Ok, just did an oil and filter change (third oil change, 2nd filter)
Now, how the hell do i replace the oil filter (without a hoist etc) and NOT have oil piss off everywhere because the filter is mounted on its side? Do i need to just deal with it and clean it up?
Tried to replace the fuel filter, DAMN those lines are put on HARD. Is there any took that i could use? I was thinking of buying one of those puller things which attached to a hose and then you screw in a screw forcing the hose off. Is that the best idea?
To replace the ATF, do i just drain the fluid at the transmission sump and then top up from the dip stick bit? Anyone know how much fluid i need or is a more "as much as you take out" answer that i will get?
How do i replace the diff oil? I think this may not need replacing often, but hey, i reckon its never been done on my car (F and R) so id wanna just be smart about it.
Thanks for all your replies :D
https://www.sau.com.au/forums/topic/94037-some-general-service-question/
Thanks for all your replies :)
not much oil will come out when filter is removed ..few drops only ,fuel filter should have been changed at compliance..not that long ago i presume .fuel filter supposed to be good for 40,000klm so i don`t know if really needs changing.
auto trans is best serviced by the auto trans guy .. drains oil ,removes pan..cleans or replaces internal filter and he knows how much oil to put back in ;)
and as far as the diffs .you need a pump to get oil back in ..the auto trans guy should have one :D
It could have been changed at compliance, but when the car is wound back and the fuel filter on there is not a genuine nissan, i dont want to take any chances.
Best to be safe then sorry ey?
When i replace my oil filter i get a good 1/2 glass worth of oil drip down on my diff/steering rack etc...
I am using genuine nissan filters, what can i do to change this? I want to get a oil filter relocation kit, but have fears with the oil being needed to be pumped that extra distance.
oil filter change is abit messy, only way of keeping it 100% clean is a remote oil filter setup which is what the 26 needs cause its in a bastard of a spot.
the more oil in the entire setup the better i thought, and the relocation kits should have a non return valve maybe to stop it all draining back into the sump?
fuel lines r a pain, especially old ones that aint been off in 10 years :D but i recently bought a set of fuel hose removing pliers from repco for $20 i think, and they are like opposite opening pliers so when u press them together they spread the end apart, and they grip onto the metal line and press the fuel line off easy as piss, no more smashing knuckles and swearing like i did for the past 5 years hehe :lol:
ask at local auto shops and they will sell em, coventrys has em too i think.
auto gearbox is probably easier done by a shop because when they change the fluid they actually pump all the old shitty stuff out and replace it with new stuff, rather than just draining 90% of it and topping it back up.
diff is easy, just remove the back plate off and let it drain out, then put plate back on with a new gasket or gasket goo, and then wait abit before refilling, making sure the gasket stuff is set (read gasket goo instructions to find out).
easiest way to refill it is get about a 2 metre length of tube (as big as will fit in the diff plug hole and hold it up above the height of the diff at the rear of the car (roof height and start filling up, once it reaches the diff plug hole and starts leaking out its full, as the plug hole is the full line :)
personally i reckon the diff is probably the original shitty oil and is worth changing.(old diff oil smells lovely too :lol: )
cheers
Brad
pics of fuel removal pliers for ya alex :) go buy some, best $20 u will spend.
Edited by StageZilla
I have the same mess when changing the oil filter, it just goes everywhere. And then I had trouble getting the new one to srew on. Tryed for 5 mins dam thing, Then hey I'll use my other hand/arm and hey screwed on first go, just couldnt get the right angle with the other hand for some reason.
I did the fuel filter the other day, Yes the hoses are very tight, I used pliers to wrigle the hose around till it has movement. Lost a little fuel while changing it but nothing to worry about. Try and block off the hoses when you change them.
Does anyone know of a decently priced (i.e., good value, but not cheap) oil-fliter relocation kit, or should I just stump up and buy a full oil-cooler kit and get the relocation kit they usually have thrown into that lot?
Thanks in advance,
Nick T.
Re the diff fluid, you don't need to take the back off. There will be a drain plug under the diff (1/2 drive, can be verrry tight). And a filler plug on the side of the diff, just use a length of hose like stagezilla said.
Always undo the filler plug first! You don't want to undo the drain plug, drain all the oil, then find you can't refill it.
SZ good tip on those pliers I'm looking for a pair :D
SZ good tip on those pliers I'm looking for a pair :)
cheers for the info duncan on not having to remove diff plate, i aint been near my diff for a long while, and i forgot about the drain plug, im thinking back to the VL commo days when changing diff oils thats y, and they dont bother with a drain plug (too smart for holden :) )
fuel pliers are brilliant, maybe groupbuy time haha, though $20 is bugger all anyway.
cheers
Brad
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
