Shit, you could have a redline of 10,000rpm if you wanted too but most engines will be producing peak power way before this, and it would require racing forged parts.
What are you really interested in, make shitloads of power, cause a high rev limit is not the best way to go.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9404-high-revving-rb20s/#findComment-142000
I have an auto GTS-4 (vitually standard with a few minor mods) and when I drive at around 55-60kph then I floor the accelerator and drop the auto into 1st you get to see the tacho needle go way past the 9000rpm so I checked the Avc-r and Rsm to check the actual peak figures and both display figures around the 11500rpm (wasn't that high to start with was 10500 first and now it say's 11500 so I broke my old record by 1000 rpm)
and there was no engine damage at all!!(dam no matter how hard I try I still can't break the RB20)
I nearly couldn't believe it the first time I saw it!,I was showing a friend the functions of the Avc-r!
You can imagine the look on his face too!! :lol:
MEGA
P.s might post pic of screen with the 11500 on it if you wan't!
https://www.sau.com.au/forums/topic/9404-high-revving-rb20s/#findComment-143305
My RB20 runs a standard (I think!) ECU with APEXI A/F & I/T units piggybacked. Cutout should be 8400rpm but I've seen over 9 without a hint of hesitation. Everyone else is right about wasting your time up there as power gains are non existant even with a solid huffer upgrade. No matter how well engineered the RB series are, they're still going to eventually deteriorate or destruct sooner if pushed that hard! Where's the love?
Curious though! Does anyoune know what would most likely give up first? Is it valves, rods or something else?
https://www.sau.com.au/forums/topic/9404-high-revving-rb20s/#findComment-143329
put a brick on the gas pedal in neutral. I'm sure it will see a good 15-17,000rpm before the engine parts start coming out the exhaust.
we did this to a mazda 808 wagon(and a few others) with the 1600cc motor and although we didn't have a tacho readout, we were pretty sure it was singing at 14,000rpm for a good 10min of fireworks display out of the tail pipe, the longest we ever saw, before the engine seized.
https://www.sau.com.au/forums/topic/9404-high-revving-rb20s/#findComment-143348
When looking at RB20 there arent many people making rods for them, maybe because they arent seen in the same class as RB26/Sr20/2JZ etc. But its worth considering that they are pretty bullet proof factory so no one bothers with overkill rods stronger then the engine could ever flow.
Out of interest does anyone know any stats of the old Sammut Bros Drag 300ZX. I know it ran an RB30, but id be curious to know the level of mods considering the number of untubbed 9/10 sec VLs getting around VIC
https://www.sau.com.au/forums/topic/9404-high-revving-rb20s/#findComment-143359
Guest nismogtsx
I dont rev my motor....
Even though its built for 8000+ rpm gear changes, I dont due to boost bleed caused by a faulty ext wastegate i am just driving the car gentlly until the new turbo/wastegate/intercooler package gets delivered.... I have had the car to 9500rpm back in the days when it had its original stock IC but now with the larger FMIC and turbo the car hits peak power at 5700 rpm and any thing after that is a waste of time... Know what i mean....
But im sure that once i get the new larger turbo ill be able to drive the motor to the best part of 10,000rpm, but even then i will never keep hitting it..
My average gear change is at 3,000rpm i really dont drive the turbo... When i get up it im changing at 5000rpm... But when i really get up it ill go to 9000+rpm (not recientlly as explained above.)
https://www.sau.com.au/forums/topic/9404-high-revving-rb20s/#findComment-143380
What computers are you all running so that your engines actually hit those revs???
I wouldnt be happy if i got my car back from the tuner and they had increased my redlien past say 8200rpm. Engines stresses increase exponentially as revs rise.
If i understand correctly its safer doubling engine power using boost only whilst maintaining factory redline, then to increase the rev limit from the factory 7400 (on my engine anyway) to say 10,000rpm. Neither are really safe if you dont want to rebuild/replace an engine if (some may say when) she goes bang.
https://www.sau.com.au/forums/topic/9404-high-revving-rb20s/#findComment-146959
8200 seems to be the the red line most quoted I know of a very strong rb 20 that was pulling hard to 8500 and this motor ran in this state for 2 years making 5-600 hp it was using tomei forged pistons 82 mm so a 2.2 kit with the rb 26 crank install you can look at 9000 rpm. personalyy 8 k seems fine to me although my car has the rev limiter set to 7600 why you ask cause with my current turbo there is no point.
meggala
https://www.sau.com.au/forums/topic/9404-high-revving-rb20s/#findComment-147041
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
    • Nvm ignore this I read it wrong
