I have three questions regarding a R33 Line.
- Firstly, i owned a NA r33 and whenever i turned the car of completly, then back on 20mins later, the climate control would come back on to the same settings as it had when i turned the car off.
(i.e. the fan was on two, the temp was on 22oC, the AC was on and it was going both feet and face. But when the car is turned off, for about 10mins or so, it would revert back to, not AC, 25oC and the fan is on one. It does it everytime.)
I have an idea that its not getting power when the car is off, the climate control is not getting direct power from the battery.
- Second question is the clock is giving the same symptons, it reverts back to 1:00, whenever the car is off for more than 20min as well as its is nearly impossible to view in the day time and only just viewable at night time. Has anyone had any simular experiences. (as per my last car, it worked fine day and night and never reverted back to 1:00.)
- Third thing is last night when driving home, my HICAS light came on and just stayed yellow/orange until when i turned the car off. It hasnt done it today but i am kinda wanting to know what happened.
If anyone has experienced any of these things, could i have your advice and/or what the outcome was.
Cheers,
https://www.sau.com.au/forums/topic/94027-three-questions-regarding-r33/
Well... the clock should dim when you put headlights on... see if it goes dimmer.
It almost sounds like everything is wired up to accessories or something weird like that. I've never thought about whether the A/C has an EEPROM or whether it has a small amount of power when the car is off.
Perhaps check the wiring of the clock and/or AC with a multimeter when the car is off?
I'm sure someone on here will have an answer for you though!
Im not sure about the accessories, but i think your correct. I havnt taken the dash out to have a look, i just purchased the car from an SAU member 3 weeks ago. All i know is, no matter if the lights are on or off, or the dimmer is up or down, you still cant see it in the day, you can only just see it at night.
It would have a small amount of power, you would think, thats how it remembers.
I will check the wiring when i have some more time.
I hope someone does. Cause its rather annoying, thanks for you imput.
It is obvious that you have lost the circuit that provides battery backup to the A/C and the clock. Happy hunting.
The problem with the visibility of the clock is that they are back-lit - you have blown the globe (like a panel globe) that lights the clock.
Mitch its definately a clash with the assories and +12 perm line.
Seems like your AC and clock's +12 perm volts line is not connected or is wired incorrectly with the assories.... So when its off the +12volt goes away...
I wired my HU the wrong way around and when I turn off the car the AC and clock would reset. Then I rewired it and it worked fine.
ALso check fuses if they have somehow blown? but then again u wouldnt get any power if they were.
This is all well and good and i think you are all on the money, today is going to be spent messing around with it. But one weird thing about the way the precious owner wired the headunit is, the 12V +, comes directly from the battery... i think that qualifys for "what the" because there is a power in the dash to be used. (well there was in my NA R33.)
UPDATE:
i pulled the dash out today, None of the wires in the plug going to the clock or the Climate control have been cut or pulled out.
I am totally stumped. I left the clock out and now im trying to find someone whos r33 i can use to put my clock in and see if it does the same thing. Anyone in the western sydney/st clair/erskine park area wanna give me a hand?
Cheers,
SINDOWS
with the HICAS light, have you got a after market steering wheel? if so ya mite not have the correct boss (got no idea what that is im just relaying what i herd from a friend) in the steering colem.. i THINK, that the bos tells the HICAS what position the steering wheel is.. or sumthing like that, i duno..
pritty much, ya ether havent got the right boss or nun at all and that could be y the HICAS light is coming on
hopfuly this will get ya on the right track to asking some1 who knows more.. :D
Yeah i got an aftermarket nismo steering wheel.
It has a boss, but after reading another thread, when you travell on the highway and dont turn the steering wheel much the yellow/orange light comes on, i noticed that work the other night when i was on a straight for ages and it came on.
Thanks for the advice.
Cheers,
SiNDOWS
Cheers,
SiNDOWS
oh kool, i was half right :P lol
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
