I have three questions regarding a R33 Line.
- Firstly, i owned a NA r33 and whenever i turned the car of completly, then back on 20mins later, the climate control would come back on to the same settings as it had when i turned the car off.
(i.e. the fan was on two, the temp was on 22oC, the AC was on and it was going both feet and face. But when the car is turned off, for about 10mins or so, it would revert back to, not AC, 25oC and the fan is on one. It does it everytime.)
I have an idea that its not getting power when the car is off, the climate control is not getting direct power from the battery.
- Second question is the clock is giving the same symptons, it reverts back to 1:00, whenever the car is off for more than 20min as well as its is nearly impossible to view in the day time and only just viewable at night time. Has anyone had any simular experiences. (as per my last car, it worked fine day and night and never reverted back to 1:00.)
- Third thing is last night when driving home, my HICAS light came on and just stayed yellow/orange until when i turned the car off. It hasnt done it today but i am kinda wanting to know what happened.
If anyone has experienced any of these things, could i have your advice and/or what the outcome was.
Cheers,
https://www.sau.com.au/forums/topic/94027-three-questions-regarding-r33/
Well... the clock should dim when you put headlights on... see if it goes dimmer.
It almost sounds like everything is wired up to accessories or something weird like that. I've never thought about whether the A/C has an EEPROM or whether it has a small amount of power when the car is off.
Perhaps check the wiring of the clock and/or AC with a multimeter when the car is off?
I'm sure someone on here will have an answer for you though!
Im not sure about the accessories, but i think your correct. I havnt taken the dash out to have a look, i just purchased the car from an SAU member 3 weeks ago. All i know is, no matter if the lights are on or off, or the dimmer is up or down, you still cant see it in the day, you can only just see it at night.
It would have a small amount of power, you would think, thats how it remembers.
I will check the wiring when i have some more time.
I hope someone does. Cause its rather annoying, thanks for you imput.
It is obvious that you have lost the circuit that provides battery backup to the A/C and the clock. Happy hunting.
The problem with the visibility of the clock is that they are back-lit - you have blown the globe (like a panel globe) that lights the clock.
Mitch its definately a clash with the assories and +12 perm line.
Seems like your AC and clock's +12 perm volts line is not connected or is wired incorrectly with the assories.... So when its off the +12volt goes away...
I wired my HU the wrong way around and when I turn off the car the AC and clock would reset. Then I rewired it and it worked fine.
ALso check fuses if they have somehow blown? but then again u wouldnt get any power if they were.
This is all well and good and i think you are all on the money, today is going to be spent messing around with it. But one weird thing about the way the precious owner wired the headunit is, the 12V +, comes directly from the battery... i think that qualifys for "what the" because there is a power in the dash to be used. (well there was in my NA R33.)
UPDATE:
i pulled the dash out today, None of the wires in the plug going to the clock or the Climate control have been cut or pulled out.
I am totally stumped. I left the clock out and now im trying to find someone whos r33 i can use to put my clock in and see if it does the same thing. Anyone in the western sydney/st clair/erskine park area wanna give me a hand?
Cheers,
SINDOWS
with the HICAS light, have you got a after market steering wheel? if so ya mite not have the correct boss (got no idea what that is im just relaying what i herd from a friend) in the steering colem.. i THINK, that the bos tells the HICAS what position the steering wheel is.. or sumthing like that, i duno..
pritty much, ya ether havent got the right boss or nun at all and that could be y the HICAS light is coming on
hopfuly this will get ya on the right track to asking some1 who knows more.. :D
Yeah i got an aftermarket nismo steering wheel.
It has a boss, but after reading another thread, when you travell on the highway and dont turn the steering wheel much the yellow/orange light comes on, i noticed that work the other night when i was on a straight for ages and it came on.
Thanks for the advice.
Cheers,
SiNDOWS
Cheers,
SiNDOWS
oh kool, i was half right :P lol
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
    • You need to buy a Saab Matt, ours had a button that turned all the dash lights off. Any decent aftermarket dash has sufficient brightness control and a headlight input for day/night settings. None of which probably helps OP
    • Yeah thanks...i thought it would be alot more i dont know 馃槃 I saw some videos on converting push/pull and it seems you need to "drill" the hole for slave(master) cylinder and buy some converter kit. On that front yoke clip i did not even know that is a thing and i need to source that(custom shops do not do that?) But anyway thank you for the info
    • Not the headlight. It's the DRL that serves double duty as white and amber. Would be the easiest way to make it happen, if fitting a BCM was in any way an easy thing. Otherwise you'd do it with some relay logic and/or maybe some diodes.
    • Would require a very smart body control module which these cars are about 20 years to old to have
