeeeeeeeeeee :lol:
https://www.sau.com.au/forums/topic/94018-port-and-polish/#findComment-1704562
We made the same power (although would loved to have tested that same dyno to compare much more accurately) but i saved what... $1500?  :)
I too would have liked to see a same dyno, same day, comparison, As i believe that dyno charts aren't really worth much. Mind you my car is only fully tunned to run 255rwkw, as i never intended to run over this power, with a std bottom end. :D
Note: Little off track :blink:
Did you save that $1500?
What about the new ic piping, oil and water lines, most people require a new exhaust manifold (You were lucky and has the GTS-R manifold), maybe an ext. wastegate, etc. When you add all these up, just to acheive a similar figure, how much are you really saving, you'll probably find you are actually spending more :)
Lets not forget all the hidden costs:
- More boost=less reliablity
- EPA: You mods stuck out and were obvious, the officer will really have to know his stuff to pick up on my mods. B)
https://www.sau.com.au/forums/topic/94018-port-and-polish/#findComment-1705588
now now - lets settle it down girls
let's agree that port and polishing is a good thing - but only when it's justified, and I mean in terms of cost and desired performance
Let's also agree that to REALLY see the benefits - you need the other supporting mods, EG exhaust, dumps, AFMs CAMS and the list goes on
My opinion is that once these other mods ARE done - that you will see better results if the proper prep work has also been done
I also ggree - $1500 is a lot of beer (or scotch in my case :))
https://www.sau.com.au/forums/topic/94018-port-and-polish/#findComment-1705636
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
    • You can probably scrub the rust with a toothbrush or something. After you get the rust off flush well with water to neutralize and you will probably want to also use a fuel tank sealer to keep it from rusting again.
    • The sodium citrate solution is designed to buffer the citric acid to keep it from attacking metal quite so much, the guy that came up with that recipe did a ton of testing on how much metal loss occurs over time and it's nothing crazy unless you forget about it for months:
